Seedy Al Posted September 19, 2016 Share Posted September 19, 2016 Hey chaps. So basically, my partners sisters car has an issue or two, and thought I might try for some advice from some people that might have fucked around with black top 4ages more than me. The vehicle, ae101 bz tourer with a black top clearly. 1997 vintage. The issue or issues as such, as they maybe related. Basically it is hesitant during low revs up to around 4000rpm then most often clears put and goes very well as a 4age should. Cruising seems fine, and seems pretty good at wide open throttle. So is most noticeable at quarter to half throttle sort of thing. Also, every so often while cruising along at 80ish, so I gues around 3000 rpm, it hasca blatant miss, but only for a second. What I have done so far is new plugs, as old ones were super ashed up, so yes being a black top it uses some oil, but not fuming blue smoke all over the place bad at all. Also replaced the rotor and the cap had previously been replaced by me on request from someone else as to this being the cause, which is wasn't. However since doing the rotor and plugs it does seem ba bit better as it was lot more missy before. The leads I have swapped with some known to be good second hand ones. However not the coil lead, which could be an issue but I would be surprised. I have also cleaned out the filter for the sensor, and tried the ecu for codes. There were none. Scan tool on live data is showing that the coolant temp sensor is working like a boss. So, where to from here? I have read a bunch of threads. Every one stating its a common problem but never really getting down to how to fix the cunt. One suggestion was tps, so I am going to check and set that along with the base timing tomorrow. Another was that the oxy sensor could be toast from oil contamination. I guess I could commit to buying an oxy sensor, but. If people have some first hand experience with these rad as shit little motors and how to address this silly issue I would love to hear about it. Thanks dudes. Seedy mother fucking al Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted September 19, 2016 Share Posted September 19, 2016 o2 sensor, make sure its not running 91! 1 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted September 19, 2016 Author Share Posted September 19, 2016 My guess is it has been run on 91 but im sure I have told here to run 95min lol. Ok fuck it I will just order an oxy sensor then. But not from you you expensive cunts lol. 1 Quote Link to comment Share on other sites More sharing options...
Robbo Posted September 19, 2016 Share Posted September 19, 2016 Sounds super similar to what my old daily used to do occasionally (without the miss though), I did a bit of research and concluded it was the o2 sensor. Ended up selling it before I got chance to replace it though but that'd be the first thing I'd check out. Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted September 19, 2016 Share Posted September 19, 2016 My guess is it has been run on 91 but im sure I have told here to run 95min lol. Ok fuck it I will just order an oxy sensor then. But not from you you expensive cunts lol. Â 1 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted September 19, 2016 Author Share Posted September 19, 2016 1 Quote Link to comment Share on other sites More sharing options...
xsspeed Posted September 19, 2016 Share Posted September 19, 2016 Its been a while but possible leaky caps in ecu? That may have been a silvertop problem tho i seem to recall some ecu related shenanigans with hesitation Quote Link to comment Share on other sites More sharing options...
UTERUS Posted September 19, 2016 Share Posted September 19, 2016 Mine had the crappy running at low throttle and occasional miss at cruising speed. Â I ran it on 98, replaced leads/plugs/dizzy cap/rotor, did a trackday at taupo, replaced the o2 sensor, advanced the timing, fiddled with the tps, hit rev limiter everyday and it still ran the same. Â I was going to try a new coil next but sold it instead. Quote Link to comment Share on other sites More sharing options...
Mof Posted September 19, 2016 Share Posted September 19, 2016 Sounds like the way to fix it is to sell it I'll show myself out Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted September 19, 2016 Author Share Posted September 19, 2016 Lol. Had considered leaky caps also. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted September 19, 2016 Share Posted September 19, 2016 My black-top also does similar, or-though doesn't sound quite as bad (ours has had motor re build also). It's just not so good at low rev range, our old silver-top car just seemed to be allot smoother.  I was going to look at: smaller zorst system, clean throttle body, dizzy cap n rotor, plugs and check the sensor flexi tubes and the likes.    No real help sorry. Quote Link to comment Share on other sites More sharing options...
chris r Posted September 19, 2016 Share Posted September 19, 2016 02 sensor is more for emissions than 'general running' of the car. Black top is map sensor right? Check the vacuum lines etc. Is it using more fuel than usual? Give the coolant temp sensor a trst/try (it's cheaper than a 02 sensor). One day I will need to do a write up on efi Quote Link to comment Share on other sites More sharing options...
kempy Posted September 19, 2016 Share Posted September 19, 2016 Is there any correlation to heat ie. Cold engine vs warm engine? Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted September 19, 2016 Author Share Posted September 19, 2016 Sorry my wall of text might have been a bit much Coolant temp sensor seems fine, based on live data  Seems worst when cold, maybe, but still present through all temp range.  And I have checked the vac line to the Map when I Checked the filter that feeds to it. All Seems good and cleaned it yesterday  If I had the smoke machine here at the moment I would give it burn and check for intake leaks, but at this point I dont Lol 1 Quote Link to comment Share on other sites More sharing options...
Mourning Cupcake Posted September 19, 2016 Share Posted September 19, 2016 My guess is it has been run on 91 but im sure I have told here to run 95min lol. Ok fuck it I will just order an oxy sensor then. But not from you you expensive cunts lol. Â Have just confirmed, Yes, she runs it on 91. Apparently that's what the sticker on the flap says. Quote Link to comment Share on other sites More sharing options...
UTERUS Posted September 19, 2016 Share Posted September 19, 2016 Mine would only run decent on 98 Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted September 20, 2016 Share Posted September 20, 2016 Yeh, deff should be running on 95+, they are 11:1 comp ratio I think. Â If she drives like a blouse, it may just need a good nang, they sometimes carbon up due to being driven too nicely, and a good thrash clears them out. Well I had a silver top that would slowly die due to this, a good nanging always cleared it out. 1 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted September 20, 2016 Author Share Posted September 20, 2016 I put 98 mobile in it on Monday, and can confirm I have been nanging it as I too have considered this. Wonder if I do the oxy sensor, keep her running 95 to 98 and disconnect the battery to try hard reset the ECU Quote Link to comment Share on other sites More sharing options...
Mourning Cupcake Posted September 20, 2016 Share Posted September 20, 2016 Bahahaah, Yea, nah, she doesn't drive like a nana. Quote Link to comment Share on other sites More sharing options...
pbaines Posted September 20, 2016 Share Posted September 20, 2016 Just finished having the same issue with my BZR. Turned out to be the igniter. Get another coil and igniter setup from somewhere and wack that in and see how you go Quote Link to comment Share on other sites More sharing options...
