  • Replies 9.9k
16 minutes ago, cletus said:
Depends on the car, some are on the buckle end, some are in the retractor, but either way still has to function
If it's at the buckle end and integral to the seat then I'm pretty much out of luck eh?
With cracktesting of welded struts.
Do I need to get the forms for what kind of testing they need to do from the cert guy or will the crack testing man provide the right forms?
Will the cert guy need a way of identifying the struts afterwards because once cert is booked in they will obviously be painted?
@Dudley the certifier will give you the form you need, called the F008, take it to the test lab with the struts. Ask the certifier, what he would like to see around identifying the struts.
Is there a place online I can get the form? Don't really want to use the whangarei certifier. So plan to get them tested with a form and find a certifier in auckland or Hamilton.
Certifier fills in parts of the form as required, so even if you can download it, that won't work. Speak to the certifier you wish to use and go from there, much easier if you get them on board before you do anything.
WOF gurus could you fill me in on tinted windows, VTNZ has just failed the missus mazda 6 for windows being to dark. It's been tinted for a long time. Is there somewere I can find out the specs and what windows are allowed to be what darkness etc etc. MR VTNZ said it was a new rule.
https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/vision/glazing
https://www.nzta.govt.nz/safety/vehicle-safety/vehicle-equipment/vehicle-windows-wipers-and-mirrors/
I thought that the 35% VLT  was a long-standing number.
@Dudley as @Bling said, part of the form is filled out by the certifier.
You could just take the parts to an NDT lab and ask them to crack test them, but without the form they won't know what result the certifier is looking for and you may have to redo it if it is wrong, so it is better if the certifier gives you this form and it is done right the first time.
Without the form is like asking a builder to build a garden shed without any idea of where and how the customer wants it built.
Yup talked to the local certifier again and he was alit more helpful this time. Have dorm and they have passed crack testing so @kpr must know what he's doing with the ol tig welder.......
probably too late for you as it's agains the record but can you just wind the window right down and pull fuse - window winder operation is not wof requirement, is it?
anyway, do they have some sort of measuring device to check VLT?
that sounds bogus man but maybe easier to pull it out than argue about it.
it's like the time my car got failed for "excessive" emergency foot brake pedal travel. it didn't matter that it was within the manufacturer's specification.
  • Haha 1
  • Sad 1
A window does not need to go down for a wof. It does need to have a safety standard on it, so it needs to be up to be checked.
A station wagon can have 35% tints max. If there are no back seats it becomes a goods vehicle and then can have dark tints on the rear windows.
I think I'll go get it tested by a tint place with a VLT meter and go from there. I have read that some mazda 6 wagons have a light tint behind the drivers seats. This could be why these windows are to dark. Cheers for the info!
