KIRK Posted November 29, 2012 Share Posted November 29, 2012 i seen a Tecumseh throw the whole barrel/top half of engine off the block lol Quote Link to comment Share on other sites More sharing options...
Rookie Posted November 29, 2012 Share Posted November 29, 2012 I think major engine failure deserves it's own patch, something to aspire to kids... Quote Link to comment Share on other sites More sharing options...
mark105 Posted November 29, 2012 Author Share Posted November 29, 2012 man 300cc's of piston to the balls. guess i had better not expect to have kids ahaha. Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted November 30, 2012 Share Posted November 30, 2012 1979 is quite old.The new hondas aint so crash hot. I've heard they're made in the same factory as robins, and a few other motors too.Crank up the boost, wind open the throttle, gnash your teeth, and hold on! i seen a Tecumseh throw the whole barrel/top half of engine off the block lolI had a tecumseh lawnmower break the crank right through the crank pin. It was just running away hapily, while I was emptying the catcher. As I walked back, it went CLUNK. And stopped dead. At least they have a forced fed lubrication system. Does you're motor have that TenFizz? Quote Link to comment Share on other sites More sharing options...
UTERUS Posted November 30, 2012 Share Posted November 30, 2012 It'll be sweet, we are still waiting for a proper engine failure aren't we? I'm trying man. Quote Link to comment Share on other sites More sharing options...
mark105 Posted November 30, 2012 Author Share Posted November 30, 2012 Force fed oil system in 1979 lol you be lucky. Splash fed. Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted November 30, 2012 Share Posted November 30, 2012 Do you know what the dipper is made from? Briggo's break the dipper when the revs get up. (Then the rods snap in two) So of the more up market rods have a big end cap with the dipper cast into it. I don't think it would be that hard to make your own rod. Yardkart guys tell tales of fitting a new rod, and pop ritiring a patch over the hole i the block with some RTV to seal it up. Quote Link to comment Share on other sites More sharing options...
KIRK Posted November 30, 2012 Share Posted November 30, 2012 briggs rods are strong as man. Tecumseh 4 stroke rods are much much less robust but still they are fine if you don't free rev it and your bearings are ok etc. as for the dipper. that shit isn't guna fail until waaay after you've trown a billet rod, flywheel, stiff valve springs and shit at the engine in an attempt to hit super-duper rpm. nothing is guna break on that engine, under load, below 5500-6000rpm. obviously boost might break or melt shit but that's a different issue Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted November 30, 2012 Share Posted November 30, 2012 braze the shit out of the rod- fill in any weight reducing cavities etc dunno if it will be stronger but it will look cool maybe cut rod in half and braze back together burt Munro style Quote Link to comment Share on other sites More sharing options...
UTERUS Posted November 30, 2012 Share Posted November 30, 2012 Put the doobie down man. Quote Link to comment Share on other sites More sharing options...
mark105 Posted December 3, 2012 Author Share Posted December 3, 2012 bit of plumbing and carburetion while i wait for other stuff to be sorted. just needs a reducer to hook up to engine to be made and its all done. rolling plain old radiator piping for inlet hose. not fully deal but should last long enough. was not keen on super expensive prices that silicone ones seem to be. Quote Link to comment Share on other sites More sharing options...
Rookie Posted December 3, 2012 Share Posted December 3, 2012 Looks mint. Quote Link to comment Share on other sites More sharing options...
Steelies Posted December 3, 2012 Share Posted December 3, 2012 cool man. so jealous! Quote Link to comment Share on other sites More sharing options...
KIRK Posted December 3, 2012 Share Posted December 3, 2012 church. so just to be clear you are getting glimmers and a sequential bov? Quote Link to comment Share on other sites More sharing options...
UTERUS Posted December 3, 2012 Share Posted December 3, 2012 Too legit 10 fizz, too fucking legit. Quote Link to comment Share on other sites More sharing options...
Ned Posted December 3, 2012 Share Posted December 3, 2012 Carb will get owned on beach runs if it's that low Quote Link to comment Share on other sites More sharing options...
KIRK Posted December 3, 2012 Share Posted December 3, 2012 its above the bottom of the frame ned. mine like drags in the sand and it still works lol Quote Link to comment Share on other sites More sharing options...
Rookie Posted December 3, 2012 Share Posted December 3, 2012 Ned; the foremost expert in Velobikes, heed his warning or else!! Quote Link to comment Share on other sites More sharing options...
peteretep Posted December 3, 2012 Share Posted December 3, 2012 Ned; the foremost expert in Velobikes, heed his warning or else!! lol Quote Link to comment Share on other sites More sharing options...
Ned Posted December 3, 2012 Share Posted December 3, 2012 Whatever guys, didn't you see the wink face? Love it 10-5, can't wait for this to put Creepy_Dave back in his place on the drome haha Quote Link to comment Share on other sites More sharing options...
