ajg193 Posted September 20, 2016 Share Posted September 20, 2016 Do these have VVT? Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted September 20, 2016 Share Posted September 20, 2016 Yef, but if that jams on they won't even idle. Quote Link to comment Share on other sites More sharing options...
4AGEMAD Posted September 21, 2016 Share Posted September 21, 2016 I had that problem. Luckily i work at toyota so had access to the old brick IT1 which measured the o2 sensor and gave a graph reading of it fuel trims Old sensor was dead, flat lined. Fitted new sensor and on open loop circuit was fluctuating correctly. Also hesistation went away. Also check that your efi temp sensor is working properly Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted September 21, 2016 Author Share Posted September 21, 2016 Well. .... I replaced the o2 sensor today, and also set the base timing as it was at 5 degrees and is meant to be at 10. Still has hesitation but seems to be much better. And also actually revs alot better as you would expect with the timing being out. At this point im going to leave it for now and get her to keep running it on 95min, and see if it starts to improve. Worst case I can probably borrow a car from the car dealer we work for and try swapping ignitor and coil etc. So much info on the Internet and yet there is no magic cure haha. Quote Link to comment Share on other sites More sharing options...
_Matt Posted September 21, 2016 Share Posted September 21, 2016 I'd definitely try another ecu if you can get your hands on one. Mine was doing similar, opened up the ecu and couldn't see leaky capacitors or anything either. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted September 21, 2016 Author Share Posted September 21, 2016 And I assume that fixed it lol? Might have to keep an eye on pic a part lols Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted September 21, 2016 Share Posted September 21, 2016 One of mine ran odd for like 4 months, I tried everything and couldn't get it to stop being a dick, then one day it came right, and never did it again. I guess thats the problem when theres so much magic in an engine, only a wizard can help you. 1 Quote Link to comment Share on other sites More sharing options...
xsspeed Posted September 21, 2016 Share Posted September 21, 2016 Sparky helped you? Quote Link to comment Share on other sites More sharing options...
Stu Posted September 21, 2016 Share Posted September 21, 2016 I've had this on a couple of blacktops now. Oxygen sensor was the main culprit but also wear on the vvt pulley also caused a bit of cam wander that made it run similar to what you are describing. Swapped on a replacement pulley and the issue went away. Quote Link to comment Share on other sites More sharing options...
Stu Posted September 21, 2016 Share Posted September 21, 2016 You could try a very thorough oil flush to make sure the vvt operation gallery's are squeeky clean. Quote Link to comment Share on other sites More sharing options...
Frosty Posted September 26, 2016 Share Posted September 26, 2016 Seen oil getting into the dissy cause issues in the past, only takes one overheat to harden the internal O ring. Quote Link to comment Share on other sites More sharing options...
