Dustys 89 Hairdressermobile (mx5)
Dusty
  • Replies 185
So lately
got a new bash plate, 8mm this time good luck cateyes
New bash plate by Dustybike, on Flickr
Old engine seemed allright apart from this pitting and shit? this is #1 was the worst of them all.
This from knocking?
Fucked engine #1 by Dustybike, on Flickr
#1 conrod welded to the crank
Fucked engine experimental welding by Dustybike, on Flickr
stripped the engine bay to repaint it while i was waiting on the new engine to arrive. There was a little rust but nothing to bad. untill
Rust! by Dustybike, on Flickr
runs right to the top and forward a bit. not sure how far into the frame rails it goes but it goes lower. its the exact same on both sides.
New engine arrived today so checked it out.
"Previous owner informed me it had recent port & polish, balanced crankshaft, GTR pistons."
also paid extra for a clutch n flywheel that was suposibly all good and was ment to come with gtr ecu & loom and fuel rail.
in reality i got a gtx long block with fucked thrust bearings and intake mani sitting beside it. awesome.
Now to try and get some money back.
I must say if anyone is considering doing the same swap dont unless you have a built bpd and a gearbox to handle it.
This if far to much effort for 250-300 hp
  • 3 months later...
ill do a really sexy swap and overhaul in a couple of years
So its been a couple of years.
I brought some pineapple racing large street port templates
20120619_172438 by Dustybike, on Flickr
20120619_172834 by Dustybike, on Flickr
20120619_184303 by Dustybike, on Flickr
Ports were ok. I tidied up the template a little for the 2nd one.
20120621_171845 by Dustybike, on Flickr
I had been looking at rice racings ports and wanted bigger.
20120717_174731 by Dustybike, on Flickr
I only really went up on the outside.
If i were to do it again i wouldn't port in so much down the bottom of the port and maby not so low.
So i modified the template to suit and did the second primary.
20120717_175039 by Dustybike, on Flickr
20120717_183247 by Dustybike, on Flickr
I kept it in a little on the bottom edge but not much as i had to match the other port.
The line crossing across the bottom left of the port is about the edge of the rotor at the most open point.
20120717_183229 by Dustybike, on Flickr
20120719_181916 by Dustybike, on Flickr
20120719_181415 by Dustybike, on Flickr
I ported one of the primaries matching the top of the secondary port and modifying the bottom right a bit to blend the port.
I was pretty much blind grinding the lower part as i couldn't feel how thick the wall was.
  • 4 months later...
Brought a nice diff
20121122_125037 by Dustybike, on Flickr
20121122_125017 by Dustybike, on Flickr
fd3s diff with a carbonetics 2 way. apparently they're quite nice and quieter than kazz. how i will make it fit is still a mystery
20121123_182718 by Dustybike, on Flickr
can anyone explain this to me? the front rotor is grooved all over but the rear is smooth. Iv searched but couldn't find any info on it.
Brought a nice diff
http://www.rx7club.com/2nd-generation-specific-1986-1992-17/uhhh-trippy-ass-rotors-s4-tii-check-em-out-993537/
I am VERY much liking the direction this is taking
Thanks, hopefully it will turn out well.
cheers! so just machine marks and nothing to stress about? Hopefully it doesn't cause a heat difference between them.
I'm still trying to decide what to do body wise, I would like to tube frame the front and maby rear but I don't know if i can and put it on the road. I emailed for a hobby car technical manual but haven't had a reply.
Can anyone recommend a cert guy in the wellington or palmy north area? I went to julien cheer for the first cert and would prefer to not go back haha.
Pic of inside the front box section, you can see where its been welded right at the back :/
20121219_211828 by Dustybike, on Flickr
and how it sits at the moment... Yeahhh..
20121219_212531 by Dustybike, on Flickr
