  • Replies 540
47 minutes ago, Giant said:
has anyone here run water meth in a diesel?
Just get more air into it, water meth should be a last resort to control egt
My 3L is at that last resort level. Compound charging is high on my mind, I've been pushing 25psi from a single, could go more with a larger snail but being a daily I wanna keep the boost threshold low. I like being able to spin the tyres at 2k rpm.
Anyone else use variable vane turbo's on their diesels? I use a garrett gt2056 with 1.0 housing on my td27+T with actuator to control the vanes, Works quite well, want to compound charge next but worried about small shaft size of little turbo so probably change to gt3063 as the small turbo and hx40 as big
I have used a variable vane from a 1KD on my 3L. Just used a standard boost actuator to control it which worked kind of well. It was a bit surgy at lower throttle since it was trying make full boost all the time but tweaking the vane stop screw got it to an acceptable state.
