JustHarry Posted April 2, 2018 Posted April 2, 2018 30 minutes ago, cletus said: I blew all the remaining fuel back into my face/eyes character building I think its called Bet that hurt/stung real good. Done same sort of thing . Paint thinners is a real goodie to get in eyes. 0/10 would try again Quote
RUNAMUCK Posted April 3, 2018 Posted April 3, 2018 I though about this problem again today. I propose we drill an M8 tapping drill through the Centre of the bung. The screw in a cap screw and throw a bit of fizz onto where the head meets the bung. Then hit the capscrew with the duggadugga gun. Profit. Quote
JustHarry Posted April 3, 2018 Posted April 3, 2018 Reverse threaded bolt threaded in? Like you say m8. Should hold up I think we've got a couple reverse thread taps at work Quote
Bling Posted April 3, 2018 Posted April 3, 2018 Someone on that side of town needs to just get er done. Quote
- i5oogt - Posted April 3, 2018 Posted April 3, 2018 I will have some more time to dedicate to this once Nats is over Quote
Beaver Posted April 3, 2018 Posted April 3, 2018 This thread is almost as bad as how manu/Steelies should have moved His container house..... 3 Quote
tortron Posted April 3, 2018 Posted April 3, 2018 1 minute ago, nzed said: how you gunna get the swarf out from drilling that hole and tapping it..? just pull the sump off. be faster than fucking around moving welding gear and power cords and shit. if bashing an impact socket on wont work. you ladies are spending more time talking about then just getting it sorted! It's genius, the flow of oil out of the sump will flush the swarf out. I would just use that bung as the new smaller sump plug Quote
RUNAMUCK Posted April 3, 2018 Posted April 3, 2018 Once the bung is out I would have poked a telescopic magnet in the hole and removed the tiny bit of swarf. And a left hand thread capscrew would be a bit of a unicorn. Quote
h4nd Posted April 9, 2018 Posted April 9, 2018 On 3/31/2018 at 22:58, RUNAMUCK said: I'd weld a bit of ten mm bar to.it in a heartbeat. It's just my welder isn't very portable Interestingly, @yetchh and me were chatting about a small hand-held battery welder at Nats... Quote
yetchh Posted April 9, 2018 Posted April 9, 2018 15 minutes ago, h4nd said: Interestingly, @yetchh and me were chatting about a small hand-held battery welder at Nats... Side sharn.. 2 1 Quote
RUNAMUCK Posted April 9, 2018 Posted April 9, 2018 I'll just fix Karls welder and return that to him. Problem solved. 1 Quote
JustHarry Posted April 25, 2018 Posted April 25, 2018 Nice and clean...... Sort of @- i5oogt - has before photos The question was how to remove the sump bung. Answer. +Heat Quote
- i5oogt - Posted April 25, 2018 Posted April 25, 2018 Thanks @JustHarry for your help today. new sump gasket and bung. It was a bit yuck under the rocker cover... 2 1 Quote
JustHarry Posted April 25, 2018 Posted April 25, 2018 5 minutes ago, tortron said: Just needed some sharns to loosen it up eh No sharns were involved in the removal of this bung 2 Quote
Carsnz123 Posted April 25, 2018 Posted April 25, 2018 I do recall looking in the filler cap when you first picked it up and saying "eww that looks a little gummed up in there" Quote
yetchh Posted April 25, 2018 Posted April 25, 2018 Fill the whole thing up with deez and let sit for a couple of weeks.. 1 Quote
ajg193 Posted April 25, 2018 Posted April 25, 2018 There are only really two possible solutions, LD28 or 13B. 1 Quote
JustHarry Posted April 26, 2018 Posted April 26, 2018 Took manifold to work today and extracted broken bolt. Drilled most of the way. Then dremmeled the remainder of the bolt out Thread was pretty chewey so a 6mm thread insert later and it's good to go 1 Quote
