Spencer Posted November 4, 2015 Share Posted November 4, 2015 Dismantle and expect, if they have a big lip they probably need sleeving, a little rust/black shit then hone it, if it looks lush then seals and do nothing. Quote Link to comment Share on other sites More sharing options...
M Night Shamalayan Posted November 4, 2015 Share Posted November 4, 2015 Rad! Thanks Quote Link to comment Share on other sites More sharing options...
Rookie Posted November 4, 2015 Share Posted November 4, 2015 If there is any thing in the bores I would try clean it up with scotchbrite and crc, if there is any pitting hone it, and if that doesn't work get a new one or resleave it. Quote Link to comment Share on other sites More sharing options...
Spencer Posted November 4, 2015 Share Posted November 4, 2015 Yes sorry always use a scotchbrite and some lube first to clean up shit. Quote Link to comment Share on other sites More sharing options...
h4nd Posted November 12, 2015 Share Posted November 12, 2015 Philae lander bounces animation. They were luck it ended up vaguely upright... http://www.esa.int/spaceinvideos/content/view/embedjw/461001 Quote Link to comment Share on other sites More sharing options...
SOHC Posted November 13, 2015 Share Posted November 13, 2015 Where in Auckland would I get NGK B9EG sparkplugs??????? Quote Link to comment Share on other sites More sharing options...
peteretep Posted November 13, 2015 Share Posted November 13, 2015 http://www.mainlandkarting.co.nz/index.php/products1/spark-plugs/ngk-b9eg-rok-plug/ ??? Quote Link to comment Share on other sites More sharing options...
slipsittin Posted November 24, 2015 Share Posted November 24, 2015 Commonly used in gokarts and motorcycles for racing, so start with bike shops. Try Automotive Supplies or Supercheap too Quote Link to comment Share on other sites More sharing options...
stillway Posted November 24, 2015 Share Posted November 24, 2015 not exactly in auckland.. but rockauto are cheap Quote Link to comment Share on other sites More sharing options...
CorollaGT Posted November 24, 2015 Share Posted November 24, 2015 If you want something soon-ish Toyota NZ have a Denso equivalent (W27ESV) and they're $4.60 each rrp Quote Link to comment Share on other sites More sharing options...
peteretep Posted November 26, 2015 Share Posted November 26, 2015 why is it that tappet settings change for different cams? personally I have had no luck with bigger tappet settings, as in they make a big racket that never seems to die away and when I set the tappets to factory settings they run sweet without issue 1 Quote Link to comment Share on other sites More sharing options...
Roman Posted November 26, 2015 Author Share Posted November 26, 2015 Does anyone know of a factory FPR that will fit a Toyota rail, that's higher than ~40psi? Everything I've seen that's ~60psi runs a returnless line and FPR in the tank. Trying to avoid a big bulky external aftermarket one if I can. Quote Link to comment Share on other sites More sharing options...
fletch Posted November 26, 2015 Share Posted November 26, 2015 How much pressure do you want? Give your stock one a love tap with a hammer to squash the spring up a bit for some more psi. 2 Quote Link to comment Share on other sites More sharing options...
Rookie Posted November 26, 2015 Share Posted November 26, 2015 Roman, just get an aliexpress tomei one, they are sweet and not that big. Quote Link to comment Share on other sites More sharing options...
Yowzer Posted November 26, 2015 Share Posted November 26, 2015 So if I were to mash R134 in my Cressidas R12 system, will the world explode? I don't even know if the compressor works so I'm not concerned about wrecking anything. The system's been empty for years. 1 Quote Link to comment Share on other sites More sharing options...
Spencer Posted November 26, 2015 Share Posted November 26, 2015 You really need to flush, new set of O-rings, new oil, new receiver/dryer then charge. Depends what the system is to how well it will work with the different gas. Pretty sure R134 mixed with the R12 oil makes bad stuff. Quote Link to comment Share on other sites More sharing options...
Yowzer Posted November 26, 2015 Share Posted November 26, 2015 Yup I have the machine and a selection of o rings so flushing ain't an issue. Otherwise maybe I'll raid a bunch of crap from a wreck and try horey it in. Quote Link to comment Share on other sites More sharing options...
Spencer Posted November 26, 2015 Share Posted November 26, 2015 Dryers can be reasonably generic and should be replaced every time you open the system so get one (be like $20). Then drop the sump on compressor if it has one, some just have a drain bolt then flush that, take lines off and flush until it flows clear, same with condenser and evap flush until clear. Then assemble with new o-rings, add manufacturers recommended amount of oil to compressor, pull a deep vacuum (important) and see if it holds overnight, if not leak test. If good charge and enjoy. A new parallel flow condenser will bump up the efficiency of the system (they are dirt cheap), and how well the R134 works also will depend how your system regulates the evaporator (there's like 10+ different styles in cars) Quote Link to comment Share on other sites More sharing options...
Yowzer Posted November 26, 2015 Share Posted November 26, 2015 Sweet gonna look into it. Quote Link to comment Share on other sites More sharing options...
HighLUX Posted November 27, 2015 Share Posted November 27, 2015 Got an old tach im wanting to install. It only has a positive and negative input. What to I tee them into to make it work? 1 Quote Link to comment Share on other sites More sharing options...
