Kimjon Posted June 4, 2018 Share Posted June 4, 2018 Love it! 1 Quote Link to comment Share on other sites More sharing options...
Ghostchips Posted June 4, 2018 Share Posted June 4, 2018 That's straight for a tractor (having worked in a tractor shop i saw some shocking things). 2 Quote Link to comment Share on other sites More sharing options...
chasinthemirage Posted June 4, 2018 Share Posted June 4, 2018 What does the hatch in the centre of the hood give you access to? Fuel tank? 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted June 4, 2018 Author Share Posted June 4, 2018 Yeah, fuel filler. Unsure why the whole thing hinges! Quote Link to comment Share on other sites More sharing options...
chasinthemirage Posted June 4, 2018 Share Posted June 4, 2018 It's a pretty cool feature imo! 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted June 4, 2018 Author Share Posted June 4, 2018 The best part is that this thing lived by the sea (coromandel) and yet its still only got surface rust* *With exception of the 2 hood holes and the bottom corners of yhe front side panels and also the rear guards. So what im trying to say in hindsight is that the hoods good and the rest isnt. Quote Link to comment Share on other sites More sharing options...
Valiant Posted June 4, 2018 Share Posted June 4, 2018 Yes! What are your plans for the Tractor Nathan? Do you have a specific purpose in mind of is it for general tractor hi-jinx? 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted June 4, 2018 Author Share Posted June 4, 2018 Its going to mow my lawns and also id love to make use of the rear hydraulics with attachments like- -engine lifter -mole plow -rear scoop. 2 Quote Link to comment Share on other sites More sharing options...
Valiant Posted June 4, 2018 Share Posted June 4, 2018 I'd love to see some attachments, such as. -Log saw. -Wood splitter. -Post driver. 3 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted June 4, 2018 Author Share Posted June 4, 2018 Forgot to mention. Iv found a good auger at the neighbours that i may purchase Those saws are way too terrifying! Would love a screw type log splitter.. omg https://youtu.be/X3Rypb1dcUE Quote Link to comment Share on other sites More sharing options...
Shakotom Posted June 4, 2018 Share Posted June 4, 2018 Hell yeah 1 Quote Link to comment Share on other sites More sharing options...
nickrock Posted June 4, 2018 Share Posted June 4, 2018 Thoes auger type log splitters suck they get stuck in a knotty bit of wood and can be a mission to get out the spear ones work well you just retract the ram and the wood falls off 2 Quote Link to comment Share on other sites More sharing options...
datlow Posted June 4, 2018 Share Posted June 4, 2018 Oh yeah seems we have thrown all the 2 pac grey out we have this mystery acrylic? Stuff 2 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted June 4, 2018 Author Share Posted June 4, 2018 Sounds like something you'd make tortrons shoes out of, lol. 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted June 4, 2018 Share Posted June 4, 2018 I have a tin of "army green" might be enough for the tin work 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted June 4, 2018 Author Share Posted June 4, 2018 It's staying bare steel thanks :-:D Quote Link to comment Share on other sites More sharing options...
tortron Posted June 4, 2018 Share Posted June 4, 2018 if you have any ripples in it you are welcome to use my shrinking disks 1 Quote Link to comment Share on other sites More sharing options...
Thphantum Posted June 5, 2018 Share Posted June 5, 2018 On 4/06/2018 at 21:35, nickrock said: Thoes auger type log splitters suck they get stuck in a knotty bit of wood and can be a mission to get out the spear ones work well you just retract the ram and the wood falls off They are also quite good at smashing gearboxes, would not recommend, from experience. 2 Quote Link to comment Share on other sites More sharing options...
Popular Post flyingbrick Posted June 9, 2018 Author Popular Post Share Posted June 9, 2018 Went and met a super awesome barry in Thames who actually rebuilds starters and alternators. This guy is the ONLY person I'd spoken to who had any idea about my starter problems. He had a replacement part on the shelf for $140 and was happy as to show me all of his NOS spare parts and impossible to find bits and pieces. Every other person tried to sell me a new starter! I'd highly recommend him to anyone with old electrical stuff that should work but doesn't. 21 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted June 10, 2018 Author Share Posted June 10, 2018 Im pretty good at assembling these starters now. Had an issue with the new component not sliding nicely on the shafts spline without binding. Took about an hour with a diamond hone to get all the rubbing spots down..one by one. Then engaged the coil with jumper leads and set the pinion throw using flathead and jam nut on side of starter. This is so that when at max throw you arent loading the fork and pinion up into the end of the snout. Installed the starter, made sure there was no water in any of the fuel lines/filters, emptied the intake air cleaner (it was FULL of water) and... She fired into life after about 4 revolutions. First time in quite a while and it only took a few seconds for it to have zero smoke and run SUPER clean Then i stood back and put thr hood on. I havent finished with thr side panels and grille yet. Then back into the shed i wire brushed and penetrolled the underside of the hood and then hammered out the big dents up front. Ill get it better later (probably never will) 9 Quote Link to comment Share on other sites More sharing options...
