Everything posted by Swannie
In the classsic class no, in the general 2WD 0-1400cc class yes you can run EFI
Was cool to see the Corolla out there. I believe that the Adam Fisher starlet has a 1300cc Suzuki Swift GTi engine
- 452 replies
My son and I are in the process of building this Fiat 131, it will be sign written like the replica I co-drove back in 2005
- 452 replies
- 17
Front bumper restoration complete. After giving the bumper a good clean, firstly with a water blaster then scrubbing with a brush and some warm soapy water, I needed to fill in some of the larger scraps and scratches left by the previous owners touch parking attempts. After some sanding and a quick clean with grease and wax remover it was time for a spray with bumper paint, 4 coats later and it was looking pretty good. I also took the time to paint the headlight surrounds, grill, number plate lights and grill. Now all reassembled with freshly painted number plates and LED indicators and DRLs The finished product
- 16 replies
- 17
New headlights arrived from Japan, fitted into refurbished mounts with cleaned mounting ring and new screws. With relays fitted to the headlight circuit, this should be a huge improvement in light output.
Work slowly continues on the starlet, lots of little jobs being done when time allows. Bumper brackets are currently being sandblasted & the warm weather we are experiencing in Wellington certainly helps with getting the paint to dry. I’ll be going with a black interior so I started to paint some of the trim. First a wash in warm soapy water then a spray with plastic and vinyl paint Have also spent way too long on rhdjapan.com lately and my first lot of parts arrived. Some ARP bolts for the engine and a Cusco strut brace. The colour of the mount is fairly close to the colour I’ll be painting the car so that’s a little win.
A couple of hours of sand blasting and then a soak in CRC Evapo-Rust and the first parts are almost ready for their first coat of primer.
Time to get back into this project. I brought myself a sand blasting cabinet from Supercheap, have been playing around with the nozzles and air pressure. 100psi certainly gets paint and rust off components but is probably at the limit for my 50l 2hp compressor.
- 16 replies
As part of the rebuild I’ll be getting rid of the tan/ brown interior. I’ve always liked the look of flocked dashboards so I brought a kit and decided to try my hand at some flocking. I started with the instrument panel cover as a test piece, not perfect but not to bad. Needs a few little touch ups but coverage turned out fairly even. I think I’ll spay the rest of the dash black before I flock it as the tan can show through a little of the coating is a bit light. The flocking makes one hell of a mess so you need a big tarp and clear space to work.
The car is slowly been stripped down for body work and paint and this is the only structural rust found so far. Previous repairs at the tip of the C pillar (both sides) Hole in the side of the scuttle panel Hole in in the top corner of the tail lights (both sides)
So not much has happened with this car over the last few years, hopefully soon it will get some love lavished on it. I found some cheap LED indicators and DRLs on The Market and with some slight modifications they fit the KP60 bumper perfectly.
Had one of these around 2005/2006, awesome vehicles. Awesome work with the head lining.
Finally I brought a welder, just to confirm that my welding is still sh!t. Welded up the holes left behind by the self tapping screws used to mount the mud flaps to the front guards.
Wow long time no post. haven’t done a whole lot on the car over the last couple of years, but will post up some photos of the small progress. rebuilt the front brake calipers as they were seized and the pads were almost non -existent. Also replaces the front rotors as they were under minimum thickness, ended up getting a set of 233mm discs machined down to 203mm, they will do until I get around to a brake upgrade
My uncle brough a GTO new. One of the first in New Zealand and the first in Wellington. He confirmed to me that the claimed top speed of 111mph was infact correct, as they achieved this on the western side of Lake Taupo late on night.
Swannie replied to h4nd's topic in Other Projects
Nothing flash, just a cable tie holder. Used 50mm tubing and the end caps are screwed to the wood so I can add additional tubes if required. -
Just checked, and the cables have been discontinued.
Discussion thread
Opinions, questions and help for my project thread
Scored a 4K and K50 via trade me on Monday, and the bonus was that it was local. Most the the engines that seem to be coming up for sale are either in Auckland or Christchurch For now itwill go into the car as it is, but will eventually get a big birthday with a cam, Webber carb, rings and bearings, some compression and a port and polish
One of the rear shocks was leaking , so I replace both sides. I’ll get some shortened shocks when I get around to lowering it, but these will do for now. I also cleaned up the rear inner guards whilst I had the shocks out, and gave them a coat of under seal, but forgot to take photos.
Over the last couple of months I’ve been doing a few small jobs on the car, mainly tidying things up and replacing worn out components. The previous owner couldn’t be assed spending $50 on a new set of proper HT leads, so bodged something up himself using a garden hose to preven arcing to the cylinder head! Needless to say I have fitted a proper set of HT leads and replaced the spark plugs.
- 16 replies
