KKtrips Posted October 7, 2014 Share Posted October 7, 2014 Project thread - //oldschool.co.nz/index.php?/topic/45349-seedy-als-1976-datsun-1200-pick-up-of-rattyness/#entry1398600 Hey Seedy you don't have the engine crossmember in backwards at all? I have a recollection about someone else doing something similar and having issues. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted October 7, 2014 Share Posted October 7, 2014 Lol na. I had thought of that but checked it against the old one again and its right. Gear box shifter is in right place. So yeah. My guess is cross member doesnt match my mounts. But un sure what cross member and mounts I need to aquire. Who would have thought putting a standard motor in a car would be dramas lol. 1 Quote Link to comment Share on other sites More sharing options...
KKtrips Posted October 7, 2014 Author Share Posted October 7, 2014 But the gearbox shifter hole may have been moved to suit the 4AGTE gearbox.... /you would know better cos you have looked at the silly thing. LOL I can't understand how the clutch fork would be hitting the firewall. My next guess is the mounts onto the block are wrong - I had that on the Commy when doing engine conversion. Quote Link to comment Share on other sites More sharing options...
Chris.QCR Posted October 7, 2014 Share Posted October 7, 2014 The problem is it's a Datsun . Plus clutches suck . Haha Wish I'd kept A series. Looks so simple 1 Quote Link to comment Share on other sites More sharing options...
anglia4 Posted October 7, 2014 Share Posted October 7, 2014 The problem is it's a Datsun . Plus clutches suck . Haha Wish I'd kept A series. Looks so simple You're a nutsack Chris Your problem isn't even engine related any more! GET OFF HERE AND BLEED YOUR CLUTCH!!! Lubs Quote Link to comment Share on other sites More sharing options...
Beaver Posted October 7, 2014 Share Posted October 7, 2014 If the clutch fork is hitting then surely that means the engine is just sitting too high? That gearbox was out of dadums wagon/all A series 4 speeds are the same size IIRC. Also looks like the firewall has been welded up? Sure it wasnt replaced with something odd for the 4age? /get the hammer out son. Quote Link to comment Share on other sites More sharing options...
Goat Posted October 8, 2014 Share Posted October 8, 2014 Do they have different clutch fork positions on the gearboxes? Quote Link to comment Share on other sites More sharing options...
Beaver Posted October 8, 2014 Share Posted October 8, 2014 negative. As I said, that box is out of dadums wagon, and then I ran it in the 120y. Quote Link to comment Share on other sites More sharing options...
Goat Posted October 8, 2014 Share Posted October 8, 2014 I meant do utes have it comming out of bottom of bellhousing or something..... Quote Link to comment Share on other sites More sharing options...
Goat Posted October 8, 2014 Share Posted October 8, 2014 Have a gander here: http://datsun1200.com/modules/mediawiki/index.php?title=Crossmember May be useless. But could shed some insite... Quote Link to comment Share on other sites More sharing options...
kyteler Posted October 8, 2014 Share Posted October 8, 2014 comming out of bottom Teehee Also, I'm not aware of any differences in gearboxes to suit the utility variant of the Nissan Sunny, more than likely the old 4AGE has tainted the ute with yuck/what beaver said, what the fuck is up with that tunnel? My brother might still have an old sedan shell sitting about that I could cut a tunnel out for you, you fruity bar steward. 2 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted October 8, 2014 Share Posted October 8, 2014 What you need Alan is a 1200 ute Xmember. They are different to all the other car/coupe/wagon etc ones. And cunts ask too much for them. All the car/wagon/coupe 1200's had the early style "front dizzy" engines. And the 120y onwards (including the 1200 utes) had the "mid dizzy" engines. So there is not going to be a bolt together solution. Often people fit mid dizzy motors into 1200's. Just by adding a plate to the top of the xmember to space the xmember to the mount. If you find a ute xmember, I have the Ute engine mount brackets to suit. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted October 8, 2014 Share Posted October 8, 2014 ok. that pretty much answered my question thanks bart! Yeah more than certain engine was sitting to high so would mosty likely explain the clutch fork problem gear box tunnel was cut out to fit a rotary before the 4age lol. But its all in the original spot. So....... really, I should not worry about this cross member coming from Auckland, in fact I don't need any of that at all, as I already have all the brake bits I need for disc conversion anyway, and try find a ute cross member........ Fuck. starting to seem I should just keep the cunt 4age lol. Probabaly cheaper haha Quote Link to comment Share on other sites More sharing options...
Chris.QCR Posted October 8, 2014 Share Posted October 8, 2014 That's not entirely true . Of the three wagons I've seen they all had the same cross members as utes. Quote Link to comment Share on other sites More sharing options...
kyteler Posted October 8, 2014 Share Posted October 8, 2014 WHAT DO YOU KNOW ABOUT 1200 WAGONS, CHRIS?! I should really chase the panel beater up about my brother's one, then we can have wagon races. Quote Link to comment Share on other sites More sharing options...
Snoozin Posted October 9, 2014 Share Posted October 9, 2014 Ol Dattochriswagon in the house. Quote Link to comment Share on other sites More sharing options...
Chris.QCR Posted October 9, 2014 Share Posted October 9, 2014 Whoa whoa whoa haha! Motorcycles rule . What would make your job easier Seedy would be a complete 1200 wagon with a crossmember installed and engine fitted to it. Super tidy . Needs clutch line and bleed to finish . Boosts hard on my drive . Offers 1 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted October 9, 2014 Share Posted October 9, 2014 Swap for a 1200 ute. And a crown or two lol. But yeah ok. If thats true im still less likely to find a wagon one the same haha. Quote Link to comment Share on other sites More sharing options...
grant76 Posted October 9, 2014 Share Posted October 9, 2014 maddat.com.au sell brand new ute crossmembers for $270 australian as a last resort?? Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted October 10, 2014 Share Posted October 10, 2014 Thats like, half the price of a cert lol. Might as well just make my own and super slam it haha. Quote Link to comment Share on other sites More sharing options...
