d.p.n.s Posted November 18, 2009 Author Share Posted November 18, 2009 i understand what your saying mate but imo with what your doing i would be realy tempted to just 4 link it now. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 18, 2009 Share Posted November 18, 2009 These are some escort suspension setups I got photos of from the manfield meet just been Note in this picture how the mount between diff and tramp rod is quite far from the housing to give good leverage ... iv been told idealy i want to get the eyelet about 160mm away from the housing (probably wont be able to achieve this due to ride height) and the bar at a 16 degree angle away from the housing. The White Mk2 cossworth that was EXTREMELY quick with 300hp. Could a sway bar be an alternative for a panhard rod. Allan Man replica .... I think i will do my panhard rod the same as his .... Note the tube that travels across the back of the body providing support for were the rod mounts to the body (a difficult part to get a ridged mount too) and as a brace. And a lotus escort thats "Been raced since factory" Quote Link to comment Share on other sites More sharing options...
petemk1 Posted November 20, 2009 Share Posted November 20, 2009 are you gona space the front wheels out some how. the rear height with wheel and arch combo is mint. so want to do a bubble escort now. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 20, 2009 Share Posted November 20, 2009 Yeah legally i can space them 25mm i think i worked out so will do that... and try sink the flare in mabie even chop it down the centre to bring them in. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted November 20, 2009 Author Share Posted November 20, 2009 nice just a few qustions mate if you can help 1 how wide is your diff from disc to disc? 2 what size wheels are on it ? and what off set? 3 are you front coil over set up alloy? just sitting on a steel ring. cheers dan Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 20, 2009 Share Posted November 20, 2009 nice just a few qustions mate if you can help 1 how wide is your diff from disc to disc? 2 what size wheels are on it ? and what off set? 3 are you front coil over set up alloy? just sitting on a steel ring. cheers dan 1. 1460mm however that was lying under the car trying to measure it myself. I may have the diff out tonight so will update with accurate measurements latter on. 2. 8" wide with 0 offset 3. Yup alloy sitting on steel seat that Jason turned up for me. Just purchased oil cooler kit, now looking for oil catch tank and spacer kit. http://www.trademe.co.nz/Trade-Me-Motor ... 078179.htm http://www.trademe.co.nz/Browse/Listing ... =254311989 Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted November 20, 2009 Author Share Posted November 20, 2009 thanks for that mate im going to shorten my diff housing by 70mm that shout take it down to 1470 so that will be mint. and i was wanting to build a coilover front end and all ive seen is the alloy kits and for some reason never thought of sitting them on a steel ring and then grub screwing the lol. thanks again dan Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 20, 2009 Share Posted November 20, 2009 thanks for that mateim going to shorten my diff housing by 70mm that shout take it down to 1470 so that will be mint. and i was wanting to build a coilover front end and all ive seen is the alloy kits and for some reason never thought of sitting them on a steel ring and then grub screwing the lol. thanks again dan If you can make these work could be a cheap set of coilovers! don't know there diameter or anything. http://www.trademe.co.nz/Trade-Me-Motor ... 077450.htm Quote Link to comment Share on other sites More sharing options...
mikuni Posted November 20, 2009 Share Posted November 20, 2009 fan of this one Agreed. But in vibrant colours of your choice. Or, Mexico theme pinstripes but with something other than Mexico written there for non-replica/cheesiness Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 20, 2009 Share Posted November 20, 2009 Haha not a fan of vibrant colours prefer chream, black grey British green mellow colors etc exciting ha Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted November 20, 2009 Share Posted November 20, 2009 just cleaning out my inbox boe, remembered you were wanting these still want them? Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted November 20, 2009 Share Posted November 20, 2009 thanks for that mateim going to shorten my diff housing by 70mm that shout take it down to 1470 so that will be mint. and i was wanting to build a coilover front end and all ive seen is the alloy kits and for some reason never thought of sitting them on a steel ring and then grub screwing the lol. thanks again dan come grab this sway bar you can have a nosey at mine there steel weld on ones Quote Link to comment Share on other sites More sharing options...
karmagedon Posted November 21, 2009 Share Posted November 21, 2009 Why did you weld that strut bar in over the engine? No plan to take engine out again? Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 21, 2009 Share Posted November 21, 2009 On of the towers has a gap on the side so that i can remove bolts slide it across up and out Quote Link to comment Share on other sites More sharing options...
karmagedon Posted November 21, 2009 Share Posted November 21, 2009 ok, well pretty cool design then. Quote Link to comment Share on other sites More sharing options...
Gaz Posted November 21, 2009 Share Posted November 21, 2009 LOL exactly what I said when I saw pics. Would have been typical of Russel to do that too Turns out this one was thought out tho! Post some pics up of other end yo. Gaz Quote Link to comment Share on other sites More sharing options...
Honda Ass Dragger Posted November 21, 2009 Share Posted November 21, 2009 nice just a few qustions mate if you can help 1 how wide is your diff from disc to disc? 2 what size wheels are on it ? and what off set? 3 are you front coil over set up alloy? just sitting on a steel ring. cheers dan 1. 1460mm however that was lying under the car trying to measure it myself. I may have the diff out tonight so will update with accurate measurements latter on. 2. 8" wide with 0 offset 3. Yup alloy sitting on steel seat that Jason turned up for me. Just purchased oil cooler kit, now looking for oil catch tank and spacer kit. http://www.trademe.co.nz/Trade-Me-Motor ... 078179.htm http://www.trademe.co.nz/Browse/Listing ... =254311989 If its a early model hilux 1460 is correct Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted November 22, 2009 Share Posted November 22, 2009 hey man, re panhard rod... unless you run rose joints the end bolts (pivot axis) will have to be horrizontal and longways if you see what im saying. . . . . Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 22, 2009 Share Posted November 22, 2009 I was going to run the one at the diff vertical and the one to the body horixontal with a thread at one end ... will that be ok? / is that what your meaning? Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 22, 2009 Share Posted November 22, 2009 dow Quote Link to comment Share on other sites More sharing options...
