ajg193 Posted January 12, 2014 Report Share Posted January 12, 2014 Project: //oldschool.co.nz/index.php?/topic/41910-ajg193s-1983-kp61-sprint/ If anyone has any suggestions or wants any information or anything, post away. 1 Quote Link to comment Share on other sites More sharing options...
UTERUS Posted January 12, 2014 Report Share Posted January 12, 2014 Tang, de sprang. 6 Quote Link to comment Share on other sites More sharing options...
ajg193 Posted January 12, 2014 Author Report Share Posted January 12, 2014 I wish I understood the meaning of that... I'm guessing you mean lower it? Quote Link to comment Share on other sites More sharing options...
EURON8 Posted January 12, 2014 Report Share Posted January 12, 2014 I believe wee simon was suggesting a rotary and some lowering. Your plans to not lower it and not change the wheels is different. I don't like it ( good thing it's not my car aye) haha. I suppose a tidy original starlet is better than a Matt black cut springs de bumpered west auckland spec one. Quote Link to comment Share on other sites More sharing options...
ajg193 Posted January 12, 2014 Author Report Share Posted January 12, 2014 I just don't see the point in lowering cars. It is great how it is, just as high as my dad's ute. A little rolly around corners though. Quote Link to comment Share on other sites More sharing options...
Snoozin Posted January 12, 2014 Report Share Posted January 12, 2014 I have/had King springs in mine, and it didn't really lower it but it stiffened it up and handling improved if that's a way you'd like to go. 1 Quote Link to comment Share on other sites More sharing options...
ajg193 Posted January 12, 2014 Author Report Share Posted January 12, 2014 Could do. Not sure whether it would be safe though. The rolliness is a good indicator that I am going too fast around the corner already, if I stiffen it up I will probably just end up sliding all over the place. Quote Link to comment Share on other sites More sharing options...
kpr Posted January 12, 2014 Report Share Posted January 12, 2014 So many kp's on here now! while i also disagree with the lack of lowering. good to see you tiding it up rather than wrecking it. stock kp suspension is unsafe haha! it will be way way better with some firmer springs and decent shocks. even without lowering it. with the right suspension mods they handle awesome. 1 Quote Link to comment Share on other sites More sharing options...
Sparkle Posted January 12, 2014 Report Share Posted January 12, 2014 Lowering would be nice? ....hur hur hur. Have a similar one much the same as yours. Cool little cars! Totally understand keeping it fairly original. 1 Quote Link to comment Share on other sites More sharing options...
Beaver Posted January 16, 2014 Report Share Posted January 16, 2014 Could be a number of things mate, check the timing and the ignition (points gap or dwell, condition of spark plugs etc) Quote Link to comment Share on other sites More sharing options...
ajg193 Posted January 16, 2014 Author Report Share Posted January 16, 2014 I put brand new spark plugs in about a month ago, old ones were still mint though. I converted it to an electronic distributor at the same time, timing was set to 8* when that was done. EDIT1: It had the same idle before I put the electronic distributor in. EDIT2: I also checked all of the high tension leads when I did the spark plugs, all were well within tolerance. Quote Link to comment Share on other sites More sharing options...
lownslow Posted January 20, 2014 Report Share Posted January 20, 2014 I would be checking for air leaks. blown manifold gaskets are common on k series. spray some engine start/brake clean around manifold and see if idle speed changes. (some people prefer to use water, I dont) Quote Link to comment Share on other sites More sharing options...
ajg193 Posted January 22, 2014 Author Report Share Posted January 22, 2014 Checked that, no change with that CRC Engine Start stuff. Checked the spark plugs, they are clean. Quote Link to comment Share on other sites More sharing options...
ajg193 Posted February 7, 2014 Author Report Share Posted February 7, 2014 Seeing as you guys are a bunch of experts [hopefully] on the topic, maybe you can help me out with my gearbox noises. When it is in neutral and my foot is OFF the clutch it makes a fairly loud whirring sound, kind of like a skateboard rolling along. The sound goes away as soon as the clutch is pushed in, this indicates that it is NOT the release bearing causing the sound. What component is likely causing this sound and is this sound safe? The gearbox has always been making the sound during my ownership and I have changed the gear fluid. Thanks Quote Link to comment Share on other sites More sharing options...
Rookie Posted February 7, 2014 Report Share Posted February 7, 2014 Input bearing. I assume it makes the same noise when you are driving too. Quote Link to comment Share on other sites More sharing options...
ajg193 Posted February 7, 2014 Author Report Share Posted February 7, 2014 Can't hear it while I am driving, probably just because more engine noise and whatnot. Do you reckon it will be safe to keep driving it as is for another year until I get back up North? It isn't leaking any oil. Otherwise I could possibly make a mission of it and rip it out this weekend and fix it before I leave down south on the 12th. Quote Link to comment Share on other sites More sharing options...
ajg193 Posted February 7, 2014 Author Report Share Posted February 7, 2014 Also, for removing the input bearing on a K50 do I need to pull the whole box apart or does it just unbolt from the front of the box? The diagram in the manual makes it look like it can just be unbolted and pulled (somehow). Quote Link to comment Share on other sites More sharing options...
Rookie Posted February 7, 2014 Report Share Posted February 7, 2014 It will probably be sweet, but that is just an internet diagnosis hahaha Quote Link to comment Share on other sites More sharing options...
ajg193 Posted February 8, 2014 Author Report Share Posted February 8, 2014 I pulled the box today, that front bearing is definitely a bit noisy and sloppy. I might try and get my brother's old K50 from his KE70 and swap the tailhousing over. Just need to wait on the person that has it laying around. Quote Link to comment Share on other sites More sharing options...
ajg193 Posted February 8, 2014 Author Report Share Posted February 8, 2014 Ended up just stripping the box, putting new bearings in on monday. Quote Link to comment Share on other sites More sharing options...
