AllTorque Posted December 4, 2019 Posted December 4, 2019 If it is a factory tint it is ok. It will have “AS3” on the safety mark. If it is a film it won’t be factory. 1 Quote
locost_bryan Posted December 4, 2019 Posted December 4, 2019 8 hours ago, rusty360 said: I think I'll go get it tested by a tint place with a VLT meter and go from there. I have read that some mazda 6 wagons have a light tint behind the drivers seats. This could be why these windows are to dark. Cheers for the info! A lot of cars have privacy glass from new, so you're tinting tinted windows. 1 Quote
rusty360 Posted December 5, 2019 Posted December 5, 2019 11 hours ago, AllTorque said: If it is a factory tint it is ok. It will have “AS3” on the safety mark. If it is a film it won’t be factory. Does this mean anything? Quote
AllTorque Posted December 5, 2019 Posted December 5, 2019 That is not factory tint. Looks pretty dark. 1 Quote
rusty360 Posted December 5, 2019 Posted December 5, 2019 Yeah it's got film on it, but I'm wondering if it's got film over a factory tint. Only one way to find out. Now how to get them off! Quote
Bling Posted December 5, 2019 Posted December 5, 2019 Youtube it, will be covered for sure. I have a curly one. Car is going for cert at some point, I want a different plate on it that it currently has. Can't get new plates made or put on to car till it is licensed. Can't get licensed till WOF'd. Can't get WOF till get cert, don't want old plate on cert plate. Currently only have one PP as it was on a trailer. Boom. Will this be a case of paying for a new cert plate the day after it's installed? Will try my luck with Licensys, but it doesn't seem like the sort of system that has wiggle room. 1 Quote
ajg193 Posted December 5, 2019 Posted December 5, 2019 Can you take it for a cert with no plate on it? That way they would just record the VIN number? /I really don't know and can't contribute in this case but I am interested in the answer Quote
KKtrips Posted December 5, 2019 Posted December 5, 2019 38 minutes ago, Bling said: Youtube it, will be covered for sure. I have a curly one. Car is going for cert at some point, I want a different plate on it that it currently has. Can't get new plates made or put on to car till it is licensed. Can't get licensed till WOF'd. Can't get WOF till get cert, don't want old plate on cert plate. Currently only have one PP as it was on a trailer. Boom. Will this be a case of paying for a new cert plate the day after it's installed? Will try my luck with Licensys, but it doesn't seem like the sort of system that has wiggle room. You can request your plate is made without a rego number on the plate. PS - are you going to get a PP for your car? I might know a guy who MIGHT be able to arrange your new PP on it. (I'm not promising but I can try) edit - FWIW - a mismatching rego number is one of the only 2 things that is not required to match on the cert plate for a WoF. 3 1 Quote
Bling Posted December 5, 2019 Posted December 5, 2019 Handy to know about not needing a rego on the cert plate. I will PM you. 1 Quote
Nominal Posted December 5, 2019 Posted December 5, 2019 48 minutes ago, KKtrips said: edit - FWIW - a mismatching rego number is one of the only 2 things that is not required to match on the cert plate for a WoF. Temporary seat removal? BTW, my plate is 4562KK - spooky! 1 Quote
KKtrips Posted December 5, 2019 Posted December 5, 2019 Yup temporary seat removal is the only other thing. Gold star for Terry. 3 Quote
RUNAMUCK Posted December 5, 2019 Posted December 5, 2019 I thought it was the ride height? /ling 1 Quote
Nominal Posted December 6, 2019 Posted December 6, 2019 6 hours ago, RUNAMUCK said: I thought it was the ride height? /ling Ride height is plus or minus 15% IIRC Had to do some careful looking to find the seat rule /who'd be a WOF man eh? 2 Quote
Nominal Posted December 6, 2019 Posted December 6, 2019 See, that's what I get for winging it 1 Quote
MaxPower Posted December 6, 2019 Posted December 6, 2019 Hi there, I have got spindles, stubs, discs, and callipers off a 1992 L300 to go onto my 1983 L300, the problem is the upper ball joint hole is larger on the new suff (there is no ball joint that fits off the shelf) can I get an engineer to make some hard tapered adapters like these? I hope so because they are getting made next week. https://www.doctordiff.com/a-body-upper-ball-joint-tapered-adapter.html Have read that the upper ball joints don't have as much stress as lowers so should be sweet? Thanks. Quote
KKtrips Posted December 6, 2019 Posted December 6, 2019 12 minutes ago, MaxPower said: Hi there, I have got spindles, stubs, discs, and callipers off a 1992 L300 to go onto my 1983 L300, the problem is the upper ball joint hole is larger on the new suff (there is no ball joint that fits off the shelf) can I get an engineer to make some hard tapered adapters like these? I hope so because they are getting made next week. https://www.doctordiff.com/a-body-upper-ball-joint-tapered-adapter.html Have read that the upper ball joints don't have as much stress as lowers so should be sweet? Thanks. I'm presuming you mean for cert? But regardless of if WOF or cert, unfortunately no you cannot. The problem with them is if you pull the ball joint out of the stub and the tapered insert falls off, then you might not notice and do the joint up and it might pull up tight but there will be play (and a lot of it) once you start driving. Quote
RUNAMUCK Posted December 6, 2019 Posted December 6, 2019 It's illegal, but you could have the taper welded up, and reamed to the smaller size. "THOU SHALT NOT MAKE A WELD UPON ANY FORGING WHICH IS EMPLOYED IN SUSPENDING OR STEERING A MOTOR VEHICLE" However, done tidily, it's impossible to prove it's been done. However depending on the metal used, it might go hard as fuck and need to be annealed before it can be reamed. Since you're not a welder be trade @MaxPower please dont do that. ;-P And if you do please use a gasless MIG or damp welding electrodes. (With 5 pairs of sunglasses) 5 Quote
KKtrips Posted December 6, 2019 Posted December 6, 2019 Bart - NAUGHTY Welding cast is an absolute no-no so please ignore Bart cos that is super dumb advice. If you are changing hubs and stubs, why not change suspension arms too and retain the correct ball-joints? 4 1 1 Quote
