Truenotch Posted January 18, 2019 Posted January 18, 2019 I've had this thing for a few months now, time to start a project thread. After the East Cape Escapade I was super fizzed about riding on gravel and keen to build / find something more capable than the FS1 for such duties. After a bit of browsing around on trademe and Facebook, this little gem popped up in Wellington: It's a 1983 Yamaha MX100 and looked like the perfect starting point for my dirt track dreams. I got in touch with @My name is Russell to go and have a gander with the idea that he'd grab it if it seemed OK. The price was 150 clams, so I figured it was worth a crack! Russell took the family for a weekend jaunt in the Cortina and came home with the prize: So far, so good. Next was the challenge of getting it up the country. Lucky for me, @Carsnz123 and @smokin'joe were doing a freight run from CCH to drag day and had space on their enormous trailer. Woohoo! It's in Hamilton. 1 Quote
Truenotch Posted January 18, 2019 Author Posted January 18, 2019 There's a fair few thing to sort out (as you'd expect), but the first thing I wanted to know was how it would look without all the superfluous 1980's bits. I stripped it back and was pleasantly surprised by its bones: Popped the head off to have a look at the cylinder: Yip, the bore is quite rusty. After a quick measure it's still at the factory size (52mm) and there are piston options for up to 3mm overbore in .25mm increments. First big job on the to-do: rebore. Then I got it naked: I decided it might look better with the bars from the FS1, so I bolted them on and pushed it outside for a few pics: Oh yeah, did I mention it's small? Here's its stature compared to the FS1. The seat height is quite low with the '80s bolster seat removed. e It also has a decent dent in the tank that'll need dealing to at some stage... and I'm definitely leaning towards paying someone to do it. Quote
Truenotch Posted January 18, 2019 Author Posted January 18, 2019 Then I decided to delve a bit deeper. These are CDI, which I'm stoked about as the points are the biggest letdown on the FS1. I was pleasantly surprised to find that the magneto cover screws came out without needing an impact driver. The cover took a couple of taps to come off, and then this gushed forth: I need to get my flywheel puller back from @flyingbrick to assess the situation properly, but that bad boy was full of rusty water! I'd say the cover area was at least half full by the look of the flywheel. I'm quite confused about how it got in there... My current theory is either that water has slowly seeped in during it's time stored outside or the thing was driven through a lake before it was parked up and maybe took a mouthful of water into the engine, which has eventually come out through the crank seals? Who knows! More investigation required. Quote
yetchh Posted January 19, 2019 Posted January 19, 2019 That's funny, I have a yamaha mx1000. A glorious 250...... Watts per channel.. Quote
Truenotch Posted January 19, 2019 Author Posted January 19, 2019 10 minutes ago, yetchh said: That's funny, I have a yamaha mx1000. A glorious 250...... Watts per channel.. Hah! Steve and @mark105 had a similar experience with Steve’s DX100. Apparently his bike is a keyboard. Quote
Truenotch Posted January 19, 2019 Author Posted January 19, 2019 Pulled the flywheel off: that’s one crusty stator plate! Any bright ideas on the beat way to clean the coils? Quote
tortron Posted January 19, 2019 Posted January 19, 2019 PCB cleaner. They have a shellac type varnish on the old ones and any alcohol will dissolve it Quote
flyingbrick Posted January 19, 2019 Posted January 19, 2019 Jesus.. what a mess. What about a soak in vinegar? Should (im no chemist, only guessing) disolve all the rust and leave the varnish and copper alone? Quote
Lord Gruntfuttock Posted January 19, 2019 Posted January 19, 2019 CRC Lectra-clean? Used to use heaps of that stuff. Melts some plastics but made for electrics. Quote
My name is Russell Posted January 21, 2019 Posted January 21, 2019 Looking good. Can you find an of the shelf replacement stator plate? Quote
Truenotch Posted February 9, 2019 Author Posted February 9, 2019 Gave the magneto and cdi pickup a good clean and threw it back on. Checked for spark and it was strong. Win! Today I collected a POS RX125 parts bike that had a DT100 engine. I took the gamble that the engine would be the same as it had a fresh oversized piston and machined barrel. Turns out there’s quite a few subtle differences, but it’s mostly the same. The barrel has the same casting numbers and looks identical. Got it home and started ripping bits off it. fitted the barrel to the MX100 Chucked on the FS1 tank as it still has some premix from the East Cape mission. It looks quite good with this tank! Got it together enough for a test run. Success! It runs. That’s one win for the weekend . Quote
