Dudley Posted September 2, 2021 Posted September 2, 2021 Might have to give ya fancy snap on box a squirt in the colour so it matches bro haha 1 2 Quote
Nominal Posted September 8, 2021 Posted September 8, 2021 Nice work one power steering leaks. Mine's terrible. For the steering wheel, can you center it up by adjusting the tie rod ends? I haven't had much luck with getting the steering wheel right, I just live with it being wonky. For the hubcaps, this gadget came with my new car, not sure if it's a home-made or commercial thing? Quote
piazzanoob Posted September 9, 2021 Author Posted September 9, 2021 12 hours ago, Nominal said: Nice work one power steering leaks. Mine's terrible. For the steering wheel, can you center it up by adjusting the tie rod ends? I haven't had much luck with getting the steering wheel right, I just live with it being wonky. For the hubcaps, this gadget came with my new car, not sure if it's a home-made or commercial thing? The steering wheel is half way off centre. but the wheel isnt flash and bits are all broken on it around the edge. so was going to fit an aftermarket smaller one. but suspect someone in the past has crossed threaded it on the splines. that tool may work but not sure how well. the one tortron put up looks like a much better tool on not damaging the paint. Quote
cletus Posted September 9, 2021 Posted September 9, 2021 I had the same problem with widened steel wheels and hubcaps, I ended up drilling a small hole in the side of the cap and made a wire hook that went in the hole to pull the cap off 2 Quote
piazzanoob Posted September 10, 2021 Author Posted September 10, 2021 9 hours ago, cletus said: I had the same problem with widened steel wheels and hubcaps, I ended up drilling a small hole in the side of the cap and made a wire hook that went in the hole to pull the cap off cheers I did think of doing that also. did you use stainless safety tie wire and tie the ends together on the inside? Quote
cletus Posted September 10, 2021 Posted September 10, 2021 For the hook? I used a coat hanger wire from memory, small hook one end and a finger sized loop on the other Quote
piazzanoob Posted September 10, 2021 Author Posted September 10, 2021 1 hour ago, cletus said: For the hook? I used a coat hanger wire from memory, small hook one end and a finger sized loop on the other yeah. sounds like it would of stood out like a sore thumb that way? Quote
cletus Posted September 10, 2021 Posted September 10, 2021 Nah I put the hole in the side of the cap so you couldnt see it If your cap doesnt have sides it would look shitty though. What about one of those neodymium magnets? I wonder if one of those would remove them Quote
piazzanoob Posted September 10, 2021 Author Posted September 10, 2021 yeah cap has no sides. that could be a go. i wonder if hunting and fishing have them go and test them haha Quote
datlow Posted September 11, 2021 Posted September 11, 2021 We have 25 Ish kg magnets at work pulling them apart is a mission if that’s a legit 112kg you’d probably dent the shit out of the hubcap trying to get it off chuck it in a sock etc so you can slide it off without damaging/denting Quote
tortron Posted September 11, 2021 Posted September 11, 2021 Have one, itl remove morrie hubcaps, held on by the 3 prongs Quote
RXFORD Posted September 11, 2021 Posted September 11, 2021 Toilet plunger... Just make sure its a new one because I probably have shit on my hubcap now. 1 6 Quote
Corbie Posted January 30, 2022 Posted January 30, 2022 What about a suction lifter? Teng Tools 30KG Professional Single Suction Cup Dent Remover/Puller & Glass/Tile Lifter - SL01 https://www.amazon.com/dp/B07C461L34/ref=cm_sw_r_apan_glt_i_Z5W9CWE4VASTE0Z6MTXT Quote
