  • Replies 140
Went down the google rabbit hole on plug chops
43497251_1208713165920501_72495233896672
Getting close but would rather a bit rich for doing 600ks round the coast so swapped the 118 out for 122mj. Run out of daylight/fucks to do another plug chop but will try again tomorrow after work
  • Confused 1
I see the confused reaction @AllTorque, guessing it's at the thread cut off?
When doing a wide throttle test over only a short distance the plug won't fully colour up, the smoke ring tells the story better than the tip of the insulator but it's nearly impossible to see properly without cutting the threads off.
  • Thanks 2
Good stuff!
How many teeth was your original front sprocket and what's the rear? I've just ordered 3 sizes to play around with on my bike - I'll have 11T (standard), 12T, 13T and 14T sprockets to test.
Standard front is 12t and havent counted the rear but its got lots of teeth dirtbike spec.
Im hoping with a less rich tune and a tutu with squish it will improve the performance but that can wait til after east cape
Oh yep, that's roughly a 25% increase in ratio / reduction in torque. Mine will be 27% if I go to the 14T sprocket, but I ordered the smaller ones to get my acceleration back if it ends up too doughy :lol:
Tutu’d with measuring the squish band then pussyed out on taking too much off the head so slapped it back together with 2 headgaskets and some copper spray so no clearance issues and half pie squish band.
Removed the oiling barb from the head and jb welded the port up.
Running good enough for me to nang round the farm/backroads for now. Might take it to the pakeha to get the squish band clearanced properly after the holidays
Done 75ks in the last couple of days so whipped the head off to check out whats happening with compustion.
As you can see its got the same issue of only burning on the front of the combustion chamber still with the new tutu'd with head. I thought the electrode for the plug being in the way was not helping the cause but they are 180 out on the 2 heads and still no difference. Time to get it booked in at @MopedNZ work the 2T wizards to sort it properly
