si
  • Replies 9k
Legally, if he didnt know then I dont think its his fault. If he knew and is playing dumb then you may have a foot to stand on.
For the sake of $500 for cert (assuming nothing major needs doing) it might not be worth it.....
another option might be go back to the place that gave it a wof and talk to them, they should not have issued it a wof
edit; assuming the wof is new- it is not uncommon for unscrupulous sorts to get a wof and then do engine swap then sell saying its legit
Hi Clintasaurus (and others),
I am looking at some coilovers to solve my suspension woes on my Cima, I can only source them from Japan but thats another issue.
2 questions:
I hear a lot of kafuffel about welding on struts however all the ones I am looking at (mostly "JIC" brand) seem to have some kind of mount welded to the side, example:
Not the best pic but hard to find a better one, you can see a funny thingy welded to the bottom of the right hand strut.
Is this Legal/Certable if it is "factory constructed" like that?
Also, because I am dutch I will probably buy 2nd hand ones. Is there a problem with getting a generic coil-over certified, or do I need factory specs or other information on the make/model of the coil-overs?
Your pal,
Turkey
My viva has no front bumper, grill or head lamp surronds and has a big oil cooler on the front. From what i read in section 2-1 of LVVTA LVV Cert Threshold because it was first registered well before 1999 it does not need to comply with frontal impact occupant protection standard and so i do not need a cert for having these things removed. Correct?
As long there is nothing that could be considered a 'pedestrian trap' (ie any way a person could get stuck in your grill if you run them over) you are probably fine.
I'll do some practical testing and get back to you.
2 questions:
Your pal,
Turkey
 The welding on a strut that is a problem is when there is cast or forged bits welded to mild steel, that is the issue. the bit that you can see there- sway bar link bracket- is fine. however it looks like the hub might be welded to the strut tube, which is a no go.
currently even brand name struts that are aftermarket, that have welding to cast incorporated in the design, cant be certified.
http://lvvta.org.nz/documents/infosheets/LVVTA_Info_05-2012_Welded_Aftermarket_Suspension_Struts.pdf
second hand struts can quite often turn into an expensive drama, especially if its an odd brand that there is no parts support for here. if i had a dollar for every time ive had a look at a car where someone had got a mean deal on some second hand leaky old "adjustyz" with play in the shock shafts and missing bumpstops and incorrect spring rates, id have enough money to buy a whole block of cheese.  i guess if you have a car thats not easy to get bits for then you have to take that risk, but be prepared for the possibility to have to spend some $ on them. have had a few customers spend $400 a corner to rebuild Tein struts
also, that was my nickname at work when i was an apprentice. BLAST FROM THE PAST
Well, if I had to pick between that and Clintaris then I would probably pick Clintasaurus :P
So anyway. Mucho thankso for your advice.
Just so I can clarify this situation here are a bunch of pics of the coilovers below (I went a bit overboard).
Pretty much if where I have marked is welded, then it is a no-go on NZ roads? Which kinda sucks cause thats how they all look to be done, (im not sure how else you could do it).
i know its been discussed already as to what does and doesnt need driveshaft hoops,but anyway,to my question:im about to convert a factory 2.5 v6 auto Non turbo Legnum to a twin turbo VR4 auto 4wd,do i need to fit driveshaft hoops for it to pass cert or will it be ok as its using all OEM parts(have the complete vr4 for the conversion)???
do this then? //oldschool.co.nz/index.php?/topic/29494-spraks-e21-315/
(about half way down)
Cool. Yeah I guess that was an option. I have to have a good look at the factory struts though to see if its even possible.
Thing is, I dont really care about the adjustable part of the equation. I just want some replacement shocks that arent hydraulic, but the only stuff I can find for my particular model of vehicle is aftermarket coil-overs.
So if I were to mod the shocks with some other "non adjustable" shocks, i'd still need a cert right? (cause they arent OEM replacements)
The whole thing just sucks and is too complicated :P
Just sell it and buy a actual VR4 and save yourself a lot of agrovation
