Hi Squires,
I've got a seat belt the fails to retract in my Hilux which is a WOF fail.
Can they be repaired, or is it better to replace with an aftermarket universal unit?
Thanks
can you retract them further and then finesse them to retract fully even if eventually? if so, spray the mechanism with silicon spray and see if that assists
You can clean all thr shit out of them, that one might be a bit far gone if it's fully stuck out.
Il let you look into it. Key part is don't disassemble the spring part. I don't think you have to worry  about explosive bits in that one
Generally it doesn't take that much gunk for them to stick
I've had some success with extending them fully (holding them extended with a clamp of some sort), smearing dishwashing liquid into the webbing, laying it out in the driveway then waterblasting what becomes a black soup out of the webbing.
Probably try not to get water into the mechanism, and chuck it in the hot water cupboard to dry fully over a few days. Then plenty of silicone spray in the spring area.
Doesn't make them new but seems to help to some degree.
I pulled the unit out of the truck, tried cleaning to no avail.
I thought flag it, I'll head to my local decent parts supplier for an aftermarket seat belt. The factory Hilux unit has a gas canister on it and the parts shop suggested I try my local commercial wrecker instead.
Can an aftermarket non canister type be fitted as intended?
That's a pretensioner belt
Should replace it with the same thing so the airbag system still functions
If the belt is changed to a non pretensioner type the air bag light will probably stay on
Toyota wreckers are thieves especially van/prado/hilux ones. Buy every single wreck at top dollar, corner market, print money. Around here anyway.  Good luck
5 hours ago, hood said:
Thanks Clint, that makes sense.
Yeah I'll go with a wrecker if it's a last resort
Go take a marketplace Hilux for a test drive and switch them out. Thats what Billy T would do.
  • Haha 3
I ended up getting the belt rewebbed through Seatbelts4u in Auckland, that remedied the problem.
Couriered it up on Saturday, back on my door step on Tuesday!
