DirtyThirty Posted July 3, 2023 Posted July 3, 2023 Link to build thread: https://oldschool.co.nz/index.php?/topic/87856-dirtythirtys-1984-toyota-starlet-kp61/ Quote
ajg193 Posted July 3, 2023 Posted July 3, 2023 Well the good news is that if that is actually a 1984 then it is a slant front that has had a conversion done. Does it have the slant front hatch and interior? If it doesn't have slant front hatch on the back then it is almost certainly plated and tagged Quote
Dudley Posted July 3, 2023 Posted July 3, 2023 It’s a drop hatch with a front swap. You can tell as the fire wall are different above the tunnel and the heater hoses go through in a different area on bug/flat front cars Quote
DirtyThirty Posted July 3, 2023 Author Posted July 3, 2023 1 hour ago, Dudley said: It’s a drop hatch with a front swap. You can tell as the fire wall are different above the tunnel and the heater hoses go through in a different area on bug/flat front cars Cheers mate! I wouldnt have known that. So just the front grille, wings and bumper etc to change back you reckon? The slant front bumper I have wants to fit but does quite at the moment, probably due to the flat front conversion? Sorta liked the slant front more anyways and it's easier to find bits so that'd be handy Quote
Dudley Posted July 3, 2023 Posted July 3, 2023 Not to sure what is different on slant fronts more of a bugeye guy Quote
ajg193 Posted July 4, 2023 Posted July 4, 2023 You'll have no difficulty swapping the flat front parts for someone's slant front parts - with cash your way. Guards, bonnet, grille, valance, I think headlight buckets, bumper and probably a few other little bits Quote
DirtyThirty Posted July 7, 2023 Author Posted July 7, 2023 Anyone done a COP conversion on a 4age here? Generally you'd need a trigger wheel but I see everyone using the distributor base as a CAS? Quote
Snoozin Posted July 7, 2023 Posted July 7, 2023 Man seeing that snippet of the numberplate, I am almost certain this is @Toucan's old KP61, can't be many other KP's 4AG swapped with those same plate letters.... Any signs of it having been a dark blue colour? Quote
Snoozin Posted July 7, 2023 Posted July 7, 2023 4 hours ago, DirtyThirty said: Anyone done a COP conversion on a 4age here? Generally you'd need a trigger wheel but I see everyone using the distributor base as a CAS? Yes, I have one using KPRs trigger setup on my 16v. There is a bracket that holds a hall effect sensor near the cambelt pulley (under the covers) and another that references a steel pin in my alloy inlet cam gear. So the upside is, it is all hidden. Beautiful clean signal to the ECU. Coils are OEM 2NZ units on an SQ coil plate. KP61 Orakei Rd-175-Edit by Richard Opie, on Flickr Project KP61 2019 (90) by Richard Opie, on Flickr Quote
Toucan Posted July 7, 2023 Posted July 7, 2023 9 hours ago, Snoozin said: Man seeing that snippet of the numberplate, I am almost certain this is @Toucan's old KP61, can't be many other KP's 4AG swapped with those same plate letters.... Any signs of it having been a dark blue colour? I was thinking that when reading the first post but couldn't spot anything to verify, but the plate confirms it! I have seen it pop up in various states on trademe over the years so it's awesome to see a thread on here again! Sadly pics all dead in old thread Quote
Toucan Posted July 7, 2023 Posted July 7, 2023 Here's another. It's a KP60 as it originally had a 2k and x code diff. And it's a drophatch with flat front conversion as has been established. Happy to share more pics if I can boot up my old laptop and answer any questions but I can imagine it's had a whole string of different engines etc since my ownership. Fond memories of this car for sure! Quote
DirtyThirty Posted July 8, 2023 Author Posted July 8, 2023 16 hours ago, Snoozin said: Man seeing that snippet of the numberplate, I am almost certain this is @Toucan's old KP61, can't be many other KP's 4AG swapped with those same plate letters.... Any signs of it having been a dark blue colour? No signs of it being dark blue, but definitely red. It's had a few plates over time. When I get a chance I'll check those up! Quote
DirtyThirty Posted July 8, 2023 Author Posted July 8, 2023 5 hours ago, Toucan said: Here's another. It's a KP60 as it originally had a 2k and x code diff. And it's a drophatch with flat front conversion as has been established. Happy to share more pics if I can boot up my old laptop and answer any questions but I can imagine it's had a whole string of different engines etc since my ownership. Fond memories of this car for sure! If only those Hoshinos were still around! Love the blue. This came to me completely stripped of everything so its a bit of a process. Great to see some history! Quote
DirtyThirty Posted July 8, 2023 Author Posted July 8, 2023 On 07/07/2023 at 21:48, Snoozin said: Yes, I have one using KPRs trigger setup on my 16v. There is a bracket that holds a hall effect sensor near the cambelt pulley (under the covers) and another that references a steel pin in my alloy inlet cam gear. So the upside is, it is all hidden. Beautiful clean signal to the ECU. Coils are OEM 2NZ units on an SQ coil plate. KP61 Orakei Rd-175-Edit by Richard Opie, on Flickr Project KP61 2019 (90) by Richard Opie, on Flickr Fantastic! I wanted it all hidden so thanks. Was going to go with the full MRP 1NZ kit but the trigger missing from all the various kits always got me. EDIT: kpr's last trigger kit acquired so ill get the sensors and look at installing them once they arrive. Was away for a week but have some trumpets waiting for me and have chosen to go for a MaxxECU. Got some work ahead of me yet... Quote
DirtyThirty Posted August 15, 2023 Author Posted August 15, 2023 Anyone know of anyone who makes wilwood pedal mounts to order? Pretty difficult to get the car anywhere unfortunately. If I can ditch this cable to hydraulic setup for the clutch, I'd be left with so much less clutter and it simplifies things a lot. Quote
Dudley Posted August 16, 2023 Posted August 16, 2023 @kpr makes all parts to order nice and cheap too at $15 incl gst per hour Quote
DirtyThirty Posted August 18, 2023 Author Posted August 18, 2023 On 17/08/2023 at 09:20, Dudley said: @kpr makes all parts to order nice and cheap too at $15 incl gst per hour I can get cheaper rates if I supply the material? Quote
kpr Posted August 19, 2023 Posted August 19, 2023 sure, I work pretty slow and generally charge out 23 hours per day. Not to mention the minimum charge out fee Quote
DirtyThirty Posted August 20, 2023 Author Posted August 20, 2023 23 hours ago, kpr said: sure, I work pretty slow and generally charge out 23 hours per day. Not to mention the minimum charge out fee But actually legit, ill flick you an email tomorrow haha Quote
