unclejake mk1
davidian
My understanding (which is probably wrong) there shoudlnt be any stress on it when the car is stationary. Under cornering both strut tops will go in the same direction...but then which strut has more force the inside or the outside...they cant be the same as then you wouldnt need a strut brace in the first place.
So in summary I dont know. :lol:
  • Replies 222
^ To add to the equation my car used to corner (when pushed hard and rightly or wrongly) on three wheels. I think that is now resolved but the stress on the outside front tyre is significantly more than the inside front tyre.
To my small brain that would indicate that the strut brace should operate in traction
The top of the strut on the outside wheel would be trying to pull away from the centre of the car?
I'm getting pissed. Should STFU
would it not dependo n the pivot point of the strut? ie:
wheel above pivot point would result in top of strut being pushed towards center
wheel below pivot point would result in top of strut being pushed out
so depends where abouts said pivot point is in relation to the center of your wheel?
i guess in this case, pivot point would = where it joins to the lower arm. so for instance, on my mx31, the hub is attached above where the strut joins the lower arm, there for top of strut under hard cornering would be pished in towards the middle
*edit*
ball joint at bottom would be pivot point. this is same set up as my mx31...
I need to think about that more Darling but as an initial response (whilst pist and not finking straight) the froce (traction) is always on the 'bottom' of the wheel as that is where the tyre meets the friction surface. That probably means that the strut top (MacPherson strut in this case) will be forced towards the outside of the car on the side of the car with the most sideways loading on the tyre (the outside front tyre in my case)/
Kisses.
yea, that does make more sense. i was only thinking as far as direct force applied to the hub. didnt take in to account that hub may have wheel attached and force (or froce as you put it :P) would be applied to the bottom of the wheel
stupid brain
ignore what i said, im not thinking straight. cars = pushed aside in aid of concentrating on finding moneys. no more contract work ftl
*edit*
I think that the lower control arm is the fulcrum in this scenario. Words with that many vowels are choice.
They are roll centre adjusters, basically they maintain the bottom arm geometry as a supposed means of controlling bump steer.
Now as I understand it, bump steer is caused by toe change as the wheel moves upwards under compression? So why not compensate by adjusting toe to what it should be anyway?
Yuh - that is why I liked the look of them. The centre of gravity can be lowered keeping the steering geometry more or less factory.
Some cars toe in on compression (bump) and some toe out. Your rear wheels will also change toe due to suspension deflection on hard corners.
Toe settings are a bit of a personal preference on a race car - but as a broad rule I like zero toe. Others prefer a little toe out to enhance to turn in but on a front heavy car like a Cortina it tends to promote understeer in my limited experience. I guess it all depends how much caster you are running too.
The way I steer into a corner will be slightly different than everyone else so what works best for me possibly will not be exactly perfect for others - but I am just an amature that TBH is only an average driver.
Setting toe to compensate for bumpsteer is not something I know about but I would think it would have a negative effect somewhere else.
yeah it doesnt hurt to say that this is very cool
UJ - the engine bay corner braces, is there anything on the other side of the firewall where they are welded on? some kind of plating or bracing perhaps? I'm tossing up between getting bars added to the rollcage in the 131 to tie in the front struts or to just do something like you have there. Do you know if theres any issues as far as MSNZ shit is concernded as far as putting chassis stiffening members like that if they are not part of the rollcage?
I think maybe this got lost? could you comment please UJ? :D
Sorry brother - I remember reading it but forgot to answer.
I do not have any additional plating on the cabin side of the firewall for the braces you mention. Those braces are really just a stronger copy of what the factory put into Mk1 Cortinas that came out of the UK or Australia (I have never been able to confirm which country but they have been present on at least one S/W I wrecked). My car has extra bracing underneath the front part of the braces you see (inside the wheel arch). It is roughly triangulated.
Is a 131 MacPherson strut?
The Cortina has had previous issues with stress cracks around the top strut mount - hence the extra effort it that region.
Lots of guys bring the rollcage forward to the strut tops. Having seen how well these cars handle I think it is a good idea if you have a shell that is prone to torsional flexing. AFAIK it is perfectly MANZ`legal but check Schedule A on their website.
I do think that MANZ outlawed a similar rollcage extention to the rear of the rear leafspring mount points (prolly not and issue in a 131 IIRC) for saftey reasons (rear end impact).
Once upon a time I came close to buying a 131R Miafororia(sp??) but it was too fucked. great driver though as I recall - but that was in the 80s :|
Your question was "can you put braces in like mine without stress from MANZ" and the answer is a firm yes.
Also: Just because I did something doesn't mean it is good. If I had my time again I would change things. I better look at your project page as I really like 131s. A modern European performance Cortina in my eyes (I hope that does not sound rude - I lubs Cortinas).
I think you should tie the front struts to the cage if you can.
Project update: Tonight I re-did all the fuels system in the engine bay. That meant was a few hours last week were completely wasted but it is better now - and as luck would have it lighter :D
  • 1 year later...
