sentra Posted November 25, 2012 Share Posted November 25, 2012 i wondered, but then got stuck as how would you make a 12x1.25 countersunk socket head cap screw out of a 12x1.25 grub screw? sheepers, blow my mind please, in 3...2....1..... Quote Link to comment Share on other sites More sharing options...
UTERUS Posted November 26, 2012 Share Posted November 26, 2012 Machine a nut into a cone shape and loctite it on the end of the grub screw. Quote Link to comment Share on other sites More sharing options...
M_C Posted November 26, 2012 Share Posted November 26, 2012 Metric fine in CSK = not in stock. Could you use and end mill to get a flat bottom in the hole so you can use a normal cap screw which are available in fine ex stock? Quote Link to comment Share on other sites More sharing options...
sheepers Posted November 26, 2012 Share Posted November 26, 2012 weld a nut on the end then turn a chamfer on the under side of the nut. you have the hex head from the inside of the grub screw and you're away. heat treat the thing after welding if you're worried about the strength but that's what i was thinking. easy. Quote Link to comment Share on other sites More sharing options...
ryanfels Posted November 26, 2012 Share Posted November 26, 2012 easy. Sounds like a walk in the park lol Quote Link to comment Share on other sites More sharing options...
Steelies Posted November 26, 2012 Share Posted November 26, 2012 weld the nut on without deforming the hex socket, or reducing it's depth too much? not that i would ever doubt your techniques mr sheepers, just curious. alex how thick is the plate these are going through? Quote Link to comment Share on other sites More sharing options...
UTERUS Posted November 26, 2012 Share Posted November 26, 2012 I was going to saw weld, but my welding sucks and would no doubt warp it all if I tried that. Sheepers is a fabricator overlord so he's more likely to actually make it happen haha. Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted November 26, 2012 Share Posted November 26, 2012 Did you get some? If not, I can get them through Atom/boltholder for you? Unless you have tried them and they failed you? Quote Link to comment Share on other sites More sharing options...
sheepers Posted November 26, 2012 Share Posted November 26, 2012 it wouldn't be to bad to weld the nut on the end. ive done similar things before without to much hassle but if you're having trouble you can file up a piece of copper and stick it in the hex to stop it deforming/melting. Quote Link to comment Share on other sites More sharing options...
Simon Posted November 26, 2012 Share Posted November 26, 2012 Is what ever it is centered with the chamfer of the bolts? If not you could just counter bore it and use a normal cap screw / bolt? Assuming there is enough meat in what ever you have to do this. Quote Link to comment Share on other sites More sharing options...
UTERUS Posted November 26, 2012 Share Posted November 26, 2012 Or weld up the holes/countersunk bit, drill out the hole from the bellhousing/engine face side and use normal cap screws. Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted November 26, 2012 Author Share Posted November 26, 2012 I should have taken a photo but yeah the plate is only 10mm thick. So too thin to get away with milling/spot facing down into the plate to take normal cap bolts. I have spent today mucking about with it trying to see what I could get away with. I now only need three bolts. I am hesitant to tap the current m12 x 1.25 holes out to 1/2unf because unless I get the tap started spot on in the same lead as the original thread I could pretty much cut out whats there already- the difference in radius only being .35mm. Would be hard to judge the tap start position as the holes are clearenced about 5mm in. Asked about various places in Nelson and no luck. I know these bolts exist. Mr old grumbly cat- yes please if you can find out if you can get me some that would be great. For now the plate is held in place anyway- but I will need 3 bolts for sure. 30 to 50 mm long will do fine- I can chop longer ones down. Dave- I presume you mean tig nuts onto grub screws. Well I have only just bought my first tig and have yet to fire it up (building my welding bench first before the big 'first go' my tig skills are basically shit. I sure I would end up with no nut left and a grub screw firmly attached to my new bench.... Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted November 26, 2012 Share Posted November 26, 2012 helicoil it to m12x1.75. profit. Quote Link to comment Share on other sites More sharing options...
bigmatt4 Posted November 26, 2012 Share Posted November 26, 2012 i had some made by the bolt holder in matamata for an adaptor plate to a 4age to vw bus box a few years back they are 12x 1.25 cost me about $12 each from memory think they were a larger countersunk screw machined down and re threaded Quote Link to comment Share on other sites More sharing options...
Rookie Posted November 26, 2012 Share Posted November 26, 2012 helicoil it to m12x1.75. profit. /thread. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted November 26, 2012 Share Posted November 26, 2012 /thread. yea? Quote Link to comment Share on other sites More sharing options...
sheepers Posted November 26, 2012 Share Posted November 26, 2012 i was going to weld them for you if i could get some. i suggested helicoils a page back. i reckon it would be worth seeing if you can helicoil it. would make life way easier. 1 Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted November 26, 2012 Author Share Posted November 26, 2012 Problem is I have 4 engines and not sure which I will end up using. Would rather not end up helicoiling all 4. If I decided to sell one or two of them off on trademe to some mx6/mx3/ford probe(worst car name ever?) then their bolts won't fit. I want these bolts! They are out there. In fact I have just sent these guys a pleaful email.... http://www.nssocketscrews.com/stocksystem/stock/cat/Socket-Countersunk/subCat/Metric-Fine-Pitch-10.9/prodCat/METRIC I'll keep searching... Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted November 26, 2012 Author Share Posted November 26, 2012 i was going to weld them for you if i could get some. Very kind of you sir. And in return I would let you cuddle our neighbours dirty looking cat in return while I pour you a Pear and scrumpy old mout. Let's see what this blighty bolt company replies with to my woeful story I just sent them.... Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted November 26, 2012 Share Posted November 26, 2012 if you get real stuck i could make you some new ones Quote Link to comment Share on other sites More sharing options...
