DangerousPerson Posted November 10, 2011 Share Posted November 10, 2011 Morrie in 114.3 would be mint. Quote Link to comment Share on other sites More sharing options...
tortron Posted November 10, 2011 Share Posted November 10, 2011 mine already is bruv Quote Link to comment Share on other sites More sharing options...
UTERUS Posted November 10, 2011 Share Posted November 10, 2011 Babe Quote Link to comment Share on other sites More sharing options...
tortron Posted November 10, 2011 Share Posted November 10, 2011 Totally am Quote Link to comment Share on other sites More sharing options...
tortron Posted November 10, 2011 Share Posted November 10, 2011 I dont have to look at me, so jokes on you Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 10, 2011 Share Posted November 10, 2011 I so want to put a Nandor Tanzcos (sp?) line in here but won't cos you most probably hear it eeeryday Quote Link to comment Share on other sites More sharing options...
tortron Posted November 10, 2011 Share Posted November 10, 2011 iv heard it all Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 10, 2011 Share Posted November 10, 2011 are you going yella under the hood or is that primer? Quote Link to comment Share on other sites More sharing options...
tortron Posted November 10, 2011 Share Posted November 10, 2011 its black now but i wish i had painted it yellow actually, that primer is a close match to what i covered the parcel tray in Quote Link to comment Share on other sites More sharing options...
tortron Posted November 10, 2011 Share Posted November 10, 2011 have since put another coat on/got all the bits i missed was a bit more dust in the shed than i had liked (outside was far better when i painted the rest of it) but whatever, its better than factory Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 10, 2011 Share Posted November 10, 2011 I wonder if you can buy the cloth wrapping that Lucas use to chuck on wiring looms - would make your engine bay look totally badass if you did.. Quote Link to comment Share on other sites More sharing options...
tortron Posted November 10, 2011 Share Posted November 10, 2011 ^ i think you can from vintage car parts specialists mine is crap and crumbling, so i had planned on soemthing like that The thought of using black nylon type braided hose had crossed my mind Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 10, 2011 Share Posted November 10, 2011 did you say get ROT808 to bend up some copper line for your wiring loom.... Quote Link to comment Share on other sites More sharing options...
tortron Posted November 10, 2011 Share Posted November 10, 2011 wow, that scares me, the electrics are dodgy already However, i do need some pipes made up for the water pump Quote Link to comment Share on other sites More sharing options...
tortron Posted November 10, 2011 Share Posted November 10, 2011 just so i remember Standard Flywheel weighs 7.85 KG/17.3 lbs Quote Link to comment Share on other sites More sharing options...
tortron Posted November 16, 2011 Share Posted November 16, 2011 Flywheel now weighs 5.55 kg discuss Quote Link to comment Share on other sites More sharing options...
tortron Posted June 24, 2012 Share Posted June 24, 2012 Broken images fixed Havnt made any progress since i put it in storage 6 months ago Things to do remove stuck flywheel bolt drop the sump - clean the crap that WILL be in it, also need to do this to get the flywheel off Fit Flywheel Replace all bottom gaskets Fit nice sump remove driveshaft - paint remove diff - paint lower rear get set of wheels widened replace front brake line - torn when removing put EVERYTHING back together - mainly engine bay stuff fancy covers for wiring Get new hoses so i can run my water pump Install carpet recover headliner, door cards strip, paint, straighten bumpers and that will be every single part of this car pulled off, rebuilt/replaced and put back together Quote Link to comment Share on other sites More sharing options...
kiwi808 Posted June 24, 2012 Share Posted June 24, 2012 Loving your Morris Minor! Quote Link to comment Share on other sites More sharing options...
governorsam Posted June 27, 2012 Share Posted June 27, 2012 Would the morrie fit on the back of you truck? Only 1 vehicle to store then Quote Link to comment Share on other sites More sharing options...
tortron Posted June 27, 2012 Share Posted June 27, 2012 have considered this it will, if i have a way of putting it on Quote Link to comment Share on other sites More sharing options...
