dave123456789 Posted March 24, 2012 Share Posted March 24, 2012 I got a rebuilt shimmed up to fuck 2way trd lsd out of japan for 700 landed in nz. prefacelift axle size. consider this as another option. Quote Link to comment Share on other sites More sharing options...
LingLing Posted March 31, 2012 Author Share Posted March 31, 2012 Right slightly screwed up today. All the input will be appreciated. have taken the rear end off. Main problem: r I can't take the diff head off, have taken off the bolts off at the ring seal, the head is actually loosened up. There is a 24mm nut at the front which connects to the drive shaft. Do I need to take that off? also, How do I not wasting any time to trying to praise all the linkage out and in? is there any good order? thank you Quote Link to comment Share on other sites More sharing options...
danger Posted March 31, 2012 Share Posted March 31, 2012 ... Have you removed the axles?.... Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 31, 2012 Share Posted March 31, 2012 Taken the axles out? Edit: Beaten Quote Link to comment Share on other sites More sharing options...
LingLing Posted March 31, 2012 Author Share Posted March 31, 2012 no, I have not. Dam, That's going to be tricky, because everything is free movement at the moment. So What should I do exactly? Quote Link to comment Share on other sites More sharing options...
danger Posted March 31, 2012 Share Posted March 31, 2012 It wont be tricky. remove rear calipers, remove bolts behind discs, possibly bolt wheel back on and pull/kick till comes out. Keep everything clean. Quote Link to comment Share on other sites More sharing options...
danger Posted March 31, 2012 Share Posted March 31, 2012 If in doubt. Google it. Quote Link to comment Share on other sites More sharing options...
LingLing Posted March 31, 2012 Author Share Posted March 31, 2012 Ok cheers. So I don't have to do anything to the 24 mm nut at front of the diff head where connects to the drive shaft? Quote Link to comment Share on other sites More sharing options...
kpr Posted March 31, 2012 Share Posted March 31, 2012 no don't touch that! Quote Link to comment Share on other sites More sharing options...
danger Posted March 31, 2012 Share Posted March 31, 2012 I'm not even sure what you're trying to achieve with all this and cbf reading but if you do decide to undo it, first mark on both the nut and pinion bolt where they line up so you can retighten it to that position afterwards. Quote Link to comment Share on other sites More sharing options...
Testament Posted March 31, 2012 Share Posted March 31, 2012 oh man sorry dude have you got a manual for the ae86. surely haynes or even factory manuals aren't too hard to get/you might even find them online if you are lucky but yeah as people are refering - the axles go into the splines in the diff head/carrier so you have to withdraw them (take the axles out) before you can pull the diff head out the front. you dont want to touch the pinion nut though. I suggest you find the manuals as above/ trawl the net and read up on how diffs go together Quote Link to comment Share on other sites More sharing options...
danger Posted March 31, 2012 Share Posted March 31, 2012 / No don't touch that! Quote Link to comment Share on other sites More sharing options...
LingLing Posted March 31, 2012 Author Share Posted March 31, 2012 The problem for me is, the diff Leaks oil, So I need to replace the Ring Gasket and the Pinion Seal. Quote Link to comment Share on other sites More sharing options...
danger Posted March 31, 2012 Share Posted March 31, 2012 Take the diff head to a mechanic ling ling. unless you like your diffs knocky Quote Link to comment Share on other sites More sharing options...
LingLing Posted March 31, 2012 Author Share Posted March 31, 2012 yeh, just got off the phone from Cam. Yeh, Probably it's good idea to get a mechanic to do it as Pinion seal is nightmare to replace. Quote Link to comment Share on other sites More sharing options...
LingLing Posted April 1, 2012 Author Share Posted April 1, 2012 Ok, Here is the update: The head is out, looks all pretty good apart from there is/was NO SEAL at the ring part. NO wonder it leaked oil!! Questions: Is this 1,1.5,or 2 way diff? do you see any problems in the photos? Should I redo the pinion seal? I don't know it leaked or not. Does it leak often from there? here is some photos: Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted April 1, 2012 Share Posted April 1, 2012 just wham it back on with some liquid gasket round the flange there then put axles in, fill with oil.. then enjoy the car/ go do a burnout somewhere. Quote Link to comment Share on other sites More sharing options...
danger Posted April 1, 2012 Share Posted April 1, 2012 Yep. Its definitely a diff head. Quote Link to comment Share on other sites More sharing options...
LingLing Posted April 1, 2012 Author Share Posted April 1, 2012 OK, what is the LSD ? 1,1.5, or 2 way??? Quote Link to comment Share on other sites More sharing options...
danger Posted April 1, 2012 Share Posted April 1, 2012 What option did you select on gran turismo? / I cant tell but it looks like it maybe has an LSD clutch pack in it Quote Link to comment Share on other sites More sharing options...
