Valiant Posted September 23, 2013 Author Share Posted September 23, 2013 SOHC: The flat head 4 turns over, it's a long way off being a runner. I hadn't intended to make it a full resto, just make it move under it's own power, put the body work back on and sort out a hydraulic system so I can grade my drive and do the weeding etc with it. I will keep the flat head 4 in the corner of my garage, may be I'll restore it when I retire or something. I don't know. Thanks for the heads up about the V8. I'll hold off though thanks. I well blew the budget buying this. Felixx, Thanks I would be interested in seeing that. Is your carb an updraught? That's what this had. Is it a 1 bbl? * It's about 1.9L displacement I think. Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 23, 2013 Share Posted September 23, 2013 http://www.ebay.com/itm/Hercules-IXB3-Engine-Oliver-Cletrac-HG-OC3-OC4-OC46-Dozer-NICE-/171119910256 Here is another motor the same, quit pricey Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted September 23, 2013 Share Posted September 23, 2013 Quite pricey, that's an understatement.... Quote Link to comment Share on other sites More sharing options...
CUL8R Posted September 23, 2013 Share Posted September 23, 2013 Like Pete says, this thing is rather tiny, need to park next to Anglia/Valiant/Cortina/Hiace for scale.. A15 should make it fun, and alot more usable than the Original motor. Was impressed with just how solid it was - and shouldn't take too much work to remove previous owner bodges... 1 Quote Link to comment Share on other sites More sharing options...
Valiant Posted September 23, 2013 Author Share Posted September 23, 2013 http://www.ebay.com/itm/Hercules-IXB3-Engine-Oliver-Cletrac-HG-OC3-OC4-OC46-Dozer-NICE-/171119910256 Here is another motor the same, quit pricey Wow I'm glad I went and got it now. Quote Link to comment Share on other sites More sharing options...
Valiant Posted October 13, 2013 Author Share Posted October 13, 2013 I took to this with the gas set last week. Old motor and box, gone. Motor bike tank, gone. Radiator mounts, gone. Various other crap, gone. I've made a start tidying up the grill, made some side panels, and worked out how it all fitted together. Next is to work out what holds the fuel tank in place. Then start adding a motor. 4 Quote Link to comment Share on other sites More sharing options...
felixx Posted October 13, 2013 Share Posted October 13, 2013 Sir here is that carb, it might be of use? 2 Quote Link to comment Share on other sites More sharing options...
Valiant Posted October 13, 2013 Author Share Posted October 13, 2013 Yep Keen. Pick it up next weekend? 1 Quote Link to comment Share on other sites More sharing options...
felixx Posted October 13, 2013 Share Posted October 13, 2013 sweet as! Pleased to be able to help sir! 1 Quote Link to comment Share on other sites More sharing options...
Popular Post Valiant Posted November 8, 2013 Author Popular Post Share Posted November 8, 2013 Crawler. Datsun. Combined! It's a bit of a tight fit, nothing that some cutting and welding won't fix. Thanks Bart for the gearbox bits. I have a rear mount to make yet, it's a bit tricky. It needs to hold the motor to the crawler and the fuel tank to the bonnet. 11 Quote Link to comment Share on other sites More sharing options...
Valiant Posted November 14, 2013 Author Share Posted November 14, 2013 Thanks to this dubious creation. Rear mount, bearing retainer, and fuel tank stand 7 Quote Link to comment Share on other sites More sharing options...
hmmmnz Posted November 17, 2013 Share Posted November 17, 2013 ^^^^ like the britten motorbike, every part with atleast 2 uses awesome stuff 1 Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 17, 2013 Share Posted November 17, 2013 Excuse my retardation but how does the gearbox fit onto this or are you going direct drive from the clutch? (which is entirely plausible) Quote Link to comment Share on other sites More sharing options...
Yowzer Posted November 17, 2013 Share Posted November 17, 2013 I think the g/box and diff are a single unit mounted under the seat? Quote Link to comment Share on other sites More sharing options...
Valiant Posted November 17, 2013 Author Share Posted November 17, 2013 I think the g/box and diff are a single unit mounted under the seat? Yep you're right. It has 3 forward and 1 reverse in there with the diff. I'll make up some kind of a drive shaft to connect the two, I'm thinking a small tractor PTO shaft at the moment. Quote Link to comment Share on other sites More sharing options...
Yowzer Posted November 17, 2013 Share Posted November 17, 2013 Would be funny running another gbox on the engine for mega heaps of ratios to chose from 4 Quote Link to comment Share on other sites More sharing options...
Valiant Posted November 17, 2013 Author Share Posted November 17, 2013 Quite a few people do. it makes the motor/box combo to long with a more modern car box though. I think that a Ford model A gearbox fits the original motors with little or no modification. Read all about it here. http://cletrac.org/pages/auxtrans.html Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted November 17, 2013 Share Posted November 17, 2013 awesome! great to see progress! Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted November 17, 2013 Share Posted November 17, 2013 Try use a proper driveshaft. The tractor ones are pretty bang bang and prob won't love 4000 rpm as most run at 540 or 1000 on a pto 1 Quote Link to comment Share on other sites More sharing options...
Valiant Posted November 17, 2013 Author Share Posted November 17, 2013 Try use a proper driveshaft. The tractor ones are pretty bang bang and prob won't love 4000 rpm as most run at 540 or 1000 on a pto Good point. I'll have to see what's out there. Quote Link to comment Share on other sites More sharing options...
