K-Trips 1982 Holden Commodore VH Discussion
KKtrips
That little box that was sitting with the engine when on the trailer.. What is it? Looked quite small.
I vote manual box for your car because it's still actually quite a small car compared to new heaps of shit and should be well fun with the 1uz
  • Replies 1.4k
G52 - and yep I'm going manual for sure.
I figured out how I can easily adapt a hydraulic clutch master to my pedal box - as can be seen by the photos of a VH and VL pedal box I put on the build thread - they are identical except for the VL one has a hole for the master cylinder to locate in.. I just need to drill the hole in the firewall and pedal box then a hole in the pedal itself for the pushrod clevis to go into.
Going to use a concentric bearing from a Mondeo or similar.
VH pedal box - Cable
VL pedal box - Hydraulic
  • 4 months later...
chevs are a bit of a prick to get in a commode. starter motor requires same real estate as steering rack as well as sump/oil pump clearance issues. you can get a kit to put an older smallblock chev in one which requires the crossmember to be shifted down which cocks up the steering arm angles if its lowered at all