TimShadboltfan27 Posted February 9, 2019 Posted February 9, 2019 Let me know if you wanna flog any rx125 bits off I could be keen... Quote
Truenotch Posted February 9, 2019 Author Posted February 9, 2019 35 minutes ago, TimShadboltfan27 said: Let me know if you wanna flog any rx125 bits off I could be keen... Flick me a PM with your shopping list. At this stage I’m only using the engine, rear wheel, swing arm and some electrics. Quote
GuyWithAviators Posted February 9, 2019 Posted February 9, 2019 Different model to yours but reminded me of what you’re doing with these ol’ hogs. Come make my V90 work better pls. Quote
Truenotch Posted March 12, 2019 Author Posted March 12, 2019 Haven’t made much progress with this lately, but have bought a couple of bits to help with inspiration. Picked up this spanny, most likely from a YZ125 apparently. Offered it up to the bike and it looks like it’ll work with a bit of fettling. Also found this tank and guard that are a bit more suited to the style I want: might need to shorten the tail of the bike a bit to get the proportions right as the tank is slightly shorter than the original, but I’m happy for now. Quote
Truenotch Posted October 29, 2019 Author Posted October 29, 2019 One month left until the Urewera ride and I’ve barely touched the MX100. It needs a lot of work before doing a 500+km mission, so I was looking at taking the FS1 again. Then one day an old acquaintance sent me a message on Facebook: The price was right and it has a couple of upgrades (GN125 rear shocks!). Thanks to @crustywhip for the OSGC freight service to get it up to Hamilton. There’s a list of things to do, but it will all be achievable within 4 weeks. Hopefully it’ll be ready for a medium distance shakedown by mid November! So far I’ve taken it for a brief squirt up the road. Wound it out to 70kph at low rpm in 5th, so it should have a reasonable cruising speed for the open road stages. Quote
Truenotch Posted November 6, 2019 Author Posted November 6, 2019 The countdown to Te Urewera is on! So far I've managed to complete a few things: Replaced broken front brake lever Made headlight and tail light work Fixed lighting switches Shocked myself trying to operate the kill switch Installed a horn button from another bike as a kill switch Fixed chain tension (it was floppier than I've ever seen) Tightened head tube bearings Checked oil pump - it works! The previous owner was pre-mixing the gas because he doesn't trust self-mix setups... But it still has 1/4 of a tank of oil and my from my tests it seems like the pump works fine, so it would have been RICH on oil the whole time he owned it. Still to do: Fit new front tyre Luggage rack / panini paneer panniers Mount number plate Carb clean and rebuild Fit an ignition barrel / key / anti theft device It also has a bit of a rattle that I think could be piston slap or a noisey kickstart idle gear. More diagnosis required. I've poked my finger up the exhaust port and it certainly seems to have some slap at BDC. It might need a good warm run before I can diagnose it properly. If it comes to it, I've got a freshly bored cylinder on the other MX that can go in its place. Quote
Truenotch Posted November 6, 2019 Author Posted November 6, 2019 New front tyre fitted: Speedo in place: Dodgy epoxy job to keep the sensor where it should be. I slapped a couple of neodymium magnets onto it for a stronger signal: And this sweet accessory courtesy of @Geophy. Perfect for a few beers and other paraphernalia. Quote
Truenotch Posted November 7, 2019 Author Posted November 7, 2019 Took the FS1 for hoon with the Speedcocks after work. Good practice for Te Urewera, but it would have been nice to be on the MX! When I got home I was inspired to work on the MX. First up, I took a video of the rattle that I suspected to be caused by piston slap: The camera did a good job of picking up the sound. It didn’t sound this bad IRL. I had a re-bored and oversized barrel/piston on rev other MX, so pulled that off and swapped them over. Here’s what it sounds like now: Much better! It has a bit of lean-hang going on, so I’ll pull the carb apart, clean it and check the jet sizes before a shakedown on @mark105‘s paddock this weekend. Here’s a pic of it looking more complete for good measure: Quote
Truenotch Posted November 9, 2019 Author Posted November 9, 2019 Carpe diem: seize the day. I blarped around town all morning yesterday - the bike is fun! Tried to ride it out of town with @Beaver and got about 1km at 85kph, then it locked up. It’s had quite a bit of lean-hang and I probably should have looked into it more.... I suspect the left hand crank seal is the cause. Pulled the flywheel and stator plate off and you can see evidence of oil that’s made its way out. I’m going to throw some crank seals at it this week, clean up the piston / barrel and hope for the best. 2 stroke 4 lyfe. Quote
