Truenotch Posted December 15, 2012 Share Posted December 15, 2012 Quote Link to comment Share on other sites More sharing options...
Bling Posted December 15, 2012 Share Posted December 15, 2012 Looks heaps better, the camber was a bit silly (IMO). Looks pretty well built. It must be to the police, what a flame is to moths. Must go to the light! Considered a car trailer version? Drive on drive off Quote Link to comment Share on other sites More sharing options...
Chris.QCR Posted December 15, 2012 Author Share Posted December 15, 2012 Yeah i was a bit of a bright light to them once they had seen it. I consider it well built. Really thick wall box section all round. 1500KG bearings,stubs,hubs,coupling. We have towed it up to 200 kmhr (On a race track of course) and it was really stable. That was with camber. I havent towed it further than the block of Hornby since changing the camber to 0 deg. will be interesting. I had two people enquire about building other slamilers but have passed as im pretty happy to have created one. It was fun having the camber based on the facial expressions you got when towing. Countless folk yelling out thier windows saying your Axles are bent! Haha Plan to build a front nose cone and enclose guards on the inside. Thinking of more of a bomber plane theme with a couple pinup girls on the sides. Quote Link to comment Share on other sites More sharing options...
lowrota Posted December 16, 2012 Share Posted December 16, 2012 I really badly want one! Quote Link to comment Share on other sites More sharing options...
AllTorque Posted December 18, 2012 Share Posted December 18, 2012 As I am a WOF inspector all this talk of slammed trailers got me looking into the rules, so I rang NZTA and was told; There is no requirement for a trailer to have suspension. There is no minimum height for a trailer. Now I wan one damn it. 1 Quote Link to comment Share on other sites More sharing options...
Chris.QCR Posted December 18, 2012 Author Share Posted December 18, 2012 Yeah my flatmate is a wof inspector too, as well as another mate and i looked into the requirements before i built it. Go for it i say! Quote Link to comment Share on other sites More sharing options...
KKtrips Posted December 18, 2012 Share Posted December 18, 2012 Will you warrant my one Roger? Quote Link to comment Share on other sites More sharing options...
AllTorque Posted December 18, 2012 Share Posted December 18, 2012 Will you warrant my one Roger? if your lights work and your wheel bearing are sweet. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted December 18, 2012 Share Posted December 18, 2012 I'll be seeing you before Wagnats then.. Quote Link to comment Share on other sites More sharing options...
Fresh Posted January 23, 2013 Share Posted January 23, 2013 I heard it was 150mph /I don't do above 50 anyway I have towed this trailer at around 200kph. 1 Quote Link to comment Share on other sites More sharing options...
camo_78 Posted January 23, 2013 Share Posted January 23, 2013 As I am a WOF inspector all this talk of slammed trailers got me looking into the rules, so I rang NZTA and was told; There is no requirement for a trailer to have suspension. There is no minimum height for a trailer. Now I wan one damn it. this is now relevant to my interests as im planning on building a low slung car trailer in the near future Quote Link to comment Share on other sites More sharing options...
dirty_leppa Posted January 23, 2013 Share Posted January 23, 2013 this is now relevant to my interests as im planning on building a low slung car trailer in the near future i was reading the trailer registration fact sheet the other day, and while they say that there is no minimum height for a trailer, if its below 100 mm then it needs cert apparently Quote Link to comment Share on other sites More sharing options...
brocky41 Posted January 24, 2013 Share Posted January 24, 2013 i was reading the trailer registration fact sheet the other day, and while they say that there is no minimum height for a trailer, if its below 100 mm then it needs cert apparently Seeing a trailer with a cert plate would be LOL as. Quote Link to comment Share on other sites More sharing options...
Cullen Posted January 24, 2013 Share Posted January 24, 2013 if there is no minimum height then why would it require lvvta certification? Quote Link to comment Share on other sites More sharing options...
dirty_leppa Posted January 24, 2013 Share Posted January 24, 2013 thats just what i read. pretty dumb the way it was worded. ill try get a copy of the fact sheet and put it up Quote Link to comment Share on other sites More sharing options...
dirty_leppa Posted January 24, 2013 Share Posted January 24, 2013 here you go, http://www.nzta.govt...ght-simple.html Minimum ground clearance There are no minimum ground clearance requirements for light trailers (but if the suspension has been modified and the ground clearance is less than 100mm, it will have to be approved by a Low Volume Vehicle Certifier). Quote Link to comment Share on other sites More sharing options...
Ned Posted January 24, 2013 Share Posted January 24, 2013 custom build trailer isn't modified so can pass without cert? Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted January 24, 2013 Share Posted January 24, 2013 custom build trailer isn't modified so can pass without cert? thats exactly how i read it too Quote Link to comment Share on other sites More sharing options...
Chris.QCR Posted January 24, 2013 Author Share Posted January 24, 2013 exactly. plus no suspension. Bearing in mind this trailer got off a pink sticker wof from AA who certainly did not want to warrant this trailer but could not find fault with anything hence the warrant Quote Link to comment Share on other sites More sharing options...
camo_78 Posted January 30, 2013 Share Posted January 30, 2013 typical ltnz,as vague as any of us after a hard night on the piss.however,im with you guys,if its custom built below 100mm to begin with its not technically modified so shouldnt need cert.as it is i was going to make my chassis rails sit bang on 100mm off the rd,because way i see it with the right length ramps any car should be able to get on it Quote Link to comment Share on other sites More sharing options...
