Truenotch Posted November 16, 2019 Author Posted November 16, 2019 I've been chasing the cause of the seize since last weekend and have done a couple of things. The bike acts lean on the overrun, which is usually caused by a vacuum leak or a lean pilot circuit in the carb, so I've been through a few things in search of the lean hang. Replaced both crank seals - no change Set float level in the carb - no change Changed the reeds over (they weren't seating completely flat on the block) Changed 17.5 pilot jet to a 30 from another carb - it's now very rich up to 1/4 throttle, but still hangs and pops on the overrun Refitted air box properly (it was loose when it seized and could have been leaning the mixture) - still hangs Disconnected the oil pump and changed to premix I highly recommend Blackwood Yamaha in Cambridge for Yamaha parts. They were super quick to respond to my queries and I had my crank seals on the same day. Their prices are reasonable too. I took it for a hoon yesterday after work and it didn't seize, so that's a bonus. I'm using the old rattly cylinder for testing so I don't have to care if it seizes again. It went pretty well and cruised happily enough at 70-75k, but felt like I was wringing its neck at 80+. When it seized last weekend, I was doing 85kph, so I must have been pulling a few revs! It's hard to find information about the MX100, but the specs I've found online for the older DT100s say that the max power RPM is 7500 (pre 1980 DT100s have the same engine but with points instead of CDI). I did a few calculations to see what revs I was pulling at 85kph: (Black is standard gearing, red is my new planned sprocket size) At 85kph I would have been doing around 8300rpm! This is probably a bit hard on an old engine that's only designed for 7500-8000 max. The red numbers in the table show the RPM for the rear sprocket I want to fit - this will sit me at about 6700 at 85kph which is a much more manageable number! It will also allow me to wind it out to higher speeds when I need to. Here's a link to the wheel speed/RPM calculator I used: http://woodsware.aciwebs.com/gears/ I'm not convinced that the problem is fixed yet, but it's looking promising. I'll head to @Geophy's place on Sunday to use his ultrasonic cleaner to make sure the pilot circuit is nice and clean. Here's my list of what might have been the problem: Lack of lubrication resulting in high cylinder temps (trusting the original oil pump) Too many RPMs Air box boot not fitted properly - LEAN Partially blocked pilot circuit - LEAN Piston to cylinder clearance too tight on new cylinder Ring gap not set correctly All of the above I'll get the new cylinder back onto it and will go for another hoon and see what happens. It's under 2 weeks until the big ride, so the pressure is on! Quote
Truenotch Posted November 16, 2019 Author Posted November 16, 2019 Forgot to add: Current sprockets are 14/48 (3.429:1) Desired sprockets are: 14/39 (2.786:1) 18.75% increase in gearing and means I might actually use the lower gears on the open road. Quote
Truenotch Posted November 16, 2019 Author Posted November 16, 2019 Fuel can, panini storage, tank bag and hypercolour handlebar bag fitted. The rack is from the FS1: I’ll need a backpack for undies and Brian Lowns too. Quote
TimShadboltfan27 Posted November 16, 2019 Posted November 16, 2019 Total Andy /ling but gizz 17.5 pilot to have a play with my RX125... will swap you a 30 if you need spare bits Quote
Truenotch Posted November 16, 2019 Author Posted November 16, 2019 5 minutes ago, TimShadboltfan27 said: Total Andy /ling but gizz 17.5 pilot to have a play with my RX125... will swap you a 30 if you need spare bits I’ve got a 17.5 from my spare carb if you want to have a play? Quote
TimShadboltfan27 Posted November 16, 2019 Posted November 16, 2019 Yea foreshore and seabed! Keen for campsite carb rebuilds in Waikaremoana tbh. Keep it in your back pocket Jim. Mine runs a 30 standard and is suuuuuper rich at idle and 1/4 throttle I’m interested in anything that will lean it out down low. Quote
peteretep Posted November 16, 2019 Posted November 16, 2019 Hey @Truenotch how does the oil system work? I see you have changed to premix but is the oiling adjustable, or some way you can see if it was working properly? I put a drill to pump oil on both my scoots to prime them/check them. My Suzuki has a non adjustable oil setup but the aprilia is adjustable Quote
Truenotch Posted November 16, 2019 Author Posted November 16, 2019 @peteretep - it’s a little pump that runs off the primary reduction gear / main clutch gear and it’s operated by the throttle via a split cable. As you wind the throttle on it opens the pump more and you can set the min/max position of the pump. The pumps can wear our and get weak, which I suspect has happened here. I’ll probably rebuild it later on for ease of use. I tested mine by pulling the hose off and idling the bike with the pump turned to max and it gave a dribble so I figured it was good. The proper way is to set the RPM and measure how much comes out (which I didn’t do because no tacho). Quote
