  • Replies 140
17 minutes ago, Raizer said:
Lush man!!
Got a 24mm carb lined up? :P
Not yet/price on something suitable and can you source the adaptor too? Think it was on Ebay I saw the Malossi ones
Nah it was on trademe last weekend. Quick bit of negotiation with the previous owner got it to a price I was happy to pay and clicked buy now before someone else could snake it
Yeah it's pretty much a full sized TS frame with just a 50cc in it and skinny rims. You would be able to ride it easily with some longer bars for your lanky frame. There's heaps of Empty Space above the barrel where you can fit a bigger cylinder like a TS 125 engine looks like it would fit
On 6/16/2018 at 17:17, Willdat? said:
You'll be after an RMX/SMX50 in no time...
Shit yeah after seeing this I am, gotta love that fuck you ima dirtbike sound
Brings back memories! I've had both - rode the RMX50 to my first OS event in Kaikoura from Nelson. Cruised at an indicated ~90km/h, topping out at ~110. Is the TS a 5 or 6 speed?
Had another go at the carb last night with a borrowed utrasonic cleaner
35763198_10160667690020323_2346457675958
It came up banging but on re assembly I noticed the main needle was looking a bit flakey so tried a bit of P2000 and it turned out to be chooched as fuck. They are NLA genuine/aftermarket so time for a NZ Scootercare upgrade.
Potatoe fone cant comprehend the shinyness of the flash CDI from Raizer
Carb from NZ Scootercare ended up in Porirua instead of Papamoa still no ringadings but the light bar I ordered from Ali turned up in 9 days which is some sorta record.
Will help with night riding as the headlight only has on with no high beam. Just need to find a bar switch to rig it up or a Suzuki switch block that has the extra position for hi beam so I can wire it into that
Turns inside of the shed from dark to daylight when hooked up to a test battery. Not so much of a direct beam but more daylight everywhere infront of it.
Will do a good job and doesnt stick out too much tucked up under the headlight
https://www.aliexpress.com/item/ECAHAYAKU-1Pcs-6-inch-18W-LED-Light-Bar-12V-80V-Motorcycle-Offroad-4x4-ATV-Spotlight-Truck/32864539972.html?spm=a2g0s.9042311.0.0.13cf4c4dF7jfq6
