  • Replies 118
Don’t get it too clean. You’ll be too scared to use it in case it gets dirty again. I’m sure you don’t need to be told to make sure the cooling system is 110%
yea cheers for the heads up.
i may put a new radiator in it. i have no idea what state the current one is in, ill know more when i change the condenser.
it "looks" like the water pump is fairly recent but again, for what its worth ill probably just put a new on on it.
oh shit also, i forgot to mention but i need to put some roof racks on it.
its got rails but i don't know what type of rack mount will fit into the rails.
I believe they are called track mounts. 1999 ford Explorer has the same thing.
You can look up rhino leg track mounts
Any history of a head being done?
When the diesel pump starts to leak its a o ring in the top housing of the pump that's a mega cunt to change without putting plastic through the pump and wreking it
If you go for a hoon to Hyper Drive they will (probably) have all your roof racking needs.
Our surf was the shape before but (apparently) the viscous fans on these is a weak point. More Barry surf’s might know more.
A nice set of Reccaros buckies will look good up front.
Yeah can change to a thicker fluid in them, mine was fucked that even with super heavy fluid it wouldn't lock up.
Thankfully it only cost me a head gasket and a gasket set etc rather than the brand new head to figure that out.
Brand new one was cheap enough that I shouldn't have bothered trying to mess about changing the oil.
Also the 10 blade fan from late model 1KD Hilux is a big upgrade from the stock 7 blade, @GuyWithAviators is the man to talk to about them.
Did the 185s come out with recaros?
I wasn't sure if it was only the 130s?
Yeah they certainly did, had a headrest with horizontal strings, instead of the fishnet type. See them more often in the V6 Petrol models.
On 16/02/2024 at 18:16, sheepers said:
Good idea man,  I'll get on to that
Also new glow plugs, they have a habit of snapping the tip off and banging around inside the cylinder..
