Unclejake Posted January 29, 2019 Posted January 29, 2019 So keen to hear this puppy gurgle... 1 Quote
Vintage Grumble Posted January 29, 2019 Posted January 29, 2019 Its no Lexus, but i'll allow it. Quote
Lord Gruntfuttock Posted January 29, 2019 Posted January 29, 2019 Carpentry tools should be fine for an old Chebby...? Quote
Unclejake Posted February 3, 2019 Author Posted February 3, 2019 Cock blocked due to a lack of key still. Getting the ignition barrel out without a key is easy on a 1994, but destructive on a 1995 Chev. Quote
RUNAMUCK Posted February 6, 2019 Posted February 6, 2019 I wonder if my mate would have some shed space you could use? I've actually been meaning to ring him.up for a yarn for a while now. Quote
Unclejake Posted February 6, 2019 Author Posted February 6, 2019 I still haven't met Jay (to my knowledge). It's an odd place. ~ 600 people live here, and in May I'll have been here for a year, but almost every single day I see someone I've never met before. WHERE DO THEY COME FROM? Aliens I guess. Un-vaccinated aliens spreading 1080 and selling fake rims. Oh, I have a plan for access to a shed. The owner's already said no, but I reckon if I promised to be in and out fast he'll relent. I'll see what I can achieve in the paddock first. I'm figuring motor and trans should probably come out together, but I have no idea how big a job the transfer case will be. I didn't look that hard. Too much sheep shit and thistles. In other news it's cold as all hell here today. Ha 1 Quote
RUNAMUCK Posted February 6, 2019 Posted February 6, 2019 Jay is a GC. He and I did a lot of really dumb shit back in the day. He's fairly mechanical too. It's suprised when he said many people down there had no clue about motors. I would have thought it'd be a neccesity if you lived somewhere like that. What's your mates name? Quote
fuel Posted February 6, 2019 Posted February 6, 2019 Surprising that there's no WOF system in the Chathams! Quote
RUNAMUCK Posted February 6, 2019 Posted February 6, 2019 I actually thought they'd begun enforcing wofs over there? My mate always told.me.it.was because the roads were so rough. My mate had a ruff as.front tug Toyota. (It died it's final death halfway through my stay there) none of the seat belts would pull out. My mate reckoned the jiggling of the grave roads fucked the inertia reel mechanisms. And all.cars did it after a while out there. Quote
SOHC Posted February 7, 2019 Posted February 7, 2019 Can you get parts shipped to you ok? can you find an old Jimmy diesel from an old boat to re power it? Dosnt the Chathams has more Harley Davidson's for its size than any other place on the earth? 1 Quote
Unclejake Posted February 9, 2019 Author Posted February 9, 2019 Rental and government vehicles have WoFs, but not many other people bother. I will build a safe and sound vehicle - but that doesn't mean it'd pass a WoF. Getting parts delivered here by ship is no problem, but it can take a couple of months and cost a lot. This Chev was ~ $5k in freight from NZ to Chatham, but about $3k in freight from USA to NZ. I can fly things the same week from Wellington to Chatham @ $3.50 per KG, but that needs someone running around in Wellington, and an engine probably weighs 400 kgs (you can do the math). CI used to have the highest Harley ownership per capita on the planet, but those days are gone now. A question: If I pull out the motor, leaving the torque convertor on the flywheel (connected to the crank) will I need to drain the auto trans first? I may abandon this project once the motor is out and I don't want to leave a dry trans sitting in the salt air for the next few years if I can help it. Does the transmission need draining? Quote
Raizer Posted February 9, 2019 Posted February 9, 2019 Why not just leave the converter in the trans? 1 Quote
Unclejake Posted February 9, 2019 Author Posted February 9, 2019 The convertor is bolted to the flywheel and I can't turn the motor over. The convertor slides onto a splined input shaft that juts out of the the transmission ( I think) I have the huge advantage of a (seized) short-block lying in the same paddock. It was obviously removed with the convertor still attached, and has helped me work out where the trans/engine block bolts are 1 Quote
Raizer Posted February 9, 2019 Posted February 9, 2019 Ooh yeah, didn't think about turning the engine over to get the the converter bolts. Quote
cletus Posted February 9, 2019 Posted February 9, 2019 You won't need to drain the trans, some might spill out the converter but it won't be much. Try and pull the motor out straight, until the converter is out, if it gets pulled on an angle it could damage the pump in the trans 2 Quote
RUNAMUCK Posted February 10, 2019 Posted February 10, 2019 How much space is in front of the engine? Can you rip the heads off first, and try turn the motor over with a big fucking bar on the crank bolt? (Slip a bit of pipe over the power bar, and jack the truck off the ground off the end of the bar. Quote
M.H. Posted March 2, 2019 Posted March 2, 2019 Lucky that pre combustion chamber has dropped right out and destroyed it all. Must have gotten pretty hot Quote
