Seedy Al Posted January 10, 2015 Share Posted January 10, 2015 Shes a lovely lady. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 11, 2015 Share Posted January 11, 2015 oh text me to remind me to grab my flare nut tool for your brake hoses Just a 10mm? I have most metric sizes Quote Link to comment Share on other sites More sharing options...
Beaver Posted January 11, 2015 Share Posted January 11, 2015 yeh 10 mm. Will txt you tomorrow Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 11, 2015 Share Posted January 11, 2015 make it sexy Quote Link to comment Share on other sites More sharing options...
hr31gts-x Posted January 12, 2015 Share Posted January 12, 2015 if pipe spanner dosnt work try vice grips on the pipe nut, i always get them out pretty good that way on my old nissans. Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted January 12, 2015 Share Posted January 12, 2015 The right tool is amazing to use. After years and years of rounding off flare nuts, and then having to use vise grips done up so tight that they would actually crush the nut out of round, I actually bought a set of the right spanners. Shit they're nice to use. You can lean on them hard, and you don't round them off/loose skin when they slip off. Good work with the Y Beaver-san. Having been privileged enough to be present when you first acquired her, it makes me smile lots to see how you're winning at 120Y improvement. Quote Link to comment Share on other sites More sharing options...
Beaver Posted January 12, 2015 Share Posted January 12, 2015 yep yep now have the right tool thanks to the seediest of Al's. Quote Link to comment Share on other sites More sharing options...
AllTorque Posted January 18, 2015 Share Posted January 18, 2015 Where's the pics? Keep an eye on your pinion angle when you lower the gearbox. Quote Link to comment Share on other sites More sharing options...
Beaver Posted January 18, 2015 Share Posted January 18, 2015 nothing to take pics off haha. Yeh will see how it pans out. The othe option option is to angle the diff head down but thats harder so will try that next if needed Quote Link to comment Share on other sites More sharing options...
Rookie Posted January 18, 2015 Share Posted January 18, 2015 You need to chop the floor to fix this properly. Quote Link to comment Share on other sites More sharing options...
Beaver Posted January 18, 2015 Share Posted January 18, 2015 Agreed. But since when do I do things properly? But yes, it may well come to that. Also need to track down some short sway bar links to get some extra clearance up front. Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted January 18, 2015 Share Posted January 18, 2015 Can you add a bit more to your bump stop height in the back? Make it hit rubber before you smash floor maybe? Depends on Heimlich travel you have/need I spoze Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted January 18, 2015 Share Posted January 18, 2015 Heimlich oh my lol Quote Link to comment Share on other sites More sharing options...
Beaver Posted January 18, 2015 Share Posted January 18, 2015 Yeh I dont think I have enough travel for that... Its pretty close to the bumps when it hits the floor so I dont think it needs too much extra room. I think ill drop the gbox a touch and see what that does, otherwsie it might be chopy chopy time. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 18, 2015 Share Posted January 18, 2015 Im not welding your floor with that gasless mig BTW lol 1 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 19, 2015 Share Posted January 19, 2015 if you get your exhaust done, AVS in Seaview are pretty fucken good, Quote Link to comment Share on other sites More sharing options...
Steelies Posted January 20, 2015 Share Posted January 20, 2015 oh tunnel/shaft/pinion angle shit. taken the car to highway speed after putting the box down yet? the wag got pretty chronic UJ rumble from all this jazz. ended up with wedged lowering blocks to correct pinion. still have em if you need at all/dodgy Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted January 20, 2015 Share Posted January 20, 2015 How did you bend the top piece of ur hoop? Nicely done Quote Link to comment Share on other sites More sharing options...
Beaver Posted January 20, 2015 Share Posted January 20, 2015 oh tunnel/shaft/pinion angle shit. taken the car to highway speed after putting the box down yet? the wag got pretty chronic UJ rumble from all this jazz. ended up with wedged lowering blocks to correct pinion. still have em if you need at all/dodgy Negative. Correcting the angle will reduce the clearance even further (as the nose of the diff will need to come up) so to fix it propoerly, I think I will need to cut the floor and angle the diff lol all fun and games. Quote Link to comment Share on other sites More sharing options...
Beaver Posted January 20, 2015 Share Posted January 20, 2015 How did you bend the top piece of ur hoop? Nicely done bent it over seedys dick. /it was part of a left over universal kit. 1 Quote Link to comment Share on other sites More sharing options...
