Dustys 89 Hairdressermobile (mx5)
Dusty
  • Replies 185
I was a bit of a dick last time i got it certed, I called him anyway today and found out i can tube front it, I need to get the hobby car manual though. I've emailed but ill go see if the library has one in the mean time.
I checked out the diff, backlash on it was good and the contact isnt to bad so wont need to rebuild it or anything which is good.
20130108_171712 by Dustybike, on Flickr
20130108_171702 by Dustybike, on Flickr
So i dummy mounted the engine and trans, it was on a terrible angle trying to leave room for the 80mm sump, it seems other people that used the s6 gearbox dropped the subframe about a inch.
Obviously im not keen on monster truck status
I dropped the engine to 50mm and cut out far more transmission tunnel than i would have liked but it sits pretty level now
20130209_172715 by Dustybike, on Flickr
Also cut off the front.. 12.6kgs of weight saving though
Moved the shifter back 40mm from stock, I prefer it closer and it should let me sit the steering rack just in front of the engine about 60mm higher than stock.
The subframe is going to take a bit of modding though.
20130209_110043 by Dustybike, on Flickr
Iv made some actual progress this weekend, I brought a welder a 200a ac/dc tig / plasma from the tool shed and finally got all setup. I also brought a nb front (bonnet, fenders, lights, bumper and smash panel) from mx5 mart but hes given me a nb2 bumper so it doesnt fit at all. the rest is nb1 stuff just because i prefer the look. Also got a pair of window regulators because i havent had working windows in so long and a dash surround because i havent had that either.. anywhore. pics:
my very first tig weld
20130223_104413 by Dustybike, on Flickr
20130223_174258 by Dustybike, on Flickr
20130224_105519 by Dustybike, on Flickr
20130224_153029 by Dustybike, on Flickr
20130224_153022 by Dustybike, on Flickr
panel steel with a tig is a shit time but its getting there
this is the insparation for whats going on there, i just need panel steel to finish it because i munted the old fender -.-
images by Dustybike, on Flickr
Guest Dusty
So, the bumper i got from mx5mart is nb1 just its that deformed it didnt near fit up so i got a brand spanker from japan
20130322_102152 by Dustybike, on Flickr
20130322_141245 by Dustybike, on Flickr
Now the bonnet fits terribly, ohwell. This OS Giken clutch came up on trademe and i couldnt resist
20130323_095944 by Dustybike, on Flickr
20130323_100441 by Dustybike, on Flickr
20130323_100542 by Dustybike, on Flickr
5.5kg flywheel should be nice and revvy. the clutch plates are worn out though, down to about 3.1mm each and the release bearing is worn as well, but hay it was cheap. ish.
Guest punkoutnz
Glad to hear another positive story from mx5mart... My "mint condition" front lip that needed plastic welding just to get on the car cos all the mounting points had been torn off. Paid $150 for the privilege. Just gave up dealing with him.
  • 3 months later...
So i lost motivation for this for a while. I missed having something fun to drive so i sold my stagea runaboat and brought another mx5.
20130525_101440 by Dustybike, on Flickr
Its higher than that now because i got green stickered about a week after lowering it and the fines havent really stopped since. Has my teins and wheels on it, up side is i have a better hard top now.
Anyway I did something to the blue one this weekend.
Trans tunnel made from 2 mm plate, Comes up 40mm around the shifter.
Ill weld it in next week I just need to dremel around the shifter hole and cut the tunnel out more before i do.
20130706_160927 by Dustybike, on Flickr
20130706_150347 by Dustybike, on Flickr
20130706_150338 by Dustybike, on Flickr
And did the front fenders. Making them aero wasnt working how i wanted. The bonnet still doesnt line up properly but its closer with the new bumper.
20130707_143613 by Dustybike, on Flickr
20130707_143628 by Dustybike, on Flickr
A bit of progress.
ported the oil pump, mainly the inlet, ill make the outlet better once the line has been drilled out.
20130715_180550 by Dustybike, on Flickr
20130715_180604 by Dustybike, on Flickr
20130715_183233 by Dustybike, on Flickr
removed the balls and springs from the oil squirters on the eccentric shaft.  bit of jb weld to hold them back in.
20130718_184754 by Dustybike, on Flickr
20130718_184809 by Dustybike, on Flickr
20130718_185611 by Dustybike, on Flickr
Have been practicing/testing exhaust ports on a spare housing.
Opens about 5mm sooner and closes close to stock. also 5mm wider on each side so i can maintain a reletively smooth flow with the exhaust sleeves removed.
20130718_191054 by Dustybike, on Flickr
20130718_191146 by Dustybike, on Flickr
20130718_191537 by Dustybike, on Flickr
Also brought this thing. holset hx50
20130717_191733 by Dustybike, on Flickr
