Adoom Posted May 7, 2017 Posted May 7, 2017 What ratio is the diff, I couldn't find it? Is it the standard ratio for an R32 GTR R200 LSD? Quote
sheepers Posted May 7, 2017 Posted May 7, 2017 no, it was 4.1 a per stock GTR but i changed it to 3.6. 1 Quote
Adoom Posted May 8, 2017 Posted May 8, 2017 2 hours ago, sheepers said: no, it was 4.1 a per stock GTR but i changed it to 3.6. How do you find that ratio for revs in 5th at 100kph? I plan on putting a 1UZ and W57 into my Triumph 2500. <-- I have all these bits already. With my 195/60/14" tires I worked out I'd need something like 3.3 to 3.5:1 to have 2600-2750rpm at 100kph. I'm exploring options for the rear end because the existing semi trailing arm setup is said to be craptastic. To put an S13(same as R32, I think) rear end in I'd have to narrow it about the same as you have. I'll drop the existing rear suspension some time and offer up an S13 subframe I have access to, to see if it's remotely feasible. I suspect the front upper arm mounts will require far too much hacking of the floor. Quote
sheepers Posted May 8, 2017 Posted May 8, 2017 3.6 works well with the R154, i would guess you'd want to go a bit lower if your going to run small tyres and a W57. keep in mind that the UZ is not a pushrod shithouse V8. they love to rev and sitting at 2800ish is no drama for them. in my limited experience with the underside of britcrap trumphs id say you will be biting off a VERY large chunk of work to get a nissan subframe to work. 1 Quote
Adoom Posted May 8, 2017 Posted May 8, 2017 1 hour ago, sheepers said: 3.6 works well with the R154, i would guess you'd want to go a bit lower if your going to run small tyres and a W57. keep in mind that the UZ is not a pushrod shithouse V8. they love to rev and sitting at 2800ish is no drama for them. in my limited experience with the underside of britcrap trumphs id say you will be biting off a VERY large chunk of work to get a nissan subframe to work. I was thinking more along the lines of not using a shit ton of fuel just cruising, rather than the engine's capacity to rev. Quote
locost_bryan Posted May 8, 2017 Posted May 8, 2017 2 hours ago, Adoom said: How do you find that ratio for revs in 5th at 100kph? I plan on putting a 1UZ and W57 into my Triumph 2500. <-- I have all these bits already. With my 195/60/14" tires I worked out I'd need something like 3.3 to 3.5:1 to have 2600-2750rpm at 100kph. I'm exploring options for the rear end because the existing semi trailing arm setup is said to be craptastic. To put an S13(same as R32, I think) rear end in I'd have to narrow it about the same as you have. I'll drop the existing rear suspension some time and offer up an S13 subframe I have access to, to see if it's remotely feasible. I suspect the front upper arm mounts will require far too much hacking of the floor. I thought the Nissans also had a semi-trailing arm rear with a reputation for snap oversteer (just like early 3- and 5-series BMWs)? A cheaper solution might be to improve the Triumph setup? Plenty of upgrade parts available for the Stag and TR sports cars (including kits to fit Nissan diff and CV joints), iirc they used the same rear end as the 2500 saloons. Quote
Adoom Posted May 8, 2017 Posted May 8, 2017 4 minutes ago, locost_bryan said: I thought the Nissans also had a semi-trailing arm rear with a reputation for snap oversteer (just like early 3- and 5-series BMWs)? A cheaper solution might be to improve the Triumph setup? Plenty of upgrade parts available for the Stag and TR sports cars (including kits to fit Nissan diff and CV joints), iirc they used the same rear end as the 2500 saloons. AFAIK early nissan stuff did, like S11, maybe S12, deffo 510. Improving the Triumph setup is still an option. I'm trying to find options to do away with the funny suspension angles the semi trailing arms do when they move. Moving the arm up causes increased negative camber and increased toe out. Reversed for moving down. Quote
locost_bryan Posted May 8, 2017 Posted May 8, 2017 This rear track control kit is supposed to cure that problem. http://www.monarch-stags.co.uk/productinfo.php?id=20 Quote
Adoom Posted May 8, 2017 Posted May 8, 2017 5 minutes ago, locost_bryan said: This rear track control kit is supposed to cure that problem. http://www.monarch-stags.co.uk/productinfo.php?id=20 I've seen that before, apparently you cannot use urethane bushes with that kit as it relies on the give in the soft rubber bushes to work. We might be getting a bit OT for sheepers discussion thread.... Quote
sheepers Posted June 4, 2019 Posted June 4, 2019 im fucked if i know. detonation? i really am stumped as to why two of the 8 are like that. 1 Quote
Truenotch Posted June 4, 2019 Posted June 4, 2019 Yeah, it’s weird alright. Are they nikasil bores or steel sleeves? Quote
sheepers Posted June 4, 2019 Posted June 4, 2019 the get bored so im guessing not nikasil. dont actually know for sure. Quote
Evan Posted June 5, 2019 Posted June 5, 2019 A man with silly hair in Hawaii bet you to it (skip to 5mins if the link doesn't go there automatically) 4 Quote
sheepers Posted June 5, 2019 Posted June 5, 2019 thats a gay little boys supercharger. not a manly cool and tuff supercharger like mine. 4 3 Quote
RUNAMUCK Posted June 5, 2019 Posted June 5, 2019 How much air are you going to force into it? What boost ratio is the efficiency island for this pump? Please run one bar plus. Any detonation is future sheepers problem Quote
sheepers Posted June 5, 2019 Posted June 5, 2019 1 bar. lol. its an Eaton M122 that will be running about 10psi, any more than that and its just making heat. 1 Quote
Popular Post cletus Posted June 6, 2019 Popular Post Posted June 6, 2019 4 hours ago, Yowzer said: Gonna whip some 3/4 race cams in too? Its Toyota, they are metric race cams. .750 race 15 1 3 Quote
