ajg193 Posted January 5 Share Posted January 5 Yep, Wargames Best hacker movie of all time 1 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted January 5 Share Posted January 5 Wasnt it an AI that wanted to nuke the russians? And right before the missles launched they asked it to play noughts and crosses with just one player. where it learned that nobody would win, and it aborted the missle launch? I feel like it's name was Jacob? 2 Quote Link to comment Share on other sites More sharing options...
rusty360 Posted January 5 Share Posted January 5 7 hours ago, mjrstar said: @HighLUX it was something like 3s crank seals, 4k Mains and big ends (there are 2 different sizes), 4k middle and oil rings, with Honda d16 top piston rings. The crank thrust washers were unique, I think I still have a set of two of them.. I might also have a couple of Honda rings because I must have used 1.5 sets to do the rebuild... From memory the head gasket also wasn't all that easy to procure.. valve shims are 16v 4age, as are the valve stem seals maybe from memory.. EDIT: Found this box dated 2003 and I have written 1G on it at some stage.. Can't help with replacement pistons though sorry. Well unless you need a complete runner 1ggte with a KP starlet attached supra 5 speed and shortened Hilux LSD etc.. That starlet must be a farking handful! Bet it's fun though Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted January 5 Share Posted January 5 9 hours ago, HighLUX said: Cheers. Had a young guy come from Auckland before and grab some 1G bits off me, namely a block as he had bought @BlownCoronas old Crown and it blew up on him at Hamilton after driving it home from Dunedin so hes trying to rebuild it at the moment. Il pass the info on thats weird, last i heard he made it home to auckland fine but with some temp strangness but then at some point it did a headgasket and he had the original block sorted out and was putting it all back together. i helped him locate a head gasket ect. i wonder if it was for his other crown Quote Link to comment Share on other sites More sharing options...
Doug Hill Posted January 5 Share Posted January 5 Has anyone got any tips identifying zinc vs aluminum castings? Apart from a specific gravity test (hard on complex parts) the only reliable thing I can think of is dilute copper sulfate should turn zinc black and not react with aluminum? My GT125 cases and head were clear/blue passivated, so need to get the process right incase some is aluminum. I suspect the barrels and the stator/points cover are aluminum, they're a lighter colour in person. Pic of glass bead fapped parts 1 Quote Link to comment Share on other sites More sharing options...
GregT Posted January 5 Share Posted January 5 Everything there is aluminium. Colour differences are pressure die casting alloy mix vs gravity die casting. Nothing they left as cast would have been clear coated originally - normal Suzuki finish of the era was silver paint. Two pot epoxy silver is the common replacement now. Some pieces like the side covers would have been polished then clear coated. A look at brochures or road test pics on line will tell you what to polish. Edit - the best paint to use I'm told is Durapox. I've seen several sets of cases done in it and it's a good finish. Zinc based I've only ever found used on components in contact with fuel. Some carb bodies and float chambers and the occasional tap. 2 Quote Link to comment Share on other sites More sharing options...
Doug Hill Posted January 5 Share Posted January 5 6 minutes ago, GregT said: Everything there is aluminium. Colour differences are pressure die casting alloy mix vs gravity die casting. Nothing they left as cast would have been clear coated originally - normal Suzuki finish of the era was silver paint. Two pot epoxy silver is the common replacement now. Some pieces like the side covers would have been polished then clear coated. A look at brochures or road test pics on line will tell you what to polish. Zinc based I've only ever found used on components in contact with fuel. Some carb bodies and float chambers and the occasional tap. I thought so too, until I went to blast the cases and they appear to be clear/blue passivate, as was the cylinder head. I'll snap a pic inside casings to show. Barrels and most covers appear to be painted or polished aluminum. My later GT motors are all painted though. The other possibility is Zamac or whatever that classic zinc alloy was Quote Link to comment Share on other sites More sharing options...
