boxxy
New Members-
About boxxy
- Birthday 01/06/1985
Gender
Male
Local Area
Wellington
boxxy's Achievements
Member (2/5)
4
I used a quartermaster 721-100 after reading of the dramas with the howe bearings. Its behind my 1uz and, touch wood, has been hassle free for 40000 kms of crawling down SH2 in wellington traffic. I got this kit when it was still a reasonable price http://www.trademe.co.nz/a.aspx?id=864089094 but you can import yourself for not too much if you shop around
Ive seen a few with the califont mounted in a box over the drawbar, keeps the gas run short and no need to make another potential leak in the roof
can also recommend the wetback idea, bag of coal to get it to 40deg, and another to keep it there for 2 days. Also look for cheap warehouse pool pumps on the tard, got a new one for $50 Insulated the pipes with a towel as it was Twizel, and about -2 outside
my mounts turned up today, pretty stoked with them for 150usd! and in, now have 15mm clearance all round, so should keep the cert man happy Tried the crown header, it fits with about 2mm between the steering knuckle so need to get creative In other news... house buying sucks. but have gone conditional on this 90m2 of garage/basement, double garage is behind (could fit 3 cars in) theres a house and a section too, but this is the best bit
Tried my hand at making up a hose today, I am using -6 braided teflon hoses for power steer and fuel, and -3 for my clutch line. Started on the longest hose so I could make a cockup and not worry too much... seems that was a good choice as I used shit tape when I made the cut and the cut off wheel flared the braid out making it impossible to put the nut on. Learnt 2 lessons - put the nut on first, and use good tape Checked and its about 3 inches longer than one of my fuel lines i have to make so not too much wasted hose. Also got one of these to convert my standard fuel hose to AN fittings as it isnt long enough to move the filter out of the way of the head and header. And the hose I made Tim
Is painful, but will be mint to have something of our own that has more than a car+nothing man cave and yea, keeping the Aircon - its hella easy as the compressors have the same oulet flange and are in roughly the same place. Looks a bit messy as I haven't degassed it yet so the old pumps hanging around. When the 1uz's in for the final time I will get the mobile aircon guy round to degas the old one, I'll unbolt/rebolt and get him to gas it back up. Found some engine mounts that are the right height, are poly, and are cheaper landed than some standard ones from mountshop They are for a Cadillac CTS-V so should be more than up to the task! also ordered this Was less than half the price shipped than the ones on trademe.. go fleabay When the mounts arrive I'll pull it out and install the clutch (anyone got a W5x clutch alignment tool I can borrow in welly? ) and install the fan bracket/idler and drop it back home for hopefully the last time. A few nights of attaching wires and it should be started Tim
Fuck. Had a big update writting and smashed the back button on the mouse. Aweseome. Havent done much recently as promised the better half we would save for a house deposit.. got preapproved for a loan so figure i can start spending on the car again When looking at the struts for Euron8 I noticed some rust, turns out it has been done before and hit with some bog but not painted properly. I'm not sure if I can get away with some more bog or if I need it cut out.. I hit what i could with a wire wheel and some kill-rust, and will assess properly when I pull the screen to replace it. pretty crap photo, but thoughts on if it needs cut out? I have no experience with rust at all Have ordered some more Metric to AN adapters for my fuel and PS lines as I cocked up the thread (1.5mm vs 1mm), and worked out the only big expenses left are: Drive shaft Exhaust Getting the diff setup in the cressida housing Some 215/35/19s for the front as the 235s dont have enough stretch/guard clearance And a fan bracket to get rid of the hydraulic fan pump think im gonna import one from the states as they are well cheaper than trademe/toyota nz so if anyone is keen for one and wants to halve shipping hit me up Also lifted the 1u up and got an engine rubber out so i can go down to BNT in the am and find some (taller) replacements. Im hoping 250000kms of holding the 7M up has squished them a bit and hopefully some standard ones will be sweet. Cheers, Tim
from top of the camberplate to the join of the strut tube to the hub (top of the cast bit) is 490mm with no weight, 465mm sitting on the ground with the 1uz in I got 10mm machined off the bottom of the BCs and welded 10mm up the tube. less than 5mm from tire to guard with a 235/35/19 hope that helps?!
If you you want i can measure the legnth of my BCs with no weight on them?
hmm this is all i could find atm wasnt overly low in the front, those springs are only cobra lows... bringing the back down from the standard bogan rake was another story, i think it was 65mm lower than standard in the back and 30 in the front in that pic the best low i had before my coil overs was std s14 springs, 60-70mm chassis clearance
Here you go, easiest way is to look for the lug thats circled the s2/jzx mounting surfaces are closer to horizontal but not quite, I read alot of things on the net saying they are dead flat which lead me to think i had an s1 cross member
looks like your cressy is an S2? if it is it has the same cross member as a JZX81 and then alloy mounts off a JZX90 work if you flip the sides (left to right, right to left) Ill hunt down the differences in the crossmembers for ya, have a favourite saved somewhere
Mint job dude, makes me wish I still had mine
So got home today to find a box on the porch containing.... they make the other headers look amazing haha spent a couple of hours pondering and moving the motor around and almost got it perfect, going to leave it slighly forward and get the drive and shaft / shifter housing extended unless I can find a remote shift box and it works. I lifted the drivers side 15mm and it now sits nicely off the rack, and clears the master cylinders ok so will lift the other side maybe 10mm to even it out a bit, and go hunting for some bigger rubbers so i dont have to use a stack of washers. if anyone knows of any that around around 85 -> 90mm sing out you can see here why I needed the ugly headers, will eventually get a custom set made up when the $$$s allow THe other side has all the aircon crap in the way (keeping it, just have to switch the top plates over on the compressors and its perfect.. score) but theres stiill enough space to just get my arms in. Heres my trusty helper, making sure I dont screw too much up oh yea, sorry for the crusty phone pics.. I dont own a real camera Tim
mmm x8 hardtop goodness Ive got some springs floating round in the shed that I dont want much for, if your keen giz a PM
