flyingbrick Posted April 1, 2012 Share Posted April 1, 2012 if you can't tell by driving the car, lingling... does it really matter? Quote Link to comment Share on other sites More sharing options...
LingLing Posted April 1, 2012 Author Share Posted April 1, 2012 how can you tell then? need more photos? yes it does matter. Quote Link to comment Share on other sites More sharing options...
danger Posted April 1, 2012 Share Posted April 1, 2012 If you're not gonna bother with a new gasket atleast use a good quality RTV sealant. Why does it matter? Quote Link to comment Share on other sites More sharing options...
LingLing Posted April 1, 2012 Author Share Posted April 1, 2012 I have toyota new gasket. yes it does matter when I am on the track. Can you guys not tell? Quote Link to comment Share on other sites More sharing options...
danger Posted April 1, 2012 Share Posted April 1, 2012 No, I cant tell. Sorry Lingling. I have failed you. Quote Link to comment Share on other sites More sharing options...
LingLing Posted April 1, 2012 Author Share Posted April 1, 2012 I understand that 1 way does acceleration, where two way does acceleration and deceleration. Ok, danger, no worries. thanks anyway Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted April 1, 2012 Share Posted April 1, 2012 pffft, danger, no x-ray vision? loser! Quote Link to comment Share on other sites More sharing options...
Cullen Posted April 1, 2012 Share Posted April 1, 2012 *facepalm* Quote Link to comment Share on other sites More sharing options...
LingLing Posted April 1, 2012 Author Share Posted April 1, 2012 Please, only technical related post here please, i.e. No spam thank you. Quote Link to comment Share on other sites More sharing options...
ryanfels Posted April 1, 2012 Share Posted April 1, 2012 People on the Hachi facebook page will more likely be able to tell you over people here Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted April 1, 2012 Share Posted April 1, 2012 If its a TRD one, then it could be either 1.5 or 2 way, depending on how its been setup. I have some sort of aftermarket T series LSD, but it has no identifying marks on it at all. Quote Link to comment Share on other sites More sharing options...
LingLing Posted April 1, 2012 Author Share Posted April 1, 2012 ryan I have done that. also toyspeed people told me it's surely trd, but again, wouldn't know 1,1.5 or 2 way til taking the actual diff out Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted April 1, 2012 Share Posted April 1, 2012 take it for a thrash and then tell us if its 1, 1.5 or 2 way. If you can't tell then it DOESN'T MATTER! Anyway. Its got so much rust than it'll probably not make it to the next track day. Quote Link to comment Share on other sites More sharing options...
Bistro Posted April 2, 2012 Share Posted April 2, 2012 Please, only technical related post here please, i.e. No spam thank you. LOL Quote Link to comment Share on other sites More sharing options...
Rookie Posted April 2, 2012 Share Posted April 2, 2012 Out of the 11ty photos you took, not one of them shows the area of the head that would let you identify what sort of LSD it is. Take a photo of the ramps and then we will tell you. Quote Link to comment Share on other sites More sharing options...
LingLing Posted April 2, 2012 Author Share Posted April 2, 2012 yeh, well, ok, will let someone with experience drive it then we will know I guess. Quote Link to comment Share on other sites More sharing options...
LingLing Posted April 3, 2012 Author Share Posted April 3, 2012 Ok, bit screw up today. I have replaced the exhaust system for the panda today and it couldn't start. basically didn't touch anything else, except the taking the distributor off and put it back on again. only touched two bolts that holding the distributor to the engine. all the wiring is untouched. also, the exhaust temperature sensor is also swapped the wiring on the sensor is bit doggy, but this wouldn't be the problem right?? So the problem is I can turn the car on, start cranking, start motor is good, The Exhaust is actually farting quite a bit, but just can't start. Would the mega squirt ecu need read good exhaust temperature sensor? or Would it be the exhaust slightly leaking at the extractor, because I don't have all the bolts. or Did I screw up the timing? Quote Link to comment Share on other sites More sharing options...
durty Posted April 3, 2012 Share Posted April 3, 2012 distributor on the right way? not bolted back on straight? Quote Link to comment Share on other sites More sharing options...
LingLing Posted April 3, 2012 Author Share Posted April 3, 2012 right way? err, does it have to be exact same spot as before??? because the distributor have two screws that can be adjusted up and down? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted April 3, 2012 Share Posted April 3, 2012 Sounds like you have put the timing out. Are these dizzys on a gear or a dog drive? Quote Link to comment Share on other sites More sharing options...
