remove rust using molasses
eureka
1 part molasses (get from farmlands) to 10 parts water.
surface rust gone in a few days very very pitted rust in couple of weeks.
gets into A pillars, panel gaps etc where sand blasting can't.
it really does work I put my Austin 8 van body into a 4000L swimming pool  of it. ate all the rust away so now I can weld patches to the solid steel.
Lasts for approx 6 months and at the end all you are left with is sugary water (with a little iron)
don't have to get swimming pool ($159 from warehouse if you do) small parts easily cleaned up with just a bucket of it
  • Like 9
  • Replies 45
Can the general public buy concentrated hydrochloric acid? that shit is boss for stripping rust, used it when i was an electroplater.
You can buy Muriatic Acid (another name for hydrochloric) at hardware stores - used for concrete cleaning.
I have that I use for getting rust or zinc plating off steel.
It's nasty though, need gloves and goggles, and don't store it in your garage.
Why not?
I have the leftover stuff from my garage floor operation in my garage still.
I've been told it can cause rusting of nearby steel due to vapour escaping the container.
I keep it in a garden shed, on a metal shelf though.
Don't use it inside either - nasty fumes.
http://www.jalopyjournal.com/forum/threads/a-downside-to-muriatic-acid.813794/
