Dusty Posted September 21, 2010 Author Share Posted September 21, 2010 am now proud to say. i am to low to get a wof at vtnz. cant fit me over the pit rails also went for wof. failed on engine mount with a crack right through it and left hand chassis rail has a tear in it and found out my diff housing arm thing had cracked off at some point and was welded back together Quote Link to comment Share on other sites More sharing options...
Dusty Posted October 26, 2010 Author Share Posted October 26, 2010 dun fuck all lately have been waiting on the rwd sump to arrive. almost finished the megasquirt. sump looks like it will fit fine just need to get the old baffle out. will need to mod the 1.6 engine mounts which hopefully wont be to hard. managed to get a wof after fixing the crack in the chassis rails and the split engine mount. bumpy drive up to Auckland for the weekend. think i might have seen a couple of you oldschoolers on the way. Quote Link to comment Share on other sites More sharing options...
EURON8 Posted October 26, 2010 Share Posted October 26, 2010 I saw ya somewhere between Auckland and Taupo on monday. Looked good Quote Link to comment Share on other sites More sharing options...
Dusty Posted November 18, 2010 Author Share Posted November 18, 2010 I saw ya somewhere between Auckland and Taupo on monday.Looked good Cheers man. given up on turbo getting done this year. to little cash. exhaust mani when half done. fuck i hate fileing. Got a rwd sump from a na1.8 and tapped oil drain hole and blocked off the oil level stick hole. its all bolted in on the engine now. today: finished exhaust valve actually works really well iv got it blocking the 2.5 inch pipe only slightly louder than the blockoff plate when closed. ill put a vid up at some point. inside of exhaust with valve closed. looks like shit :/ also painted the window frame. Quote Link to comment Share on other sites More sharing options...
Dusty Posted November 26, 2010 Author Share Posted November 26, 2010 exhaust mani progress. ill weld it up monday. megasquirted the mx. went reasonably smoothly apart from having spark wires crossed. fixed that. started right away. no longer a hot air intake Quote Link to comment Share on other sites More sharing options...
Testament Posted November 28, 2010 Share Posted November 28, 2010 sweet progress man, did you get an MS that plugged straight into the MX loom? Quote Link to comment Share on other sites More sharing options...
Dusty Posted November 29, 2010 Author Share Posted November 29, 2010 sweet progress man, did you get an MS that plugged straight into the MX loom? nah just standard and cut into the loom. the quiet side exhaust snapped off at the 2.5" so welded that back on today. set the timing on the ms correctly (was 8degrees to retarded) runs a little better now. going to make a new spark map and should run sweet. started welding the exhaust mani together and its coming along nicely ill pop a pick up tomorrow. Quote Link to comment Share on other sites More sharing options...
Dusty Posted November 30, 2010 Author Share Posted November 30, 2010 Still tuning the ms but its getting there. exhaust mani semi welded. looks horrid. welding is 60% good. need to file down the inside but i cant be assed so ill do a halfassed job of it tommrow. also the td04 turbo i brought is fucked with bad shaft play and cracked exhaust housing so ill have to get a td05 at some point. Quote Link to comment Share on other sites More sharing options...
Dusty Posted December 5, 2010 Author Share Posted December 5, 2010 fuck. Quote Link to comment Share on other sites More sharing options...
NicT Posted December 5, 2010 Share Posted December 5, 2010 Cut down until u get a parrallel face on the wastegate pipe, then get a steam pipe tight radius 90 and face it off on an angle so the direction it points in is in line with where the centre of the dump pipe will be. I tried to draw it in paint but that ended up being a bit of a fail haha. Quote Link to comment Share on other sites More sharing options...
Alistair Posted December 5, 2010 Share Posted December 5, 2010 Hard to see but if it was flipped upside down to run top mount it looks like the angle you have the turbo flange on would allow it to clear and have the wastegate underneath? /maybe nah? Quote Link to comment Share on other sites More sharing options...
Testament Posted December 5, 2010 Share Posted December 5, 2010 ah shite. I'm going to sound like a dick but did you tack it up to check fitment first? also what about stuff in the car, engine mounts, inner guards etc.? Quote Link to comment Share on other sites More sharing options...
Dusty Posted December 6, 2010 Author Share Posted December 6, 2010 ah shite. I'm going to sound like a dick but did you tack it up to check fitment first? also what about stuff in the car, engine mounts, inner guards etc.? nah never checked it and hence welded it on upside down. thought it was wide bolts at top thin at bottom. always the other way around. well have to cut it off grind it back and reweld it the right way. fuck. ohwell. Quote Link to comment Share on other sites More sharing options...
Testament Posted December 7, 2010 Share Posted December 7, 2010 Yeah, nothing 1mm cutoff wheels and a few meters of mig wire cant fix. Quote Link to comment Share on other sites More sharing options...
Simon Posted December 7, 2010 Share Posted December 7, 2010 I'm very interested in the exhaust valve. I have been contemplating that ever since I found out what mufflers did. Whats the motor that you use? I guess an old throttle body with a circular plate cut to fit the ID of the pipe? I thought about just doing the flap part of of box section and then doing something like this for the V8. Although the different designs are endless you get the idea. Quote Link to comment Share on other sites More sharing options...
Dusty Posted December 7, 2010 Author Share Posted December 7, 2010 I'm very interested in the exhaust valve.I have been contemplating that ever since I found out what mufflers did. Whats the motor that you use? I guess an old throttle body with a circular plate cut to fit the ID of the pipe? I thought about just doing the flap part of of box section and then doing something like this for the V8. Although the different designs are endless you get the idea. I used a electric window winder motor. the flap was a 2mm circle i ground to sort of fit and a piece of tube with a slot cut into it to hold the flap. It works but it doesn't sound nice when closed as it does a shitty rattle. you can buy pre fabbed "exhaust cutouts" like this http://www.trademe.co.nz/Trade-Me-Motor ... 343199.htm but they're stupidly expensive. if you make one just make sure there's no play in it so it wont rattle. Quote Link to comment Share on other sites More sharing options...
Truenotch Posted December 7, 2010 Share Posted December 7, 2010 Simon - raid a throttle body for the valve. Use the spring as a return and do the window winder thing for actuator... Would be easy. Quote Link to comment Share on other sites More sharing options...
Simon Posted December 7, 2010 Share Posted December 7, 2010 I think I'll just make it sound sweet and be legal. And take the pipes off for track haha. Will be going under the diff anyway so wont be hard to drop the whole thing and save a few kgs. Sorry for spam. Quote Link to comment Share on other sites More sharing options...
Dusty Posted February 19, 2011 Author Share Posted February 19, 2011 well. havent dons squat to the mx. replaced RHR knuckle and brake caliper due to buckledness. remade the exhaust because of the powlece. and not much will happen any time soon. paying off tools then saving for a welder. also brought some nicely shaped rust. Quote Link to comment Share on other sites More sharing options...
Dusty Posted September 27, 2011 Author Share Posted September 27, 2011 Quote Link to comment Share on other sites More sharing options...