Doug Hill Posted January 5 Share Posted January 5 Shows up less on camera, but there's a blue tinge. Just like clear passivate. Problem being, if it's all aluminum it will be difficult to achieve the factory finish Quote Link to comment Share on other sites More sharing options...
GregT Posted January 5 Share Posted January 5 I'm still convinced the cases are aluminium as I've never seen anything else used by Suzuki. I suspect you're seeing a stain rather than a factory finish. I know that Laverdas have a problem repeating the OE finish on castings as as they were chromate treated - with a now illegal NATO chromate. Which is a unique colour... I'd try painting the lower case and see how it comes out. Painted silver is as close to OE finish as you're going to get. Quote Link to comment Share on other sites More sharing options...
Doug Hill Posted January 5 Share Posted January 5 It wasn't painted, unless it's a tinted clear that replicates passivation. But it did not blast off like paint does on the engine casings They could be aluminum, and that's fine, it just changes the process to replicate the OEM surface finish. Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted January 5 Share Posted January 5 Zinc blends are used because its more free flowing when casting. Ie, you can cast in more detail, and save on maching costs. The more garbage metal in the pot, the more free flowing it is. (Like carburetors for instance) Quote Link to comment Share on other sites More sharing options...
h4nd Posted January 5 Share Posted January 5 Oh! Just Googled that. Pot metal! Quote Link to comment Share on other sites More sharing options...
Doug Hill Posted January 5 Share Posted January 5 So i rushed to farmlands and got some cipper sulfate because i lost my other bag. Did a control test on some zinc fasteners, scotchbrite then dilute copper sulfate, instant black. Gave each part a sneaky scotchbrite. Zero reaction essentially. GregT wins the cookie. Happy i confirmed it with a science though. So I guess I'm looking at conversion coatings for aluminum now. Can't say I've ever seen a paint finish that will replicate it Quote Link to comment Share on other sites More sharing options...
GregT Posted January 5 Share Posted January 5 Even on polished sidecovers the clear changes colour over time - and with heat. If, as is possible, the raw castings out of the dies were clear coated, and it's oxidised to the colour you see now, I don't see a way of getting the casting surface back to original. Possibly a chemical soak might do it. Any abrasive - even walnut shells or plastic media - will leave a texture rather than a dead smooth surface. Quote Link to comment Share on other sites More sharing options...
Doug Hill Posted January 6 Share Posted January 6 And there we go, I figured it out. Left casing was washed and sprayed with MetalPrep (Phosphoric acid + Zinc Phosphate), poor man's alodine or zincate Right casing is glass bead blasted 7 Quote Link to comment Share on other sites More sharing options...
h4nd Posted January 6 Share Posted January 6 On 05/01/2024 at 13:49, h4nd said: I have been formally gifted the family Osbourne 1 https://wedistribute.org/2023/07/mastodon-retro-clients/ Quote Link to comment Share on other sites More sharing options...
h4nd Posted January 10 Share Posted January 10 Network connected wrenches (think Boeing 'is that nut 27/B really 20nm? - I guess) are being hacked. And ransomewared. Riiiiiiiiiight. https://mastodon.social/@arstechnica/111726377301903842 2 Quote Link to comment Share on other sites More sharing options...
locost_bryan Posted January 10 Share Posted January 10 Is that Boeing's excuse for the side falling off? 1 Quote Link to comment Share on other sites More sharing options...
kws Posted January 10 Share Posted January 10 2 hours ago, h4nd said: Network connected wrenches (think Boeing 'is that nut 27/B really 20nm? - I guess) are being hacked. And ransomewared. Riiiiiiiiiight. https://mastodon.social/@arstechnica/111726377301903842 Today in this episode of "things that don't need to be internet-connected"... 4 Quote Link to comment Share on other sites More sharing options...
h4nd Posted January 10 Share Posted January 10 35 minutes ago, locost_bryan said: Is that Boeing's excuse for the side falling off? 4 Quote Link to comment Share on other sites More sharing options...