Truenotch Posted November 17, 2019 Author Posted November 17, 2019 Gave the carb a good clean with @Geophy's ultrasonic cleaner today. Blew out all the jets and passages and re-assembled it with the standard 17.5 pilot jet. Whacked it all back together and the hang + pipe bangs were exactly the same. Then I wound the idle screw out as far as I could so it wouldn't idle and it sounds good: Maybe the pipe bangs are a normal characteristic for these motors when the idle is cranked up a bit? Took it for a hoon and adjusted the mixture screw a bit. It goes really well! I might have been chasing a red herring by looking for a lean issue with the carb, but at least now I know it has a very clean carb, new crank seals, correct oiling (premix). Next job is to gear it up . Quote
Truenotch Posted November 23, 2019 Author Posted November 23, 2019 New sprockets are fitted and I’ve had some successful testing . Glad I didn’t gear it up any further because it’s only just able to pull 5th gear at the moment. You’ve got to hang on to 4th for quite a while and then bang into 5th at 80k or so. It’ll cruise on the flat at 85-90 and I’ve seen 96kph on the gps with a bit of a downhill run. Popped the “good” cylinder back on and took it for a hoon out to @Archetype‘s place for a few laps of his paddock. It’s fun on the gravel and grass! It died on the way home and I was shitting myself thinking it had seized. Turns out it had run out of fuel, so I flicked to reserve and powered on. Unfortunately I didn’t reset my odo after fueling up, but I think I got around 60km from the 4.5l tank. Hopefully a spare 5L will give me enough range for Te Urewera. Quote
Truenotch Posted December 8, 2019 Author Posted December 8, 2019 This thing got a good dose of mud and dust during Te Urewera Undertaking a couple of weekends ago. It performed great and didn't miss a beat over the whole 550km distance! Only issues to report were the rack failing on Day 1 due to too much weight bearing onto the rear guard. It bent rack far enough that the rear wheel caught the numberplate and folded it upwards (folding the guard in half at the same time). The guard pulled straight (enough) and my tools rode in the service wagon for the rest of the event. Notice the relocated number plate too. Hah. The other issue was on day 3 when my fuel can (now strapped to the seat) came loose and blocked my exhaust! It happened just after going through a ford, so I was looking for wet spark components. The plug, coil etc were all dry as a bone and it wasn't until a few minutes later that I noticed the fuel can was blocking the pipe. It was super close to burning through and could have turned me into a fireball . Such a great way to spend a few days and I'm already hanging out for the next one! It's given me some inspiration to start working on the blue MX again, so I'll start chipping away on that over summer. Quote
lachy1324 Posted May 14, 2020 Posted May 14, 2020 hey guys need some help pulling apart rear shocks on my 1980 mx100 Quote
Truenotch Posted May 14, 2020 Author Posted May 14, 2020 1 hour ago, lachy1324 said: hey guys need some help pulling apart rear shocks on my 1980 mx100 I’ve never pulled a set apart before, but ask the question in this thread, I’m sure someone can help: Quote
Truenotch Posted May 15, 2020 Author Posted May 15, 2020 Front tyre is a 2.75-18 Shinko SR241 and the rear is a 3.5(?)-16 Shinko Holeshot super extreme knobbly. Quote
lachy1324 Posted May 24, 2020 Posted May 24, 2020 so i finally got them apart and turns out they're dead so does anyone know and shocks that will fit on my bike would be a huge help. Quote
Mop Head Posted May 24, 2020 Posted May 24, 2020 Just measure how long they are and then search the measurement and the word shock afterwards on the internet. Try trademe, aliexpress etc. For example if I wanted a 280mm pair of shocks I would search "280mm shocks" on websites I mentioned before. Make sure they have the same mounting points as your old ones and you're sorted. Quote
Truenotch Posted November 24, 2020 Author Posted November 24, 2020 I've decided that knobbly life is not for me, so the holeshot has been retired and there's now an SR241 GOLDENBOY gracing the rear of the MX. @Mitch.W and I went for a test hoon yesterday and the bike felt fine. The rear feels WAY better on the road and at least as good on the hard-ish gravel we were hooning yesterday. Aliexpress fuel can arrived today too. Good timing! Revised paneer for the other side: The rear wheel bearings were pretty loose in the wheel, so I grabbed a new set and @BLIZZO kindly punched my hub and goo'd the bearings into place with retaining compound. Should feel a bit more solid after that treatment! Quote
Popular Post Truenotch Posted October 13 Author Popular Post Posted October 13 Woah, long time no update! Since the last post this bike has done Raglan Ride, Te Urewera Undertaking 2020, Molesworth Mellee 2021, Marlborough Melee 2022, East Cape Escapade 2022, DGR in Wellington, moved to Queenstown for a few years and now I'm starting to daily ride it in Christchurch. The only changes over the years are a slightly different fuel tank (it's about 2L bigger than the original, plus it's older style and has a more simple quarter turn cap) and a yellow headlight from Aliexpress because @johnnyfive threw a rock at me (with his XL185) during East Cape 2022 and smashed my headlight. Here's a highlight reel: 20 Quote
