yoeddynz Posted January 30, 2012 Share Posted January 30, 2012 I got new tyres for the rear of the Viva. I think fairly decent quality Hankooks (Ventus V2 concepts) in 185/60 13. As soon as I left the tyre shop and headed back to city centre along bypass at 100kph the car felt really unstable with the rear end shifting about sideways as if it was tramlining badly, following evrey ridge on the road or like as if there were bloody strong side winds. A couple of people have said that its the waxes and silicone on the tread that needs to get worn off and another told me its the little moulding spikes. I've done about maybe 200 kms in car now and the spikes are now little stumps. The car still feels 'drifty' like as if the rear suspension is all soft. I seem to remember the only other time I have ever bought new tyres years back, some Yokohama A510's? for my old supercharged mr2 and they felt shit until the tread was half worn down and then they were great. They only lasted 10,000 kms of spirited driving on the back though. Is this all usual for new tyres? - are they always shit for a few thousand k's? I'm gonna check all my suspension bolts are tight tomorrow but the car was fine until I had bought the new tyres so I'm pretty damn sure its them. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted January 30, 2012 Share Posted January 30, 2012 DOASKID! Nah but really - check tyre pressures New tyres can make a millions of difference to how a car feels.. Try swapping tyres front to rear and see if it makes any difference/the symptoms shift. Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted January 30, 2012 Share Posted January 30, 2012 I had a similar thing when I finally bought a new set of tyres for my RX-7 (in blenheim too actually!), They felt worse to drive on than the rooted second hand tyres I'd been using, for a couple of weeks then they settled down. No idea what caused it though, maybe they needed to settle on the rim or something equally bizarre. They were some sort of decent Goodyear too, so shouldnt have been a quality thing. Quote Link to comment Share on other sites More sharing options...
kpr Posted January 30, 2012 Share Posted January 30, 2012 definitely the tyres. depends on car how bad it feels though. my starlet walks around all over the place on new tyres, and as you say once they wear down a bit its fine. i put some of it down to the triangulated 4 link setup they run. sloppy rear plus sloppy tyres = extra sloppy... so worth looking at whats going on back there. same tyres on the trueno is way less noticeable. but can still fell it found that the front alignment can make it feel worse as well. Quote Link to comment Share on other sites More sharing options...
DavidTheCreator Posted January 30, 2012 Share Posted January 30, 2012 check the back wheel nuts are tight Quote Link to comment Share on other sites More sharing options...
JoKer Posted January 30, 2012 Share Posted January 30, 2012 directional's? on the right side? Quote Link to comment Share on other sites More sharing options...
10Speed Posted January 30, 2012 Share Posted January 30, 2012 I have had the same problem with new rears on the 350z, so bad it even sometimes trips traction control (when it shouldn't). Then a couple of hundred km later it's all good Quote Link to comment Share on other sites More sharing options...
H05TYL Posted January 30, 2012 Share Posted January 30, 2012 Mould release agent soaked into the outer layer of the tyre perhaps? Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted January 30, 2012 Author Share Posted January 30, 2012 Cheers aircooled but my nuts should be fine. I'll double check them just in case. Kpr- the Viva uses a similar 4 link setup with triangulated top links. The bushes are soft so this might compound the effect. A mate in Scotland with a modded HB Viva had neatly fitted a Panhard rod and said it makes a big difference to stop the sideways movement. I'll give the tyres more time to get better and double check all bolts, nuts, bushes etc. The tyre pressure they put in was about roughly 33psi. I wonder if thats too high and at speed the tyres are getting a rounded profile? They are crashy when hitting bumps. I used to run 28 I think. Will try a drop in pressure. Quote Link to comment Share on other sites More sharing options...
keltik Posted January 30, 2012 Share Posted January 30, 2012 Yeah when i stuffed new tires on the wagon last, the first passing lane i came to - gave it a bootful and it was shuffling and squirming all over the place. New tires have some kinda wax on them to prevent them perishing on the shelf - takes a while for that to scrub off was the explanation i got. Plus with new tall tread blocks - youll get a much different feel as the treads distort under power or stress a lot more than a smaller/worn block would. Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted January 30, 2012 Author Share Posted January 30, 2012 moral of story.. Buy secondhand tyres. but i struggle to find this size. I shall report back when they start to feel better. Quote Link to comment Share on other sites More sharing options...
Phil180b Posted January 31, 2012 Share Posted January 31, 2012 Are the wheels balanced? Check you receipt and see if the balanced them after putting new tyres on Quote Link to comment Share on other sites More sharing options...
CUL8R Posted January 31, 2012 Share Posted January 31, 2012 Alex, they're directionals yea? Theres your tramlining problem, will lessen with a matched set... They always want to wander and follow the road. I'd be running 36psi in there.. Should've come to me Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted January 31, 2012 Author Share Posted January 31, 2012 Hiya Chris. Yeah I would have seen you but your all the way down there and I'm all the way up here. I got them for 125 each fitted and balanced as fella who works there owns a 12A powered HA Viva. I think thats an OK price ? Yeah they were balanced and came up good. I'll top the pressures up and try that. Yeah they are directional and pointing the right way. Still have the little knobs to wear off so more skids then..... Quote Link to comment Share on other sites More sharing options...
ProZac Posted February 3, 2012 Share Posted February 3, 2012 Video of skid or it didnt happen. Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted February 4, 2012 Author Share Posted February 4, 2012 I might fake it with some smoke from a little fire and dubbed over engine noise. I am an old lady driver... Quote Link to comment Share on other sites More sharing options...
shizzl Posted February 4, 2012 Share Posted February 4, 2012 ive had a similar experiance but on the front of a fwd civic wagon.. it didnt end too well...lost traction mid corner in the wet= having lunch with a culvert.. tyre shop paid for a new tyre cos it got ripped open..no damage to the car luckily.. but since then ive never got new tyres.always gone used.... Quote Link to comment Share on other sites More sharing options...
sholdowa Posted February 4, 2012 Share Posted February 4, 2012 Chris, has the design of tyres changed since the time 185/60x13 was a real sporty tyre? We used to run 28-30psi then... Quote Link to comment Share on other sites More sharing options...
shizzl Posted February 4, 2012 Share Posted February 4, 2012 185s?? yeah that was wide back in the day, i was rocking 155r 13s...then got some watanabes with 185/60s,thought theyr were the shit.. times have changed heaps...i even remember when 17s became the biggest rim,and were expensive... Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted February 5, 2012 Author Share Posted February 5, 2012 Yeah I'm sure 36 psi seems high too but I'll give it a go. Quote Link to comment Share on other sites More sharing options...
