Adoom Posted July 23 Report Share Posted July 23 Was that Howat Engineering in Lower Hutt you used? What did he charge you for cutting the splines? ....I've got some CV shafts I need to get shortened and was planning to go see Brian about it eventually. Quote Link to comment Share on other sites More sharing options...
zep Posted July 23 Report Share Posted July 23 7 hours ago, Adoom said: Was that Howat Engineering in Lower Hutt you used? What did he charge you for cutting the splines? ....I've got some CV shafts I need to get shortened and was planning to go see Brian about it eventually. They were like $100 each to be cut, welded up (due to the dip in the axle after the spines), resplined and heat treated. Ridiculous! 3 Quote Link to comment Share on other sites More sharing options...
