savageoutlaw Posted July 17, 2012 Share Posted July 17, 2012 OK, here is a picture of my problem so you know what I am talking about. When I have a bit of weight in the back - eg passengers etc this happens. Exhaust used to hit the ground sometimes while cornering - had that repaired and not wanting a repeat! I don't want to lift the cars ride height as I think it is perfect but are there any ways to prevent the springs from compressing so much - like in the picture. I believe it has coils all around and captive cut at the back. Sorry in advance if this is a stupid question, still learning the basics. Thanks Quote Link to comment Share on other sites More sharing options...
Taistorm Posted July 17, 2012 Share Posted July 17, 2012 Edit: Get firmer springs? There's an outfit down your way called Chamberlain who can make up springs to whatever specs and they're not too pricey. Perhaps get some measurements and pick a desired spring rate and get them to make up some springs for you. Chur, Tai. Quote Link to comment Share on other sites More sharing options...
Yowzer Posted July 17, 2012 Share Posted July 17, 2012 Yup firmer springs, and stiffer shocks so you don't get all bouncy bounce spec. Do it right and ride quality shouldn't suffer too much. Quote Link to comment Share on other sites More sharing options...
savageoutlaw Posted July 17, 2012 Author Share Posted July 17, 2012 That will be added to the list of things to do I guess. Any by not too pricey, how much cash are we talking - guesstamation? Are there any DIY solutions in the mean time that wont take up much cash. Need the cash to get it road legal again! Quote Link to comment Share on other sites More sharing options...
Yowzer Posted July 17, 2012 Share Posted July 17, 2012 DIY solutions would involve making a very educated guess on what spring rate and length you need, then go around the wreckers and measure up any and all springs you can find until you get something as close as possible. Trim with angle grinder if required. Quote Link to comment Share on other sites More sharing options...
Taistorm Posted July 17, 2012 Share Posted July 17, 2012 Probs be looking somewhere in between $300-$450 I reckon. May be a little more but doubt it. Quote Link to comment Share on other sites More sharing options...
dylann Posted July 17, 2012 Share Posted July 17, 2012 seriously though, what they said ^ 1 Quote Link to comment Share on other sites More sharing options...
savageoutlaw Posted July 17, 2012 Author Share Posted July 17, 2012 Yes , you would say your car was too low when you have to corner slowly to reduce the scraping the exhaust has on the road... Would putting something along the lines of rubber in some of the coils to dampen the compression be a stupid idea? Quote Link to comment Share on other sites More sharing options...
Yowzer Posted July 17, 2012 Share Posted July 17, 2012 I think there is actually such a thing. Yeah http://www.circletrack.com/chassistech/ ... ewall.html Don't know anything about them though, legalities and all that Quote Link to comment Share on other sites More sharing options...
chees- Posted July 17, 2012 Share Posted July 17, 2012 lift the exhaust up? /never take passengers Quote Link to comment Share on other sites More sharing options...
savageoutlaw Posted July 17, 2012 Author Share Posted July 17, 2012 Legalities can wait! They don't seem to be harmful at this stage. That picture is even better then what I had in mind... if anyone knew where I could find these or even what they are called would be much appreciated. Exhaust problem has been fixed by the way (it had leaks) and what is the point of being at high school with a Datsun when you cant give a few girls a ride in your car? Quote Link to comment Share on other sites More sharing options...
Yowzer Posted July 17, 2012 Share Posted July 17, 2012 They seem to be called 'spring rubbers' BNT, Autolign, random suspension shops could be worth a shot Quote Link to comment Share on other sites More sharing options...
Raizer Posted July 17, 2012 Share Posted July 17, 2012 Diy solutions on the cheap? No fat chicks Remove rear seats Air shocks Quote Link to comment Share on other sites More sharing options...
KKtrips Posted July 17, 2012 Share Posted July 17, 2012 Only way you can do it properly is uprated springs - ie get new coils made... $300 a pair.. Sorry but you better start saving pennys.. Quote Link to comment Share on other sites More sharing options...
durty Posted July 17, 2012 Share Posted July 17, 2012 Just kidding do not do this Quote Link to comment Share on other sites More sharing options...
Testament Posted July 17, 2012 Share Posted July 17, 2012 Put in longer bumpstops? probably the easiest option Quote Link to comment Share on other sites More sharing options...
Steelies Posted July 17, 2012 Share Posted July 17, 2012 yep, unfortunately buying the correct parts for the job is most likely the best option. Quote Link to comment Share on other sites More sharing options...
JoKer Posted July 17, 2012 Share Posted July 17, 2012 apparently a easy/simple solution to the front wheel lifting antics would be these : http://www.trademe.co.nz/motors/car-par ... 086149.htmanyone have experience? apparently that's what NASCAR does basically chocks the spring stiffening them up (similar to cutting a coil but not) found something similar to them coil rubbers on TM once, trying to stiffen my rear.. cant seem to find an existing lising thou discussion on this page www.oldschool.co.nz/phpbb/viewtopic.php ... 7&start=80 Quote Link to comment Share on other sites More sharing options...
Truenotch Posted July 18, 2012 Share Posted July 18, 2012 Falcon front springs in the rear - cut to suit. Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted July 18, 2012 Share Posted July 18, 2012 weld a sacrificial plate to the exhuast, repeat every 2 months? Quote Link to comment Share on other sites More sharing options...
