Raizer Posted January 1, 2019 Posted January 1, 2019 It's carboning up on the exhaust side, clean on the intake side. How are your reeds? I still think you have been nanging it too lean on the main jet tbh. Quote
HighLUX Posted January 1, 2019 Author Posted January 1, 2019 Carboning up on the exhaust side. Its had a 118mj in it when it popped on the way to east cape ride Quote
Vintage Grumble Posted January 1, 2019 Posted January 1, 2019 Could it just be how the mix transfers up to the combustion chamber? Might just come up one side easier or something? 3 Quote
HighLUX Posted January 1, 2019 Author Posted January 1, 2019 Reeds seem fine but dunno what im looking at other than they seal against the reed block ok 1 Quote
flyingbrick Posted January 3, 2019 Posted January 3, 2019 On 01/01/2019 at 15:54, Vintage Grumble said: Could it just be how the mix transfers up to the combustion chamber? Might just come up one side easier or something? I asked some barry about mine and he said only different squish does this Quote
peteretep Posted January 3, 2019 Posted January 3, 2019 I thought those markings on the inside of the head were fairly normal and represented how the unburnt fuel/air entered and the mostly burnt fuel/air left. I dont understand why you would need to change squish on a kit like this TBH 4 Quote
HighLUX Posted January 3, 2019 Author Posted January 3, 2019 Piston hits the head without taking a bit off the edge of the squish band Quote
peteretep Posted January 3, 2019 Posted January 3, 2019 is it because its the wrong kit for the bike/engine? can you space the whole cylinder/barrel out instead? Quote
HighLUX Posted January 3, 2019 Author Posted January 3, 2019 Nope supposed to be bolt on TS50 big block kit. Im tempted to try make a base gasket out of 1.2mm gasket paper instead of 0.6mm that came with the kit. Might fuck with port timing a bit but better than blowing it up Quote
Steelies Posted January 4, 2019 Posted January 4, 2019 What's the stroke on that beast? Last I heard from 'my' engine guy was not to be afraid of moving the barrel a little when dialing combustion chamber in. Jennings reckons 0.4ish mm minimum squish, 1.5mm max. Seems like a lot of leeway Any signs underneath the piston crown? Quote
HighLUX Posted January 5, 2019 Author Posted January 5, 2019 2 steps forward one step back it seems. Swapped base gasket out to 1 I barry’d up with a ball peen hamer out of 1.2mm gasket paper. Success as can now run 1 headgasket and head with untouched squish band without piston touching the head issues. Got excited for a test nang but now its running like shit and wont idle/lazy to rev. Spark plug is super wet almost dripping with fuel now. Gave up for the day and will check the carb tomorrow/drop a jet size 1 2 Quote
HighLUX Posted January 5, 2019 Author Posted January 5, 2019 Oh lols. The needle had popped the clip up when I put the carb back together earlier so it was just jumping round doing its own thing. Got it sorted and happy idle/shed nangs again. Seems alot more rev happy now too. Will wait for daylight tomorrow for more test n tune 5 2 Quote
HighLUX Posted January 10, 2019 Author Posted January 10, 2019 Just ordered a 13T sprocket from the UK to try get a bit more top speed without too much torque loss that I got from the 15T one and another Giannelli spanny/muffler combo to suit a TS50 instead of the TS80 one im currently running. It will be interesting to see how the power band changes. I slapped the factory exhaust back on for lols and it makes the bike so lazy, no noticeable powerband just quiet nangs 1 Quote
HighLUX Posted January 12, 2019 Author Posted January 12, 2019 More tutu'ing and getting better results. Whipped the head off to check squish clearance after everthing had settled, piston crown still had the faintest mark on the back edge where its just contacting when things expand. Very cautious grind with the die grinder to fix the touching and slapped it back together. Went up to a 120mj jet again an dropped to a 48 pilot which is seems very happy with, enough torque to hold 4th up most hills if I keep it on pipe and the high rev off idle cutout/splutter has gone with the smaller pilot jet. Just went for a happy backroad nang and it will rev right out to the top of 5th on the flat now which is about 78-80ks at 10k RPM. 6 Quote
HighLUX Posted February 24, 2019 Author Posted February 24, 2019 TS went bang again which was dumb so decided to see if a mudbug motor would fit, purchased a TF125 and stripped it down with a few parts going to a mate to resurrect his one. Got off to a good start with magneto and sprocket off the TS engine going straight onto the 125 block but then when it came to engine going into the frame things didnt go so good. Motor fits the frame but only just and the offset exhaust port lines up perfectly with the front of the frame so thats not going to work without fucking with the frame which I dont want to do. So purchased another one from Fielding for the lowlowprice of $150. Bit rough and ready but perfect for just nanging round on, few things on it to tidy up and get lights working etc luckily I have the other one to swap bits from. Interestingly it has a VIN on it and shows up in carjam so could be made road legal. Its going off to live down Hicks Bay as a hunting/fishing nang machine so WOF aint really required lols 3 Quote
HighLUX Posted February 24, 2019 Author Posted February 24, 2019 At a loss with what to do about the TS and its motor being a cunt really. Im over fucking round with the 50cc so the only option is go bigger displacement but still wanna stay 2T. Next step will be go have a geez at a JR80 to see how the bolt to frame/measure size but they have an offset exhaust port too which could be an issue or maybe a RM80 engine/dunno Quote
Bellicose Posted February 25, 2019 Posted February 25, 2019 On 24/02/2019 at 17:07, HighLUX said: At a loss with what to do about the TS and its motor being a cunt really. Im over fucking round with the 50cc so the only option is go bigger displacement but still wanna stay 2T. Next step will be go have a geez at a JR80 to see how the bolt to frame/measure size but they have an offset exhaust port too which could be an issue or maybe a RM80 engine/dunno I've got a mid 80s and a mid 90s DS80 here if you need pics or measurements. 1 Quote
HighLUX Posted February 25, 2019 Author Posted February 25, 2019 1 hour ago, Bellicose said: I've got a mid 80s and a mid 90s DS80 here if you need pics or measurements. Pics of mounting bolt setup and barrel height/gearbox length please Quote
HighLUX Posted February 25, 2019 Author Posted February 25, 2019 This would have to be the coolest of my 2T brap collection A 72' Kawasaki G4TR with hi/lo 5 speed box, been in the family since new being purchased by my uncle to punt round his kiwifruit orchard then languished in a shed for years. Been rego'd at some point so would be cool to get a plate back on it Was last running around 10 years ago but this is the main issue that needs fixing 7 1 1 Quote
