RUNAMUCK Posted January 11 Posted January 11 You're gonna get a sticker on your wheelie bin next bin day, "Bin exceeds maximum permissible weight" 3 Quote
sheepers Posted January 11 Author Posted January 11 Yea fuck I just put all the old parts in the recycling and she's not light.... 2 3 Quote
Popular Post sheepers Posted January 17 Author Popular Post Posted January 17 I Wanted to grease the driveshaft slip yokes because they looked a bit dry so I climbed under the truck and started unbolting the driveshaft to get it apart. I got 3 of the bolts out but I kind of couldn't really get to the top one so I climbed out and pushed the truck forward a bit to allow easier access. Climbed back under the truck to get the last bolt out and that's when I discovered it has grease fittings on all the joints. So I put the bolts back in and got out the grease gun....... 2 1 12 Quote
sheepers Posted January 17 Author Posted January 17 The auto shifter was all over the place like a mad woman's shit so I pulled it out and found all the bushes for the couple of links had completely vanished. Made some new bushes and put it all back together. It's perfect now. 9 Quote
Popular Post sheepers Posted January 18 Author Popular Post Posted January 18 I dunno what the fuck this thing is but it said rude things about my haircut so I took it off and threw it in the bin. 8 7 Quote
sheepers Posted January 19 Author Posted January 19 Then the motor was really loud and wouldn't go right. I had to make some bungs to fill the holes left by that pipe thing. 6 Quote
sheepers Posted January 19 Author Posted January 19 Some fuckin fully hectik cunt has been playing race car driver and probably had a boost tap on the waste gate. When they removed it the left a long piece of fuel hose to activate the waste gate. That fuel hose was long enough to loop up and rest against the exhaust manifold. Shockingly it had a hole burnt in it, so the wastegate wasn't working at all. It works now and seems much happier about the whole ordeal. 2 Quote
Raizer Posted January 19 Posted January 19 6 hours ago, sheepers said: I dunno what the fuck this thing is but it said rude things about my haircut so I took it off and threw it in the bin. On my 1KZ I had to leave that plugged in or it'd throw up the check engine light and go into limp mode, it's now cable tied somewhere by the starter motor and the ECU is happy. 1 Quote
cletus Posted January 19 Posted January 19 59 minutes ago, sheepers said: Some fuckin fully hectik cunt has been playing race car driver and probably had a boost tap on the waste gate. When they removed it the left a long piece of fuel hose to activate the waste gate. That fuel hose was long enough to loop up and rest against the exhaust manifold. Shockingly it had a hole burnt in it, so the wastegate wasn't working at all. It works now and seems much happier about the whole ordeal. Is it now not going as hard for wat it is? 2 Quote
sheepers Posted January 19 Author Posted January 19 45 minutes ago, Raizer said: On my 1KZ I had to leave that plugged in or it'd throw up the check engine light and go into limp mode, it's now cable tied somewhere by the starter motor and the ECU is happy. Yea, same. 1 Quote
sheepers Posted January 19 Author Posted January 19 35 minutes ago, cletus said: Is it now not going as hard for wat it is? I think it arguably goes harder? For what it is. 2 1 Quote
Popular Post sheepers Posted February 6 Author Popular Post Posted February 6 "EGR removal phase two, the de-sliming" Got new genuine toyota gaskets for the intake then took it all apart. Fuck what a mess. I am now covered in sludge but anywho it's cleaner. The ports were about 6- 8mm smaller all round due to the amount of buildup in the manifold walls. I got all the shit out and also got the ports in the head all cleaned out. Put it back together. It goes way better, it's super noticeable how much better it goes. You could say it goes hard, For what it is. 25 1 Quote
sheepers Posted February 6 Author Posted February 6 been driving the truck around this morning and i can confirm with actual science* that the truck has way more power than it did before. fuck, what a difference. *no actual science has been used in the making of this post. 9 Quote
xsspeed Posted February 6 Posted February 6 what calibrated gluteus acceleration sensors arent science? 1 Quote
sheepers Posted February 6 Author Posted February 6 neither are gravel burnouts in the driveway apparently. 8 Quote
sheepers Posted February 8 Author Posted February 8 I like to cruze around with the back window down. Had a bit of zorst smell sometimes so I made a side exit zorst to hopefully send the fumes to outside my environment. 8 Quote
sheepers Posted February 11 Author Posted February 11 Bought new stalks because they were available and not too expensive. I also ordered the clear cover for the gauges and in typical amayama fashion they listed it, sold it to me, took my money, waited two months and then told me they are NLA. I love how amayama do that. 5 2 Quote
