rum rums hillbilly hot tub
rumrum
  • Replies 48
How will you heat it?
We made one out of a chest freezer at uni. Had a radiator from a mini sitting on a gas burner with a boat bilge pump puming the water from the frezzer through the radiator and back in.
Also rigged up a thermette type thing which worked good as well.
Ok so plan is to heat it using a copper coil put into wood/gas fire, creating a thermosiphon much like this but a lot less sexy (i look good in a bikini but not that good!!)jglpkodt.qtp.jpg
I Am looking for a metal tub type bucket thing to use as a fire box, thinking of just disassembling a washing machine and using the innards..
$50 wet back fire will heat this sweet. Did a perfect job on a full sized spa pool setup I made last year.
Thermosyphoned fine with about 100mm of fall but could of done with a bit more to help it heat faster.
Go to a pool store and ask nicely for some solar bubble pool cover off cuts, a couple of layers of this floating on the water help it to heat up a lot quicker/keep the heat in when
can also recommend  the wetback idea, bag of coal to get it to 40deg, and another to keep it there for 2 days.  Also look for cheap warehouse pool pumps on the tard, got a new one for $50
Insulated the pipes with a towel as it was Twizel, and about -2 outside
Fahh , i thought of this when we started going through IBC's of Adblue coming through.
They are pretty strong with those cages in place. getting out when your pissed might be interesting , the sides are really smooth.
Yeah I was thinking exactly the same thing as we got heaps of ex adblue ones
I just wasn't sure about contamination. Was told inside plastic of container soaks up residue of adblue, but that could be bullshit
