Yowzers Turbo Deezz Wagon of Smoke
Yowzer
  • Replies 201
are you using the VGT turbo or did you find something else/another CT26?
Yup Hilux VGT
Fired it up tonight, did a few stationary doorts to test the boosts. Has a mild exhaust leak and the alternator still doesn't work, so those are tomorrows jobs. Exhaust is now done though so it's basically driveable again.
10974330_829711993734679_805796247660055
Hey did you end up getting a controller for the VGT?
Yeah man the older setup way tougher. i love seeing the compressor in full sight for max intake noise tough lookingness . Watching the jet engine ramping up was something else .
P.s wanna buy a t45 with 1.0A/r  Garret?
Would take till 3g to get boost , but it would look pretty cool
New turbo setup has been so lush so far, and most importantly, it hasn't fallen off! The boost control is a bit vague due to the funky angle the actuator has to work on but I'll correct it one day.
I've whipped some new shocks in the front and tightened up the steering box which has improved the handling soooo much! It no longer smashes into the road and now has semi-responsive turn in. Woo!
The exhaust has had a bit of work recently, the old flexy was ripped to bits and in a bit of the wrong place
10688207_840412242664654_409323608371872
So I chopped it out and wacked a new one in further up the line, so the downpipe now hits the road post flexy and doesn't put all the stress on the turbo
10982580_840412399331305_160573737634004
As I've since found out it's now high enough to barely scrape. Although..
There was once an exhaust hanger there, but that fucked off somewhere in the Coromandel.
The zorst then took a pounding
Lols. So I patched it up
And hung it up
Heeeeaps more betterer mayte.
Still heaps to do but highest priority right now is a manual box. So till next time, here's a lush as fuck view from the trip home from Wagnats
1614513_831366950235850_7866884022052784
Controller is just a standard wastegate actuator hooked up through a check valve. It works pretty average but it works.
Yuh bigger turbo would be super lush but the low down torques this thing gives over the CT26 is phenomenal. Insta-powar! However those Kia Sorentos have a much bigger awesome looking Garret VNT and they pump out 200HP from a 2.2TD, which is all kinds of badass.
Happy to see/hear this thing is doing stuff again.
If ditching any of the L series turb stuff keep me in mind. Will likely buy to adorn shed walls with.
I ditched it all awhile ago sorry, I think I spend the funds on beer while thinking about boobs.
  • 4 months later...
