ajg193 Posted September 26, 2023 Posted September 26, 2023 I use these https://www.nzefi.com/product/bosch-210cc-min-high-resistance-top-feed-fuel-injector/ Quote
lownslow Posted October 3, 2023 Posted October 3, 2023 Pretty sure I may of owned this years ago, but I cant remember the rego number when/if i had it. 4age, Dark blue, cream interior, drop hatch with flat front conversion, Oldschool cert plate on it. Quote
DirtyThirty Posted October 6, 2023 Author Posted October 6, 2023 On 26/09/2023 at 16:05, ajg193 said: I use these https://www.nzefi.com/product/bosch-210cc-min-high-resistance-top-feed-fuel-injector/ Cheers man! They look like exactly what im after Quote
DirtyThirty Posted October 6, 2023 Author Posted October 6, 2023 On 03/10/2023 at 18:53, lownslow said: Pretty sure I may of owned this years ago, but I cant remember the rego number when/if i had it. 4age, Dark blue, cream interior, drop hatch with flat front conversion, Oldschool cert plate on it. Theres been a few rego #s, but that sounds about right. Not sure about cream interior, I got it with black vinyl painted over Toyota brown Quote
tortron Posted October 7, 2023 Posted October 7, 2023 Shhhhh don't look at it It will be leaking from the rusted out seam in the cowl. V.lame to weld up Quote
tortron Posted October 7, 2023 Posted October 7, 2023 Have done it to I think every vechicle with a cowl I have owned. It's real easy when everything else is rusted out so you start from base level lol Quote
DirtyThirty Posted October 8, 2023 Author Posted October 8, 2023 On 08/10/2023 at 08:21, ajg193 said: Is that massive rust above relay block? Yeap "FIXED" by PO. Its on the list of the greater rust I've found. They rust through the cowl, its a previous repair done badly. Can see a good chunk of daylight from the otherside. Quote
DirtyThirty Posted November 4, 2023 Author Posted November 4, 2023 Got an offer for a RA29 T series diff with drum setup. Looks to be about the same width as the KPs 1370mm so won't need shortening. Any known rear disk upgrade and are the usual T series AE86 centers compatible? Quote
BlownCorona Posted November 13, 2023 Posted November 13, 2023 it looks like that spoiler was designed to have a thick rubber gasket under the leading edge? i bet it would look better with one. cut nice and flush to suit. Quote
DirtyThirty Posted November 19, 2023 Author Posted November 19, 2023 On 13/11/2023 at 23:14, BlownCorona said: it looks like that spoiler was designed to have a thick rubber gasket under the leading edge? i bet it would look better with one. cut nice and flush to suit. None of them seem to run anything and just are open there. But that's not a terrible idea! Might give that one a go Quote
ajg193 Posted November 19, 2023 Posted November 19, 2023 Good news about the injector situation Quote
DirtyThirty Posted November 20, 2023 Author Posted November 20, 2023 On 20/11/2023 at 05:44, ajg193 said: Good news about the injector situation Cheers man for pointing me in the right direction! Was an easy one in the end. Quote
Dudley Posted November 21, 2023 Posted November 21, 2023 Aren’t 210cc injectors smaller than stock ones? Quote
DirtyThirty Posted November 24, 2023 Author Posted November 24, 2023 On 22/11/2023 at 12:36, Dudley said: Aren’t 210cc injectors smaller than stock ones? I THINK stock 4AGE bigport ones were 220/210cc. With the years of gunk etc in them im sure they were flowing less than ideally anyways, so these new ones in theory should be fine. Im not going to be making any more power than stock at this point. Maybe in future, but ill deal with them then. Quote
DirtyThirty Posted November 28, 2023 Author Posted November 28, 2023 Honda people, any ideas what this clutch master is out of? Looks very short and would work for me. Have borrowed a friends S2K one to try, but still a fraction too long. The one in the photo is close to a EM2 Civic one, but not quite? The remote res will also help Quote
DirtyThirty Posted November 28, 2023 Author Posted November 28, 2023 7th Gen civic clutch master cylinder from @mk2marty if its any use to anyone in future. Similar to the sample photo above but not exactly, getting close.... Quote
mjrstar Posted December 1, 2023 Posted December 1, 2023 You'll need a pretty decent breaker for the battery, I think the one in my Mazda is about 150a and it's not really enough... Quote
DirtyThirty Posted December 3, 2023 Author Posted December 3, 2023 On 01/12/2023 at 17:43, mjrstar said: You'll need a pretty decent breaker for the battery, I think the one in my Mazda is about 150a and it's not really enough... I was looking at 120 amp ones, so I'll look for something higher. Maybe I'll call an actual sparky because I start a fire.... Quote
kp60nick Posted December 19, 2023 Posted December 19, 2023 On 10/11/2023 at 15:01, DirtyThirty said: Went ahead and installed the T3 wing, again not overly happy with how they have gaps. But turned out better than I thought. What I dont like is that they sit back from the hinged area of the boot, i get why, because otherwise they hit the roof. And I dont like they have gaps on the corner sides, but every single one I've seen installed looks like this. Few more screws to be installed but overall, not terrible. I have an og trd fiberglass roof wing from jp that I've had a mould made. Could potentially get one made if you are interested? Quote
