  • 1 year later...
  • Replies 103
Didn't catch you fellas this morning in the pits and didn't really think the arvo was a good time to talk racecars.
Tuff day on the gravel
haha yeah would of been nice to make it past the second stage! same bloody stage the motor blew up on last time too. Must be cursed.
How did your day pan out?
Work mate went well came 4th overall...
All I did was change a few tyres and tip near 50 litres in the tank, pretty damn tame compared to you fellas
Had a chance to look at it , new shell?
But god damn was it cold up in them hills.
Yeah was a cold day. Nice going. Always a good day when things go well!
Not sure if the shell can be saved yet. Need to strip body and cut the cage out before assessing what can and can't be fixed. You can pretty extensively repair a rally car I've seen much worse than this come out fairly straight.
I was going to ask how the new trumpets went but obviously not much chance to test them, How much damage was done to the cage ? glad you guys came out of it ok ive had my share of offs in the co drivers seat and know that feeling of just hanging on because you are just a passenger at that point waiting for it to stop. Keen to see this rise from the ashes so to speak and get going again.
Didn't end up running new trumpets in the end. Engine was running well for a change and didn't want to risk anything not being right with them - either not handling the heat or restricting airflow. Its something that we will have the R&D a bit further before we are comfortable to run in a rally situation.
As you know during a rally the oddest things pop up as issues cause most racecars don't have to complete a couple hundred KM's at a time so better to be safer than sorry.
Rollcage is pretty pooped. Bar above windscreen is bananna'd which has pulled the pillar bars in. We always knew the cage was pretty weak as its an oldschool bolt in design. Actually kinda glad to build a new one we always wanted to but didn't want to go through the hassle. As his day job, Nick builds a few cages and his engineering is really top notch these days so it will be the flashest cage you'll ever see in a ke20!
Was all over in a matter of 1-2 secs from it being 'OK we are running a bit wide but will bounce back onto the road...' till the obligatory 'ahh fuck' moment. Wasn't super high speed or anything nasty like that.
that's not too bad then and yes some of those old cages are super sketchy design wise or some real old one made from scaffold pipe or ally , Jonathan has made some for my car and a friends so i'll let you know how we get on with them mine are exactly the same as yours but for 45s and my mates are 50mm long they were cheap enough to take a punt on  as i have the same space constraints in the mazda.
Thats cool I'm pretty confident they would be completely fine going off all the testing and info I've come across before. 3D printing is something I'm sure we will utilise more and more in the near future.
Yeah those small filters really hold us back in the intake department. Would be nice to have long staggered trumpets but means sealing the whole area and working out how to filter the air etc etc. Def in the too hard basket for now.
  • 7 years later...
Just been back and re-read the project thread from the start, it's been a journey!
It will be good to see you getting it out and racing again.
2 hours ago, smokin'joe said:
just seen the updates,
did you see that Mike Shaw was selling a cheap FG bonnet and maybe a boot for a KE20 ?
No I didn’t see that. Might give him a ring thanks
On 21/09/2024 at 05:02, Swannie said:
Was cool to see the Corolla out there.
I believe that the Adam Fisher starlet has a 1300cc Suzuki Swift GTi engine
Thanks man. Ah true that would explain a lot. Pretty quick little car.
10 hours ago, Truenotch said:
So... When's the next rally????
Ahhh this decade hopefully?  I'm still trying to catch up on sleep/get on top of my life 3wks later :grin: busy work, sickness and toddler life has made it harder to recover from little sleep than it used to be that's for sure!!
I guess we need to figure out what's going on with the engine. What I would give for a reliable 100hp EFI engine over shitty pushrod carb crap.
Can you run efi on the 4k or is it a class restriction?
Some ITB would be fun :p
