Beaver Posted September 24, 2014 Share Posted September 24, 2014 No you dont. Becasue I have it! Mwahahahah I can drop it round tonight joseph 1 Quote Link to comment Share on other sites More sharing options...
KKtrips Posted September 24, 2014 Share Posted September 24, 2014 Shit - I need to keep a better eye on where I lend my tools out. But that is much easier for getting to Broseph. Quote Link to comment Share on other sites More sharing options...
Goat Posted September 24, 2014 Author Share Posted September 24, 2014 Chair bolts. Probably won't get around to torquing up head tonight. Have inlaws for dinner... Bike is in wellingtone. I am heading to the tron tomorrow night for the weekend. Will grab my one from there. Quote Link to comment Share on other sites More sharing options...
Goat Posted September 25, 2014 Author Share Posted September 25, 2014 Got the tensioners in and sorted without having to take off head. Yay. Also managed to undo all the adjustment bolts without them breaking, which is pretty common. Another yay! Just gotta torque down the head and we're good to go! 3 Quote Link to comment Share on other sites More sharing options...
Rookie Posted September 25, 2014 Share Posted September 25, 2014 Good job Broseph. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted September 26, 2014 Share Posted September 26, 2014 bad ass. good to see your fingures busy dude 1 Quote Link to comment Share on other sites More sharing options...
Mourning Cupcake Posted September 26, 2014 Share Posted September 26, 2014 Have inlaws for dinner... . Sounds.... tasty.... /spam 1 Quote Link to comment Share on other sites More sharing options...
Goat Posted October 1, 2014 Author Share Posted October 1, 2014 Torqued the head down to 20NM. WAT. that is so low... Its what the manual and the internet said though... Put rockers back on. Turned engine over by hand. No fouling or anything. Kicked it over a bit. Still no fouling. WIN! It means the cam is either correct, or 180 out. hah. Next step is to put carbs back on and kick 'er in the guts. Hopefully it bursts into life. Will attempt that tonight. Also, as i dont have a picture of my progress, her is a pic so this isn't a boring post: 3 Quote Link to comment Share on other sites More sharing options...
Steelies Posted October 1, 2014 Share Posted October 1, 2014 EXCITE Quote Link to comment Share on other sites More sharing options...
Big Value Buddy Posted October 1, 2014 Share Posted October 1, 2014 Yo G, you should cum on the rescheduled distinguished gentleman's ride this weekend. CB or GP, anything goes! 1 Quote Link to comment Share on other sites More sharing options...
Goat Posted October 1, 2014 Author Share Posted October 1, 2014 Woul like to. GP will be a bit ham for it though... But hopefully this will be ready for a WOF on saturday (hopefully friday even) Quote Link to comment Share on other sites More sharing options...
Big Value Buddy Posted October 1, 2014 Share Posted October 1, 2014 A dude as fly as you can ride whatever he likes! GP would be cool, but CB would be mega hot. Quote Link to comment Share on other sites More sharing options...
Goat Posted October 1, 2014 Author Share Posted October 1, 2014 So yea, Decided id do oil and filter change too. And though i'd pull the sump off to clean out the sludge. Its like 3/4 of the sump gasket has been glued to the engine. Sump came off fine. But the gasket is going to be an absoloute cunt to remove from the engine. And as the sump mounts between the frame rails, access is crap. Some real deal first world problems i have to deal with now.... Need to get a gasket scraper. Which i can't get till the weekend. Spanner in the works... Frustrating. Pic for thread: 1 Quote Link to comment Share on other sites More sharing options...
Beaver Posted October 1, 2014 Share Posted October 1, 2014 use a screwdriver you sissy. or I have a couple of blades (for applying bog) which work a treat, you can use 1 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted October 3, 2014 Share Posted October 3, 2014 I got taught to remove a gasket with a hammer today Mind blown 1 Quote Link to comment Share on other sites More sharing options...
Hayholes mum Posted October 3, 2014 Share Posted October 3, 2014 Hurry up shithead, the Gentleman's Ride is in 15 hours. 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted October 4, 2014 Share Posted October 4, 2014 I got taught to remove a gasket with a hammer today Mind blown Hahha explain that one Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted October 4, 2014 Share Posted October 4, 2014 depending on the gasket, if you hit the side of it, it splits it off from the casing, and if its in a place that you cant get to the side of it, you can use the ball part of a ball pein in the center of it to break it away from the alloy. hard to explain and you need to be careful 1 Quote Link to comment Share on other sites More sharing options...
Goat Posted October 8, 2014 Author Share Posted October 8, 2014 Got gasket off last night. Degreased and cleaned sump. It's all ready to bolt back up. Didn't want to use the old bolts as they looked gross. Thankyou Coastal Fastenings: Tonight will hopefully go something like this: Bolt up sump with new gasket. Fill with oil and crank over with no plugs and no oil filter until clean oil chooches from oil filter holes. I want to get all the old oil out of the system. Fit new filter. Fit exhaust. Fit ignition. Fit carbs. Start it up. 4 Quote Link to comment Share on other sites More sharing options...
Goat Posted October 8, 2014 Author Share Posted October 8, 2014 ^I actually did all of the above. It runs. And without the blow back through number 4. Yay! Next problem to tackle. The carbs on it have been fully stripped, cleaned, new gaskets, jets and needle. Back to factory jetting. The engine runs like a triumph tc. Super sluggish and unresponsive. haha (It was like this before i pulled it down and put it back together, so its nothing to do with cam timing etc) The old carbs that were on it were phucked. They had holes, no gaskets and leaked petrol like they didn't have the drain bungs in them. They were also running super duper rich. (You could see the carbon in the head caused by these carbs). However, with this POS carbs on it, the engine was super lively and super responsive. It ran like you'd expect a 11k redline 4 cyl to run. What could cause these rebuilt carbs to make the motor feel dead and super flat? Too lean? I don't know how carbs effect stz... Quote Link to comment Share on other sites More sharing options...
