RUNAMUCK Posted July 6, 2009 Share Posted July 6, 2009 I my pile of spares, I have a diff from a crown like yowzer's one. Is there an LSD head available for these bad boys? Quote Link to comment Share on other sites More sharing options...
Crownin_Round Posted July 6, 2009 Share Posted July 6, 2009 Yeah either modify an IRS lsd nugget to suit or very rarely estima lsd's... Or aftermarket but you would have to scour e-bay or yahoo.jp... Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted July 6, 2009 Author Share Posted July 6, 2009 what flavour of IRS would I need to hunt out? Toyota stuff is totally foreign to me. Also, what kind of lsd are they? anyone got any links to what mods gotta be done? Quote Link to comment Share on other sites More sharing options...
Yowzer Posted July 6, 2009 Share Posted July 6, 2009 I too am interested in this. Quote Link to comment Share on other sites More sharing options...
sheepers Posted July 6, 2009 Share Posted July 6, 2009 anything F series. MA61 is the most popular. but they are not common, that "def rattle" was selling one a while back that was fucked, he still wanted moonbeams for it. they are around, you just have to keep your eye out for them. i guess youd pay 400-500 for a good one?? spence, what do you reckon? Quote Link to comment Share on other sites More sharing options...
Crownin_Round Posted July 6, 2009 Share Posted July 6, 2009 Not quite Spencer but that could be a starting price, Ive moved one for $300 before but it wasn't flash and it was clutch type. The easier option, as long as you don't mind not having a hardcore LSD is Estima "F series" live axle diff's, usually the LSD ones are disc break too! Look for codes on the engine plaque ending in 3's or 5's ie F283 or F285, 3 denotes 2 pinion LSD and 5 is 4 pinion LSD.. Quote Link to comment Share on other sites More sharing options...
Spencer Posted July 6, 2009 Share Posted July 6, 2009 If your not wanting it for D1's just traction then go a torsen from an altezza there's no modifications and they only go for ~$300ish. No mods needed, dropped one straight into the soarer housing, at worst in a live housing you may have different bearings. Factory F clutch LSD's are stink you can shim them up and they will hook 2 but when cornering they unpredictably let one go, no ramps. If you want to D1 you need a TRD, Cusco etc centre proper clutch LSD all still available new Quote Link to comment Share on other sites More sharing options...
Ke36 Posted July 6, 2009 Share Posted July 6, 2009 If your not wanting it for D1's just traction then go a torsen from an altezza there's no modifications and they only go for ~$300ish. No mods needed, dropped one straight into the soarer housing, at worst in a live housing you may have different bearings. Factory F clutch LSD's are stink you can shim them up and they will hook 2 but when cornering they unpredictably let one go, no ramps. If you want to D1 you need a TRD, Cusco etc centre proper clutch LSD all still available new while were on a close subject can you buy good aftermarket lsds for a hliux diff? Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted July 6, 2009 Share Posted July 6, 2009 Lots of people seem to buy truetracs. There was a TRD lsd for one for sale out've a gx71 GT. Tama autos' was selling it though so they wanted ~$1200. Quote Link to comment Share on other sites More sharing options...
Yowzer Posted July 6, 2009 Share Posted July 6, 2009 Just stole this from the turbo ke35 auction Shortened Toyota F Series diff (from a Crown) with LSD internals from an independent rear end CelicaHigh ratio (4.3:1 ?) crownwheel fitted so flies through the gears Went with this setup instead of Hilux diff as the F series is a clutch pack LSD and already has disc brakes Quote Link to comment Share on other sites More sharing options...
Crownin_Round Posted July 6, 2009 Share Posted July 6, 2009 Lame at clutch pack, as above my MA61 LSD would always drop a wheel mid D1. The IRS LSD nugget is wider to accommodate the floating axle, so you have to modify it to suit for solid. Don't know exactly what that involves, some re-shimming, could ring the diff shop or somewhere that specializes in diff's in your area. Yep Christchurch.. don't get them to do the work though they are foooorking expensivo Quote Link to comment Share on other sites More sharing options...
Spencer Posted July 7, 2009 Share Posted July 7, 2009 ^ theres no re-shimming on a live F series it has adjustment. Think your confused only difference is the bearing sizes with some heads. this is marks (ae25 on here?) altezza head in a live F housing And yea yowzer ma61 etc clutch pack lsd's are lame just like lux G series ones. Tru tracs are a good solid unit if you want a torsen but will let one go doing skids, good for track work. Mine was awesome in the soarer. TRD still do G series LSD units new as do a few other aftermarket brands, guess its the only way to go if you only want a LSD for skids. For me the torsen unit is much nicer on the track traction wise Quote Link to comment Share on other sites More sharing options...
ryanfels Posted July 7, 2009 Share Posted July 7, 2009 Lots of people seem to buy truetracs.There was a TRD lsd for one for sale out've a gx71 GT. Tama autos' was selling it though so they wanted ~$1200. that was a G series 1 and he ended up selling the whole subframe and diff for about $900 in the end, was a sweet buy! Quote Link to comment Share on other sites More sharing options...
Spencer Posted July 7, 2009 Share Posted July 7, 2009 ^ yea not exactly common to find a G series rear end for a x7 chassis Quote Link to comment Share on other sites More sharing options...
ryanfels Posted July 7, 2009 Share Posted July 7, 2009 specialy with a TRD lsd already set up in it Quote Link to comment Share on other sites More sharing options...
Yowzer Posted July 7, 2009 Share Posted July 7, 2009 This is what ya need if ya want a diff for skids. Can't say I have a use for an LSD at this stage, car ain't a track weapon and I doubt it could ever pull a skid with its shitty auto box. Good to know for future reference though Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted July 7, 2009 Share Posted July 7, 2009 Lots of people seem to buy truetracs.There was a TRD lsd for one for sale out've a gx71 GT. Tama autos' was selling it though so they wanted ~$1200. that was a G series 1 and he ended up selling the whole subframe and diff for about $900 in the end, was a sweet buy! Yeah I know it was a G series, it was in reply to the post above mine I should've grabbed the rear end out've the GX71 GT I found a pick a part by the sounds of it Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted July 7, 2009 Author Share Posted July 7, 2009 What a mean thread I've started. I can't wait to read it when I sober up. Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted July 7, 2009 Share Posted July 7, 2009 while were on a close subject can you buy good aftermarket lsds for a hliux diff? theres a guy around that does escort stuff, he makes ramps for hilux diffs, send him your standard lsd and he'll replace the sping loaded center thinging with ramps, bout $600? prob more by now... Quote Link to comment Share on other sites More sharing options...
Roman Posted July 9, 2009 Share Posted July 9, 2009 Yeah I put an Altezza cusco 2 way in my F series live axle, fit up sweet! No modding required. And yeah, TRD G series LSD that Tama Autos was selling was fucking mega, worth every cent for who ever bought it IMO. That'd support some biiiiiig power going through it. Quote Link to comment Share on other sites More sharing options...
